It is currently Sun Nov 24, 2024 12:18 pm
Post new topic Reply to topic  [ 213 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 15  Next
 Post subject: Re: Breaking 6502 apart
PostPosted: Fri Jun 29, 2012 6:44 am
That analog **** makes my research more complicated :(
6502 addict
PostPosted: Fri Jun 29, 2012 6:52 am
I think you can treat it all as digital, in the sense that a transistor is a switch. But it is bidirectional... And you can't divide up the circuit purely into neat logic gates. There are some interesting combinations.
By the way, the dynamic latches are the exact reason why a single stepping circuit must be careful about whether it stops with the clock high or low. One case will be fine, the other will have the leaking storage and will not be reliable.
PostPosted: Fri Jun 29, 2012 6:56 am
Thanks Ed, things become more clear to me.. )
50 kHz makes those 2 ms discharge rate )
At 500 kHz halfclock will last only 2us, its 1000 times shorter than discharge period )
So in order to recognize such capacitors I just need to pay attention on long polysilicon wires ?
6502 addict
PostPosted: Fri Jun 29, 2012 7:07 am
Oh, I know.... When I see mosfets connected in parralel next time, I will add capacitor in schematics =)
Edit: like that :
6502 addict
PostPosted: Fri Jun 29, 2012 7:46 am
Well, you won't always have two transistors - in fact, usually you'll only have one. You'll see these nodes in the timing shift register in the first picture you posted - at top right there's a master-slave flip-flop made of two dynamic latches. More or less.
But you probably only want to annotate a capacitor when the latch is single and there's no recirculation.
PostPosted: Mon Jul 02, 2012 8:08 am
Wrote small script which helps to understand which instructions are affected by decoder.
http://ogamespec.com/6502/decoder.htm
Type IR-line into input fiels and press "Decode". Script will highlight affected opcodes.
Example : XXX110X1
6502 addict
PostPosted: Mon Jul 02, 2012 8:30 am
Neat! It wasn't working for me at first, but I realised I was hitting 'Enter' rather than clicking on the button.
PostPosted: Mon Jul 02, 2012 7:23 pm
Todays speccy : Address pin
Bonus: Youtube videos, capturing my 6502 tracing skills :mrgreen:
Part 1 : preparations
http://www.youtube.com/watch?v=dj-DcMYihp4
Part 2 : color scheme
http://www.youtube.com/watch?v=wTJygx3VAXY
http://www.youtube.com/watch?v=_Z0O-IdJRQc
Part 3 : transistor level
http://www.youtube.com/watch?v=y-q5643WVno
6502 addict
PostPosted: Tue Jul 03, 2012 10:06 am
Todays speccy : SYNC
Color :
Transistor level :
Logic:
SYNC = sync (driven by internal signal through amplifiers)
Image Image
6502 addict
PostPosted: Tue Jul 03, 2012 2:18 pm
Found error in data latch (missing vias).
Updated transistor level schematics :
6502 addict
PostPosted: Tue Jul 03, 2012 5:42 pm
I completed reversing of data bus logic :)
PHI1:
if (DL_ADL) ADL = DL;
if (DL_ADH) ADH = DL;
if (DL_DB) DB = DL;
DOR = DB;
PHI2:
if (RW == 0) DATA = DOR;
DL = DATA;
ADL = ADH = DB = 0xFF;
6502 addict
PostPosted: Wed Jul 04, 2012 2:32 pm
Started random logic :)
Simple explanation :
6502 addict
PostPosted: Thu Jul 05, 2012 8:43 pm
Todays speccy : Registers X, Y, S
Color (bit 0):
Transistor level:
Logic:
PHI1:
if ( Y/SB ) SB = Y;
if ( SB/Y ) Y = SB;
if ( X/SB ) SB = X;
if ( SB/X ) X = SB;
if ( S/ADL) ADL = S;
if ( S/SB ) SB = S;
if ( SB/S ) S = SB;
if ( S/S ) S = S;
PHI2:
SB = 0xFF;
6502 addict
PostPosted: Fri Jul 06, 2012 11:26 am
Todays speccy : Predecode Register
6502 addict
PostPosted: Fri Jul 06, 2012 11:56 am
Instantly recognisable! You notice how the first transistors from the databus are huge? I think that's to make the inverter's logic threshold a bit lower, which it needs to be because the databus is at TTL levels. Fortunately, it makes no difference to a logic sim. A big pulldown is a more eager one, so the output flips at a lower input voltage than it otherwise would.
You see the same thing in the next gate, after phi2, because the pass transistor transmits a degraded logic 1. The ClearIR inputs are normal sized by comparison. (As discussed previously, those PDn nodes are storage nodes.)
