Tools I use: Multi-Axis Vice (for holding board in place), .015" silver bearing solder, fine tip wire cutter(for corrections), clip on magnifier, desoldering braid(suggested by others, but not used here), wirewrap insulation strip tool (for corrections), fine tip long needle nose pliers (for placing corrections), X-Acto knife (for corrections), flux, needle containing flux, flat tip screwdriver (IC final placement & holdown), tweezers (for general small part placement),
Bare boards. Start time is 9am. I will solder in the Spartan 6, power connector, JTAG connector and associated resistors, FPGA Proms, the MUX for FPGA program stream w/pull-up resistor and jumper, and finally 1.2V/2.5V VRegulators for FPGA.
EDIT (9/19/2012): 1st pic updated. Description updated.
