Download and install Putty (if you don't have it already). This will install puttygen.exe
Run puttygen, it should be available from the Windows Start Menu after installation.
GitHub recommend using an ed25519 type key but Putty doesn't seem to support that. Secondarily they recommend an RSA 4096 type key and that can be generated by Putty. Click Generateand wave your mouse around until the green bar is satisfied.
Once the key is generated copy the Public-key text... ...into a new GitHub SSH Key. This can be found under your Account Settings, SSH and GPG keys: And paste the Public-Key text into your new GitHub SSH KeyAdd SSH Key and we're done on the GitHub side of things.
Back in puttygen copy the Public-Key text again, paste it into a text editor and save it somewhere useful with the .pub extension. E.g. C:\MyKeys\MyKeyName.pub Do not use the Save Public Key button from puttygen unless you know what you're doing. We're saving the OpenSSH Public-Key text just-in-case.
Next export the Private-Key for OpenSSH, again this is just-in-case......and save it somewhere secure. E.g. C:\MyKeys\MyKeyName Note the lack of extension.
The saved Private-Key should look something like this:
-----BEGIN OPENSSH PRIVATE KEY-----
b3BlbnNzaC1rZXktdjEAAAAABG5vbmUAAAAEbm9uZQAAAAAAAAABAAACFwAAAA
BAUGBwgJ
-----END OPENSSH PRIVATE KEY-----
Finally we need to Save the Private-Key in a form that can be used by Putty's authentication agent Pageant.Save it somewhere secure E.g. C:\MyKeys\MyKeyName.ppk and note the ppk extension.
The PPK should look something like:
PuTTY-User-Key-File-3: ssh-rsa
Encryption: none
Comment: rsa-key-20231012
Public-Lines: 12
AAAAB3NzaC1yc2EAAAADAQABAAACAQDpDTEMZZf9WIFtlGdlIMJDskcHpvP1
WnUQlA==
Private-MAC: bbac19a0c60363e1ced7f7c72c340709991381d4706e3e6ee345e1cc24540850
