Micro UK101 Build
- BigDumbDinosaur
What about BE (bus enable)? It must be pulled high, or else the MPU will tri-state the data and address buses.
- BigDumbDinosaur
BitWise wrote:
There is a lot of variation in cap values in published circuits using the MAX232CPE. I use 10uF in mine.
micro_brain
Before you guys have a mini bust-up over capacitor values, I'd just like to say I have acquired a set of 1uF electrolytics this afternoon, as well as a new MAX232 just in case the old one is blown.
I also got a new multimeter which has a frequency counter (I am hoping I can see the clock signals with it).
- BigDumbDinosaur
Which MAX would be your pleasure?
micro_brain
Well..
The meter is picking up 50hz from the power supply (even with just the -ve probe touching gnd), and I noticed this with the piezo transducer. Power supply is switched mode DC 5v 2A rating. Measures 5.1v DC but near zero AC.
There is nothing on any clock line apart from 50Hz mains hum
and nothing on the crystal - I expected 8Mhz.
Don't know if this meter is able to measure square wave frequency or whether it is AC only - Manual doesn't say.
Logic probe is in the post, it is one of these
http://www.maplin.co.uk/logic-probe-567 ... &u=strat15
This will show logic High / Low and pulsing (ie clock). I've yet to understand what this gives that a multimeter doesn't, apart from knowing a line is pulsing (but then you don't know the frequency). Still for a tenner it will be easier to use than a meter.
- GARTHWILSON
- Forum Moderator
It was some time in 1992 when I spoke with Maxim on whether the old (i.e., large) sizes would still work. I was told to use the 1uF to avoid harming the chip. I have done so ever since.
The reasoning behind using tantalums instead of electrolytics is the former exhibits a lot less leakage, thus making the charge pump more efficient. Electrolytics will work, just not as well.
Tantalums will have lower ESR. If you can get OS-CON capacitors, that's even better. OS-CON is not a brand but an electrolyte type, and there are at least two companies making OS-CON capacitors, one being Sanyo (which we use for the small switching supplies in our products).
If you already had a logic probe, as BDD has, you might not see much extra value in a frequency-counting multimeter. Especially if you already had a scope. But if you already had a frequency-counting multimeter (as I have) you might not see much extra value in a logic probe. It does tell you something about mark/space ratio, I gather, but then so does the mean DC voltage perhaps?
(Frequency counting up to 15MHz)
micro_brain
It is one of these:
http://www.maplin.co.uk/ut60e-true-rms- ... face-46458
Goes up to 10Mhz for frequency counting. I needed a new meter anyway as my old one (30 years and still working) is showing signs of intermittent failure.
Question is can it measure square wave frequencies? Because I am still not convinced the clock circuit on my board is not functioning, and if the meter can't do this one thing it is going back where it came from.
micro_brain
can you rig up a clock from any other nearby source? Or do you need to send off for another crystal? One reason I like the Beeb as a platform for experiments is the ease of picking signals out of it, or desocketing chips. If you've any old 8-bit computers around, you might have some signals of reasonable frequency.
micro_brain
Is there a way to test the crystal independently, and are they fragile? I mean, what's the chance I damaged it during soldering?
Sorry, I don't know how fragile crystals are. I think perhaps (4-pin) crystal cans are more robust but I get the impression this really is a (2-pin) crystal. (I think it's a fairly good plan to socket as much as you can, and perhaps a moderately good plan to buy a spare, for components which are cheap compared to postage. If you use a socket then you can't damage during soldering, and you can replace a component which got damaged some other way.)
But, just a quick and obvious question: Have you checked your board for shorts and opens? And checked the power rails, of course.
(Edit: I should point out: the 4-pin crystal can is a 5v oscillator, and produces a clock signal without the need for the external components found on the micro-uk101)
micro_brain
There isn't a power rail as such, the Vcc / Gnd lines are all connected pin to pin. Yes, they're all correct and supplying +-5v to Vcc / Vss/Gnd respectively at all required locations (basically the IC sockets). I have done continuity checks on the IC pins to ensure all address and bus lines are connected, and the glue logic connections too. Like I said, i found a few errors which I corrected. I found incorrect resistor values in the clock circuit and corrected them (47k instead of 470R). I think I should revisit the wiring of the clock circuit itself to double check it. I already checked it once.
Yes, it is a 2 pin crystal. Only the ICs are socketed (otherwise I may just have well have used a breadboard).
I think I have a couple of spectrums, but can only find one, and it doesn't seem to have any life. There's a schematic herewhich says the ULA clock output comes out on pin 8A of the edge connector, and the board diagram here suggests that pin 8A would be on the underside, and would count from the middle, towards the power connector. It might be that A0 would also be an acceptable clock-like signal - pin 9A. Oh, in fact there's a handy diagram of the edge connector which I missed:
