Tiny BASIC for the 65org16
I've got a port of Tiny BASIC for the 65org16 working on the simulator. As always, available here:
http://www.lowkey.comuf.com/
The labels still have a bunch of disassembly artifacts, so I may clean them up a bit in the near future.
ElEctric_EyE
It's under 9 pages (not counting input and output routines) -- a little bit smaller than the 6502 version. By default, the user area (where programs are stored) starts at $2900 (i.e. just after Tiny BASIC itself), but you can change that by changing the G2900 label.
The User Manual describes the 6809 version which is assembled at $100, so (e.g.) address 106 in the User Manual is address $2006 on the 65org16 (unless you change the .org). Beyond that, it should be fairly straightforward.
Another nice one Bruce! Got it running in py65, with the usual tweaks to accommodate the i/o routines and a fix to halt the memory check at a suitable limit.
Edit: Bruce's site is offline at present, so here's an archive.
The memory check could run into a mirroring problem presumably, especially on fpga: it might be useful to check for that. Here's a quick hack:
As memory generally comes in round-number sizes, and presuming that we start the check at a round-number boundary, I'm tempted to speed up the check by not checking every byte. However, probably the check doesn't take much time in reality - only in emulation.
(Edit: this doesn't work as written: the initial value of Y needs to be $80 too, and the final DEY needs to be LDY #0. Then we're left with a detected top of memory which is 127 bytes short.)
(I'll correct any errors - just let me know!)
$ PYTHONPATH=py65/src python py65/src/py65/monitor.py -m 65Org16 -l TBO16.bin -g 2000
Reset with new MPU 65Org16
Wrote +10478 bytes from $00000000 to $000028ed
:10 PRINT 22000/7
:20 END
:LIST
10 PRINT 22000/7
20 END
:RUN
3142
La0 LDA (Z22),Y ;; read location
CMP $0 ;; check for wraparound
BNE nowrap1
;; slight suspicion - check thoroughly
INC $0 ;; perturb
LDA $0
CMP (Z22),Y
BNE nowrap2
DEC $0 ;; restore
;; we did wraparound - $0 is the same location as (Z22),Y
DEY
JMP OP_MT ;; jump out of the memory test
nowrap2:
DEC $0 ;; restore
LDA (Z22),Y
nowrap1:
TAX
EOR #$FF
STA (Z22),Y ;; store complement
CMP (Z22),Y ;; see if it changed
STA (Z22),Y ;; put back the value
; INC Z22
LDA #$80 ;; we don't need to check every byte
CLC
ADC Z22
STA Z22
No doubt I've done something wrong(*), but I thought you'd be interested in first light: I dusted off my OHO spartan-3 module and loaded and ran this TinyBASIC port on the FPGA:
As you see: partial success. I may well have broken the memory test. I'll put it back to the original, have a look, and update this post.
Edit: Hmm, 293 means "Syntax error in expression - expects value" - my line-ends are 0x0d as sent down the line. What else would be syntactically wrong?
Edit: more pedestrian memory check acts the same.
(*)Edit: yes, I did something wrong - wrong CPU revision! Now working.
Send 65Org16 code in variant Intel Hex format at 19200,n,8,1 ->
Download Successful!
Jumping to location $0200
:print 4
!184
:PRINT 4
!293
[snip]
:PRINT "hi"
hi
:PRINT 22000/7
!293
Since my emulator acts like a pre-loaded 32 x 16-bit RAM (essentially the A31 to A15 "pins" are not "connected"), the memory scan won't work (it'll wrap and either clobber itself or go haywire when Z22 gets overwritten). So I load Tiny BASIC and then patch it to set Z22 to a fixed address and skip over the memory scan. It's pretty much the idea described in the User Manual (the paragraph before the STATEMENTS section), but the first command need not be CLEAR since I skip to OP_MT rather than OP_WS (as jumping to $2003 would do).
I'm not planning on making a 2.0 version (it certainly wouldn't be high priority). I'll leave the memory scan in 1.0, but by all means feel free to replace it.
I'd recommend dumping Z2C in the loop of the OP_BN routine. Another way to trace things is output the X register, Z2A, and Z2C at G20FC (and preserve the P register -- some OP_ routines depend on the carry value, I think), and you should be able to watch Tiny BASIC work its way through the TBIL code and your statements/program.
If you've changed the .org or any of the Z labels, it should work, but it's possible I've missed something, so you might want to check any instructions with immediate addressing. I've only done quick tests with those sorts of changes, nothing extensive, though. It's also possible that something might not work if you put labels in different order (e.g. Z82 at a lower address than Z80), though it's not supposed to be that way.
Beyond that, nothing else comes to mind other than the usual sanity/weirdness check, e.g. are any of the addresses $2x-$Cx (or wherever the Z labels are) not RAM for whatever reason?
Thanks for the tips. Quick update: this version is built to load at $200. I just checked, and it does run in py65, so it isn't the relocation at fault. I've got C'mon running on the fpga now. So I need to put those two things together and use the monitor to see where the problem lies (or, do as you suggest, and start adding instrumentation into tinybasic itself)
It only takes 10s or so to load the monitor as a hex package, so even without having it at reset time, it's pretty much there when I want it. (The system resets into the hex loader, and I don't feel like rejigging the boot ROM right now, although that would be a step forward.)
Moved my bringup meanderings to a new thread to remove clutter.
Apologies - my trouble with the bringup on 65Org16 was all my own fault, for using an old CPU which was already in the FPGA and assuming it would be OK.
Tiny Basic now runs nicely, and reports 4k as the top of memory, as expected:
It can also list and run a program:
(I'm getting stray newlines but not to worry about that - typical line-end convention nonsense.)
Something goes wonky with the RND() function though:
and so on, repeating a nonsense non-prompt until reset. Which doesn't happen in emulation. So perhaps I need to revisit the bringup thread - but probably not tonight.
:PRINT USR(831,34)
4095Code: Select all
:LIST
10 PRINT 22000/7
20 PRINT "Pi!"
30 END
:RUN
3142
Pi!Something goes wonky with the RND() function though:
:PRINT RND(100)
-45
d--
d--
ElEctric_EyE
Excellent work BigEd! On my way home from work, just thought I'd throw this out there:
It is one of my little goals now that we have a version of Basic to get this Mandlebrot program made by Bob Bishop for the Apple to work on the 65Org16.
I guess in order for the plotting portion, we would have to use the USR function to call an assembly routine?
I know TinyBasic does not have the ability for Arrays, does the Basic portion of Bob's program use arrays?
Special bonus from a 16-bit machine: TinyBasic has 32-bit arithmetic:
Yes, you'd use USR to call a plotting routine. I don't believe you need arrays. (If you're about to embark on an adventure, can I suggest a new thread?)
:A=32768
:B=65535
:C=A*B
:PRINT A,B,C
32768 65535 2147450880
:PRINT C+A
-2147483648
