Hi all,
Following up on my February post about the two-Pico system with the real 6522 bridge—I've continued pushing this project forward and just released
v0.96 of what I'm now calling the
W25Q64_INTERLOCK project.
GitHub:
https://github.com/DonaldMoran/W25Q64_INTERLOCK
Pre-release details:
https://github.com/DonaldMoran/W25Q64_I ... /tag/v0.96
This release represents a major milestone. What started as a VIA emulation experiment has grown into a complete retro‑computing environment:
You'll want python 3 and CA65.
Key additions:
- FIG‑Forth 1.1 with a virtualized disk system mapping classic 1K Forth "screens" to individual files in /FORTH/. This release includes the FIG‑Forth editor from the FIG Installation Manual (screens 87‑97), packaged and ready to install.
- Local storage using the onboard W25Q64 flash chip, providing persistent file storage for the entire system
- MSBASIC 2.0 (Commodore BASIC) with SAVE/LOAD
- Krusader resident assembler with file‑based source management (S [save source] and F [fetch source], i.e. S ASSEM/ABC.S and F ASSEM/ABC.S)
- WRITE – a full‑screen, nano‑like text editor I authored for the system, featuring cursor movement and line numbering, etc.
- CALC – a programmer's calculator I also authored, supporting hex, decimal, and binary operations as well as Address Range Calculation
- DOTS (.S) stack display utility for Forth
- DDOS shell with file management (LS, CP, MV, RM, CATALOG, etc...) and networking (GET, PUT, PING, RLIST [remote list], etc...)
- NEWS/WEATHER info streaming over HTTP
The architecture is now a
two‑Pico system:
- Host Pico – runs the 6502 emulator (optional—can also use a real 65C02)
- Bridge Pico W – acts as a smart peripheral over a real 6522 VIA with automatic handshake, featuring the W25Q64 flash chip for local storage
The Bridge Pico W handles networking, file storage (on the W25Q64), and all the heavy lifting while presenting a clean interface to the 6502 side. Transient commands are fetched over HTTP from a local file server, making the system highly modular and easy to extend.
Here's the wiring diagram showing the connections between the Host Pico, Bridge Pico W, and W25Q64 flash:
HOST PICO (Emulator) BRIDGE PICO (Pico W)
| GP0 (PA0) <--------->| [DATA BUS] <--->| GP6 (PA0) |
| GP1 (PA1) <--------->| [DATA BUS] <--->| GP7 (PA1) |
| GP2 (PA2) <--------->| [DATA BUS] <--->| GP8 (PA2) |
| GP3 (PA3) <--------->| [DATA BUS] <--->| GP9 (PA3) |
| GP4 (PA4) <--------->| [DATA BUS] <--->| GP10 (PA4) |
| GP5 (PA5) <--------->| [DATA BUS] <--->| GP11 (PA5) |
| GP6 (PA6) <--------->| [DATA BUS] <--->| GP12 (PA6) |
| GP7 (PA7) <--------->| [DATA BUS] <--->| GP13 (PA7) |
| GP11 (CA2) ---------->| [REQUEST] ---->| GP14 (Input) |
| GP10 (CA1) <----------| [ACK] <----| GP15 (Output) |
| GND -----------------| [COMMON GND] ---|--- GND |
| BRIDGE PICO (W) |
| GP19 --------------->| DI (MOSI)
| GP18 --------------->| CLK
| GND --------------->| GND
| GP17 --------------->| CS
| GP16 --------------->| DO (MISO)
v
| W25Q64 FLASH |
| (left→right labels) |
| DI(MOSI) <------->| GP19
| CLK <------->| GP18
| GND <------->| GND
| DO(MISO) <------->| GP16
| CS <------->| GP17
| VCC <------->| 3V3
Getting started is documented in the release notes at
https://github.com/DonaldMoran/W25Q64_I ... /tag/v0.96 —flash both UF2 files, run the Python file server, and stage the networking command
SETSERVER via WozMon, as well as the
GET command. Once that's done, you can use that "transient" command
GET to get the rest of the transient command suite and the FIG‑Forth screens. The included
figinst_editor.zip contains the classic fig-FORTH 1.1 Installation Manual editor screens (87‑97) for a complete Forth development environment.
The project is still in pre‑release, and I'd love feedback from anyone willing to test it out. Open issues on GitHub if you run into anything or have suggestions.
This thread and jfoucher's original emulator were the foundation that made all of this possible—thanks again!
— Don (noneya)
