Tiny BASIC bringup on the 65org16
I thought I'd start a new thread here, since Bruce's announcement thread need not be cluttered with my thrashing around trying to get the software working.
The code works on Bruce's emulator, and on py65.
It doesn't quite work on my OHO module: it's failing to understand decimal constants, including line numbers.
Back on the FPGA now. Most variables seem to have random values, which I can use to do arithmetic with. (I know, I'm procrastinating):
but I can't input any decimal constants (including line numbers). So, most of TinyBasic is presumably working. If I print a decimal string
the bytes coming back are as expected - no high bits set. Although of course they have gone through an 8-bit filter, so that's not much of a test.
:PRINT U,V,M,E
1 5 1000 11
:PRINT ((U+U)*E*M)/(U+U+V)
3142
:PRINT "42"
42
For the other errors, it looks to me like Z2C is either advancing too far or not far enough when parsing numbers (OP_BN). Are the upper bits of digit characters in the input buffer nonzero? (the BPL after the CMP #$3A and CLC could be as issue in that case)
LDA (Z2C),Y
000D 0000 :PRINT A
0050 0000 0050 0000 0050 0000 0050 0000 0050 0000 0052 0000 0049 0000 004E 0000 0054 0000 0020 0000 0041 0000 0041 0000 0041 0000 0041 0000 0041 0000 0041 0000 0041 0000 000D 0000 000D 0000 000D 0000 000D 0000 -17694720000D 0000 000D 0000 000D 0000 000D 0000
000D 0000 :PRINT B
0050 0000 0050 0000 0050 0000 0050 0000 0050 0000 0052 0000 0049 0000 004E 0000 0054 0000 0020 0000 0042 0000 0042 0000 0042 0000 0042 0000 0042 0000 0042 0000 0042 0000 000D 0000 000D 0000 000D 0000 000D 0000 65535000D 0000 000D 0000 000D 0000 000D 0000
000D 0000 :PRINT 2
0050 0000 0050 0000 0050 0000 0050 0000 0050 0000 0052 0000 0049 0000 004E 0000 0054 0000 0020 0000 0032 0000 0032 0000 0032 0000 0032 0000 0032 0000 0032 0000 0032 0000 0032 0000 0032 0000
!293
I borrowed a couple of routines from c'mon to do that:
PHP
PHA
JSR OUTHSP
TYA
JSR OUTHSP
PLA
PLP
A bit more instrumentation, to dump P just before GET_BAS_DIG returns:
shows us the shocking truth that carry is never set on exit:
which starts to look like a CPU bug.
Trying a similar piece of code in py65 we see that $31 in A, then CMP #$30 should set the carry:
Here's the code:
(that branch target is meaningless - it's not taken)
PHP
PHA
TXA
PHA
TSX
LDA $10002,X
JSR OUTHSP
LDA $10003,X
JSR OUTHSP
PLA
TAX
PLA
PLP
000D 0004 :PRINT 2
0050 0004 0050 0004 0050 0004 0050 0004 0050 0004 0052 0004 0049 0004 004E 0004 0054 0004 0032 0004 0032 0004 0032 0004 0032 0004 0032 0004 0032 0004 0032 0004 0032 0004 0032 0004
!293
$00002007 00c9 0030 CMP #$0030
PC AC XR YR SP NV---------BDIZC
65Org16: 00002007 0031 0000 0001 01ff 1000000000110000
$00002009 00ea NOP
65Org16: 00002009 0031 0000 0001 01ff 0000000000110001
.assemble 2000
$00002000 00a9 0031 LDA #$0031
$00002002 00c9 003a CMP #$003a
$00002004 0018 CLC
$00002005 0010 e0f8 BPL $000000ff
$00002009 00ea NOP
$0000200a 00ea NOP
$0000200b
ElEctric_EyE
BigEd, if I get you right, there's an issue of the 65Org16 core not setting the Carry flag during a CMP?
I know it is working for me. Having modified the ascii character output, for C'mon to output 2 characters per 16bit location, the code is something similar. This is just part of the slightly modified code to check for ascii...
D2 LDA (NUMBER),Y ;output LSB character
AND #$00FF
CMP #$20
BCC D3
CMP #$7F
BCC D4
D3 LDA #$7F ;output solid cursor character for non-printable char's
D4 JSR OUTPUTWell, I've just this minute checked with a short program in c'mon:
and it works:
which leaves me confused as to what's happening with TinyBasic.
That program isassembled in py65 and using the OUTHSP routine from C'mon.
d00@a9,31,c9,30,a9,0,2a,4c,2dd,0,
d00g
That program is
.assemble d00
$00000d00 00a9 0031 LDA #$0031
$00000d02 00c9 0030 CMP #$0030
$00000d04 00a9 0000 LDA #$0000
$00000d06 002a ROL A
$00000d07 004c 02dd 0000 JMP $000002dd
Gah! - it's all my fault - I've resynthed from a clean git checkout and reloaded the bitstream, and it is now behaving correctly!
The 65Org16 I had on the FPGA was possibly as old as Sep 5th. Perhaps I need to arrange that the ROM startup reports a version or a build date, or both. Or a version byte in a register or trivial peripheral.
Sorry for all the doubt and confusion.
