its TD to your RD,
its RD to your TD,
its RTS to your CTS,
its CTS to your RTS,
its DSR to your DTR,
its DTR to your DSR.
You can probably get away without RI.
RS-232 is asynchronous, meaning there's no clock line. The two ends have to agree on the speed, then the receiving end starts its clock at the leading edge of the start bit for each byte, and just uses the timing to know which bit it is looking at at any given instant. That's why the timing has to be accurate with RS-232. Edit: I blew the dust off an RS-232 primer article I wrote 9 years ago but never did anything with, and updated some links and things and posted it on my website, at http://wilsonminesco.com/RS-232/RS-232primer.html .
