For some reverse-engineering I wanted some simple logic equations describing each opcode to reason about which registers or data locations were affected by a given instruction stream.
I realized Forth was a nice clean way to express (and test) that. I got slightly carried away and ended up writing this a full(*) emulator in TaliForth. (*) No decimal adc/sbc atm. I'm sure this kind of thing has been done before, so would appreciate any feedback on the approach. I'm more interested in simplicity than performance.
(edit: bugfix, bcd mode, P.)
\ 65c02 inception: emulate the 65c02 CPU with TaliForth running on a 65c02...
\ This is illustrated by emulating TaliForth's own assembly code for UM*
\ Also tested via https://github.com/SingleStepTests/ProcessorTests/tree/main/wdc65c02
\ Note: STP and WAI are treated as NOP
\ Since TaliForth is running in a 64K memory space we restrict the emulator
\ memory to a smaller memory footprint by ignoring high address bits.
\ For example setting MBITS to 12 gives 2^12 = 4K bytes of emulator memory, with
\ four ignored address bits. This means that there are 16 ways to address each
\ actual byte. For testing we avoid tests that address the same actual location
\ with distinct 16 bit synonyms. Also note that the BRK/IRQ vector at $fffe-f
\ will always map to the last two bytes of emulator memory.
12 constant MBITS \ simulator memory is 1 << MBITS bytes, with upper address bits ignored
$FFFE constant IRQBRK \ maps to the last two emulator bytes since high bits are ignored
\ create emulator address mask and reserve its memory
1 MBITS lshift 1- constant MMASK
here MMASK 1+ allot constant MBASE
\ helper functions for reading and writing emulator memory
: &M ( adr -- adr' ) MMASK AND MBASE + ; \ emulator address to host address
: M ( adr -- v ) &M C@ ;
: >M ( adr v -- ) SWAP &M C! ;
\ We need to be careful with double byte access, since they need to wrap at
\ 8 or 16 bits. So we can't just use @ to fetch two bytes since they aren't
\ always contiguous in memory.
: LSB ( v -- byte ) $FF AND ;
: W>B ( w -- lo hi ) DUP LSB SWAP 8 RSHIFT ;
: B>W ( lo hi -- w ) 8 LSHIFT OR ;
: MM ( adr -- adr ) DUP M SWAP 1+ M B>W ; \ read word from two bytes
: MMZ ( zp -- adr ) DUP M SWAP 1+ LSB M B>W ; \ read word from two bytes in ZP
\ Define the 16 bit program counter and some helpers
0 value PC
: >PC ( adr -- ) TO PC ;
: PC+ ( -- adr ) PC PC 1+ >PC ;
: PC++ ( -- adr ) PC PC 1+ 1+ >PC ;
\ Reserve table of opcode XTs, with helpers to populate and emulate them
here $100 CELLS ALLOT constant OPS
: op, ( p xt -- p' ) OVER ! 1+ 1+ ; \ helper to write XT and inc slot
: op ( -- ) PC+ M CELLS OPS + @ EXECUTE ; \ emulate current opcode
\ Reserve register memory and set up access helpers
here 5 allot constant REGISTERS
0 constant #A
1 constant #X
2 constant #Y
3 constant #S \ stack pointer (8 bit)
4 constant #P \ flag register
\ use Q for generic register to avoid confusion with return stack words
: &Q ( # -- adr ) REGISTERS + ;
: Q ( # -- v ) &Q C@ ;
: Q! ( v # -- ) &Q C! ;
: >Q ( # v -- ) SWAP Q! ;
: A ( -- v ) #A Q ; : >A ( v -- ) #A Q! ;
: X ( -- v ) #X Q ; : >X ( v -- ) #X Q! ;
: Y ( -- v ) #Y Q ; : >Y ( v -- ) #Y Q! ;
: S ( -- v ) #S Q ; : >S ( v -- ) #S Q! ;
: P ( -- v ) #P Q ; : >P ( v -- ) #P Q! ;
\ Stack management
: PUSH ( v -- ) S $100 + SWAP >M S 1- >S ;
: POP ( -- v ) S 1+ >S S $100 + M ;
\ push/pull address bytes individually since stack can wrap
: PUSH2 ( vv -- ) W>B PUSH PUSH ;
: POP2 ( -- vv ) POP POP B>W ;
\ Flag bits
%00000001 dup constant ^0 constant ^C \ Carry
%00000010 dup constant ^1 constant ^Z \ Zero
%00000100 dup constant ^2 constant ^I \ Interrupt
%00001000 dup constant ^3 constant ^D \ Decimal
%00010000 dup constant ^4 constant ^B \ Break
%00100000 dup constant ^5 constant ^G \ Ignored (always set)
%01000000 dup constant ^6 constant ^V \ Overflow
%10000000 dup constant ^7 constant ^N \ Negative
s" NV1BDIZC" drop constant FLAGS
: BIT? ( v mask -- f ) AND 0<> ; \ test if bit number is set
\ helpers to set or query flags
: F>P ( f mask -- ) DUP INVERT P AND -ROT AND OR >P ; \ set or clear bit number based on flag
: >Z ( v -- ) 0= ^Z F>P ; \ set Z by testing value for zero
: >N ( v -- ) ^7 BIT? ^N F>P ; \ set N by testing sign of value
: >Z>N> ( v -- v ) DUP >Z DUP >N ; \ shortcut for both, keeping value
: >C ( f -- ) ^C F>P ; \ set other flags with true/false
: >V ( f -- ) ^V F>P ;
: C? ( -- f ) P ^C BIT? ; \ carry flag as true/false
: D? ( -- f ) P ^D BIT? ;
: P. ( -- ) 8 0 DO ( adr ) P ^N I RSHIFT BIT? IF FLAGS I + C@ ELSE [CHAR] - THEN EMIT LOOP ;
\ define T and >T so generic instructions can operate on either register or memory
DEFER &T ( adr -- adr' )
: T ( adr -- v ) &T C@ ;
: >T ( adr v -- ) SWAP &T C! ;
: T:M ( -- ) ['] &M IS &T ; \ target memory
: T:Q ( -- ) ['] &Q IS &T ; \ target register
: SEXT ( rel -- v ) DUP ^7 BIT? $ff00 AND OR ; \ sign extend an 8-bit value
\ addressing modes that target a memory location or register index
: @IMPLA ( -- r ) #A T:Q ; \ implied A
: @IMPLX ( -- r ) #X T:Q ; \ implied X
: @IMPLY ( -- r ) #Y T:Q ; \ implied Y
: @IMM ( -- adr ) PC+ T:M ; \ #dd
: @ZP ( -- adr ) PC+ M T:M ; \ zp
: @ZPX ( -- adr ) PC+ M X + LSB T:M ; \ zp,X
: @ZPY ( -- adr ) PC+ M Y + LSB T:M ; \ zp,Y
: @ZPI ( -- adr ) PC+ M MMZ T:M ; \ (zp)
: @ZPXI ( -- adr ) PC+ M X + LSB MMZ T:M ; \ (zp,X)
: @ZPIY ( -- adr ) PC+ M MMZ Y + T:M ; \ (zp),Y
: @ABS ( -- adr ) PC++ MM T:M ; \ llhh
: @ABSX ( -- adr ) PC++ MM X + T:M ; \ llhh,X
: @ABSY ( -- adr ) PC++ MM Y + T:M ; \ llhh,Y
: @ABSI ( -- adr ) PC++ MM MM T:M ; \ (llhh)
: @ABSXI ( -- adr ) PC++ MM X + MM T:M ; \ (llhh,X)
: @REL ( -- adr ) PC+ M SEXT PC + T:M ; \ rr
: @ZPREL ( -- a a ) PC+ M @REL T:M ; \ zp,rr
\ opcode implementations that act on a register or memory location
: %STQ ( adr r# -- ) Q >T ;
: %STZ ( adr -- ) 0 >T ;
: %LDQ ( adr #r -- ) SWAP T >Z>N> >Q ;
\ most transfers are expressed as load from implied register with special case for S
: %TSX ( -- ) S >Z>N> >X ;
: %TXS ( -- ) X >S ; \ NB no flags are affected
: %INC ( adr -- ) DUP T 1+ LSB >Z>N> >T ;
: %DEC ( adr -- ) DUP T 1- LSB >Z>N> >T ;
: %ORA ( adr -- ) T A OR >Z>N> >A ;
: %AND ( adr -- ) T A AND >Z>N> >A ;
: %EOR ( adr -- ) T A XOR >Z>N> >A ;
: %SMB ( adr bit -- ) OVER T OR >T ;
: %RMB ( adr bit -- ) INVERT OVER T AND >T ;
: %BIT ( adr -- ) T DUP A AND >Z DUP >N ^6 BIT? >V ;
\ BIT #dd is a special case where only Z is updated
: %BIT' ( adr -- ) T A AND >Z ;
: %TRB ( adr -- ) DUP T A 2DUP AND >Z INVERT AND >T ;
: %TSB ( adr -- ) DUP T A 2DUP AND >Z OR >T ;
: %LSR ( adr -- ) DUP T DUP ^0 BIT? >C 2/ >Z>N> >T ;
: %ASL ( adr -- ) DUP T DUP ^7 BIT? >C 2* LSB >Z>N> >T ;
: %ROR ( adr -- ) C? ^7 AND OVER T DUP ^0 BIT? >C 2/ OR >Z>N> >T ;
: %ROL ( adr -- ) C? ^0 AND OVER T DUP ^7 BIT? >C 2* OR LSB >Z>N> >T ;
: %CPQ ( adr #r -- ) Q SWAP T - >Z>N> 0< INVERT >C ;
\ Use XOR trick for add/subtract to infer the carry bits from the sum S
\ Start with S = A^M^CS so CS = S^A^M and we can calculate the 6502 flags
\ via C = C8 (the addition has a carry if carry out of bit 7 is set)
\ and V = C8^C7 (overflow if the carries in and out of bit 7 differ)
: A+ ( v -- v )
A 2DUP XOR -ROT
( A^B B A )
+ C? - \ calculate S=A+B+C, noting C? is true == -1 when set
TUCK XOR \ calculate A^B^S to get C and V flags
( S A^B^S )
DUP $100 BIT? DUP >C SWAP ^7 BIT? XOR >V
( S )
LSB >Z>N> \ set Z and N leaving byte result
: B>HL ( v -- hi lo ) DUP $F0 AND SWAP $F AND ;
\ BCD flags for addition and subtraction are a mess
\ this implements 65c02 behavior per http://www.6502.org/tutorials/decimal_mode.html#B
\ for V flag we use twos complement addition in seg 2C but note that
\ sign extending a byte with bit 7 set effectively subtracts $100.
\ so we can correct the signed result back to unsigned by tracking which bytes with negative
: ABCD+ ( b -- s )
B>HL A B>HL ( bh bl ah al ) ROT + C? - \ seq 2A
DUP 9 > IF $6 + $F AND $10 OR THEN ( bh ah sl ) \ seq 2B
\ sign extend bh, ah as bh', ah' tracking unsigned correction cb, ca each 0 or $100
-ROT SEXT DUP $100 AND ROT SEXT DUP $100 AND ( sl ah' ca bh' cb )
ROT + -ROT + ROT + ( cc s' ) \ seq 2C (signed result with correction)
DUP $80 + $FF00 BIT? >V \ seq 2F
+ DUP $9F > $60 AND + ( s ) \ seq 1E (correct back to unsigned)
DUP $FF00 BIT? >C \ seq 1G
LSB >Z>N>
\ For subtraction, use binary difference to set C and V, then find the actual BCD difference
: ABCD- ( b -- s )
C? INVERT >R DUP INVERT A+ DROP ( b R: 1-c ) \ set C and V, saving original carry
A $F AND OVER $F AND - R@ + ( b sl R: 1-c ) \ seq 4A
A ROT - R> + ( sl s ) \ seq 4B
DUP 0< $60 AND - \ seq 4C
SWAP 0< 6 AND - \ seq 4D
LSB >Z>N>
: %ADC ( adr -- ) T D? IF ABCD+ ELSE A+ THEN >A ;
\ Reframe subtraction as an addition using twos complement:
\ -M = 256 - M = 1 + 255 - M = 1 + ~M where ~M is the inverse of M
\ Since borrow = 1 - carry we get:
\ A - M - borrow = A + ~M + 1 - borrow = A + ~M + C
: %SBC ( adr -- ) T D? IF ABCD- ELSE INVERT A+ THEN >A ;
: %PHT ( r -- ) T PUSH ;
: %PLT ( r -- ) POP >Z>N> >T ;
\ the status register has special behavior
: %PHP ( -- ) P ^B OR PUSH ; \ set BRK
: %PLP ( -- ) POP ^G OR ^B INVERT AND >P ; \ set IGN clr BRK
: %CLF ( mask -- ) FALSE SWAP F>P ;
: %SEF ( mask -- ) TRUE SWAP F>P ;
: %JMP ( adr -- ) >PC ;
: %JSR ( adr -- ) PC 1- PUSH2 >PC ;
: %RTS ( -- ) POP2 1+ >PC ;
: %RTI ( -- ) %PLP POP2 >PC ;
: %BRK ( adr -- ) DROP PC PUSH2 %PHP ^I %SEF ^D %CLF IRQBRK MM >PC ;
: ?JMP ( adr f -- ) IF >PC ELSE DROP THEN ;
: %BFS ( adr mask -- ) P AND ?JMP ;
: %BFC ( adr mask -- ) P AND 0= ?JMP ;
: %BBR ( adr dst bit -- ) ROT T AND 0= ?JMP ;
: %BBS ( adr dst bit -- ) ROT T AND ?JMP ;
: %NOP ( adr -- ) DROP ; \ Support variable length NOPs
\ Build the opcode table, usually pairing a memory mode with an operator
OPS
:noname @IMM %BRK ; op, \ 00 BRK ---I--
:noname @ZPXI %ORA ; op, \ 01 ORA (zp,X) NZ----
:noname @ZPI %NOP ; op, \ 02 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ 03 NOP ------
:noname @ZP %TSB ; op, \ 04 TSB zp -Z----
:noname @ZP %ORA ; op, \ 05 ORA zp NZ----
:noname @ZP %ASL ; op, \ 06 ASL zp NZC---
:noname @ZP ^0 %RMB ; op, \ 07 RMB0 zp ------
:noname %PHP ; op, \ 08 PHP ------
:noname @IMM %ORA ; op, \ 09 ORA #dd NZ----
:noname @IMPLA %ASL ; op, \ 0A ASL A NZC---
:noname @IMPLA %NOP ; op, \ 0B NOP ------
:noname @ABS %TSB ; op, \ 0C TSB llhh -Z----
:noname @ABS %ORA ; op, \ 0D ORA llhh NZ----
:noname @ABS %ASL ; op, \ 0E ASL llhh NZC---
:noname @ZPREL ^0 %BBR ; op, \ 0F BBR0 zp,rr ------
:noname @REL ^N %BFC ; op, \ 10 BPL rr ------
:noname @ZPIY %ORA ; op, \ 11 ORA (zp),Y NZ----
:noname @ZPI %ORA ; op, \ 12 ORA (zp) NZ----
:noname @IMPLA %NOP ; op, \ 13 NOP ------
:noname @ZP %TRB ; op, \ 14 TRB zp -Z----
:noname @ZPX %ORA ; op, \ 15 ORA zp,X NZ----
:noname @ZPX %ASL ; op, \ 16 ASL zp,X NZC---
:noname @ZP ^1 %RMB ; op, \ 17 RMB1 zp ------
:noname ^C %CLF ; op, \ 18 CLC --C---
:noname @ABSY %ORA ; op, \ 19 ORA llhh,Y NZ----
:noname @IMPLA %INC ; op, \ 1A INC A NZ----
:noname @IMPLA %NOP ; op, \ 1B NOP ------
:noname @ABS %TRB ; op, \ 1C TRB llhh -Z----
:noname @ABSX %ORA ; op, \ 1D ORA llhh,X NZ----
:noname @ABSX %ASL ; op, \ 1E ASL llhh,X NZC---
:noname @ZPREL ^1 %BBR ; op, \ 1F BBR1 zp,rr ------
:noname @ABS %JSR ; op, \ 20 JSR x16 ------
:noname @ZPXI %AND ; op, \ 21 AND (zp,X) NZ----
:noname @ZPI %NOP ; op, \ 22 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ 23 NOP ------
:noname @ZP %BIT ; op, \ 24 BIT zp NZ---V
:noname @ZP %AND ; op, \ 25 AND zp NZ----
:noname @ZP %ROL ; op, \ 26 ROL zp NZC---
:noname @ZP ^2 %RMB ; op, \ 27 RMB2 zp ------
:noname %PLP ; op, \ 28 PLP NZCIDV
:noname @IMM %AND ; op, \ 29 AND #dd NZ----
:noname @IMPLA %ROL ; op, \ 2A ROL A NZC---
:noname @IMPLA %NOP ; op, \ 2B NOP ------
:noname @ABS %BIT ; op, \ 2C BIT llhh NZ---V
:noname @ABS %AND ; op, \ 2D AND llhh NZ----
:noname @ABS %ROL ; op, \ 2E ROL llhh NZC---
:noname @ZPREL ^2 %BBR ; op, \ 2F BBR2 zp,rr ------
:noname @REL ^N %BFS ; op, \ 30 BMI rr ------
:noname @ZPIY %AND ; op, \ 31 AND (zp),Y NZ----
:noname @ZPI %AND ; op, \ 32 AND (zp) NZ----
:noname @IMPLA %NOP ; op, \ 33 NOP ------
:noname @ZPX %BIT ; op, \ 34 BIT zp,X NZ---V
:noname @ZPX %AND ; op, \ 35 AND zp,X NZ----
:noname @ZPX %ROL ; op, \ 36 ROL zp,X NZC---
:noname @ZP ^3 %RMB ; op, \ 37 RMB3 zp ------
:noname ^C %SEF ; op, \ 38 SEC --C---
:noname @ABSY %AND ; op, \ 39 AND llhh,Y NZ----
:noname @IMPLA %DEC ; op, \ 3A DEC A NZ----
:noname @IMPLA %NOP ; op, \ 3B NOP ------
:noname @ABSX %BIT ; op, \ 3C BIT llhh,X NZ---V
:noname @ABSX %AND ; op, \ 3D AND llhh,X NZ----
:noname @ABSX %ROL ; op, \ 3E ROL llhh,X NZC---
:noname @ZPREL ^3 %BBR ; op, \ 3F BBR3 zp,rr ------
:noname %RTI ; op, \ 40 RTI NZCIDV
:noname @ZPXI %EOR ; op, \ 41 EOR (zp,X) NZ----
:noname @ZPI %NOP ; op, \ 42 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ 43 NOP ------
:noname @ZP %NOP ; op, \ 44 NOP zp ------
:noname @ZP %EOR ; op, \ 45 EOR zp NZ----
:noname @ZP %LSR ; op, \ 46 LSR zp NZC---
:noname @ZP ^4 %RMB ; op, \ 47 RMB4 zp ------
:noname @IMPLA %PHT ; op, \ 48 PHA ------
:noname @IMM %EOR ; op, \ 49 EOR #dd NZ----
:noname @IMPLA %LSR ; op, \ 4A LSR A NZC---
:noname @IMPLA %NOP ; op, \ 4B NOP ------
:noname @ABS %JMP ; op, \ 4C JMP x16 ------
:noname @ABS %EOR ; op, \ 4D EOR llhh NZ----
:noname @ABS %LSR ; op, \ 4E LSR llhh NZC---
:noname @ZPREL ^4 %BBR ; op, \ 4F BBR4 zp,rr ------
:noname @REL ^V %BFC ; op, \ 50 BVC rr ------
:noname @ZPIY %EOR ; op, \ 51 EOR (zp),Y NZ----
:noname @ZPI %EOR ; op, \ 52 EOR (zp) NZ----
:noname @IMPLA %NOP ; op, \ 53 NOP ------
:noname @ZPX %NOP ; op, \ 54 NOP zp,X ------
:noname @ZPX %EOR ; op, \ 55 EOR zp,X NZ----
:noname @ZPX %LSR ; op, \ 56 LSR zp,X NZC---
:noname @ZP ^5 %RMB ; op, \ 57 RMB5 zp ------
:noname ^I %CLF ; op, \ 58 CLI ---I--
:noname @ABSY %EOR ; op, \ 59 EOR llhh,Y NZ----
:noname @IMPLY %PHT ; op, \ 5A PHY ------
:noname @IMPLA %NOP ; op, \ 5B NOP ------
:noname @ABSX %NOP ; op, \ 5C NOP llhh,X ------
:noname @ABSX %EOR ; op, \ 5D EOR llhh,X NZ----
:noname @ABSX %LSR ; op, \ 5E LSR llhh,X NZC---
:noname @ZPREL ^5 %BBR ; op, \ 5F BBR5 zp,rr ------
:noname %RTS ; op, \ 60 RTS ------
:noname @ZPXI %ADC ; op, \ 61 ADC (zp,X) NZC--V
:noname @ZPI %NOP ; op, \ 62 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ 63 NOP ------
:noname @ZP %STZ ; op, \ 64 STZ zp ------
:noname @ZP %ADC ; op, \ 65 ADC zp NZC--V
:noname @ZP %ROR ; op, \ 66 ROR zp NZC---
:noname @ZP ^6 %RMB ; op, \ 67 RMB6 zp ------
:noname @IMPLA %PLT ; op, \ 68 PLA NZ----
:noname @IMM %ADC ; op, \ 69 ADC #dd NZC--V
:noname @IMPLA %ROR ; op, \ 6A ROR A NZC---
:noname @IMPLA %NOP ; op, \ 6B NOP ------
:noname @ABSI %JMP ; op, \ 6C JMP (llhh) ------
:noname @ABS %ADC ; op, \ 6D ADC llhh NZC--V
:noname @ABS %ROR ; op, \ 6E ROR llhh NZC---
:noname @ZPREL ^6 %BBR ; op, \ 6F BBR6 zp,rr ------
:noname @REL ^V %BFS ; op, \ 70 BVS rr ------
:noname @ZPIY %ADC ; op, \ 71 ADC (zp),Y NZC--V
:noname @ZPI %ADC ; op, \ 72 ADC (zp) NZC--V
:noname @IMPLA %NOP ; op, \ 73 NOP ------
:noname @ZPX %STZ ; op, \ 74 STZ zp,X ------
:noname @ZPX %ADC ; op, \ 75 ADC zp,X NZC--V
:noname @ZPX %ROR ; op, \ 76 ROR zp,X NZC---
:noname @ZP ^7 %RMB ; op, \ 77 RMB7 zp ------
:noname ^I %SEF ; op, \ 78 SEI ---I--
:noname @ABSY %ADC ; op, \ 79 ADC llhh,Y NZC--V
:noname @IMPLY %PLT ; op, \ 7A PLY NZ----
:noname @IMPLA %NOP ; op, \ 7B NOP ------
:noname @ABSXI %JMP ; op, \ 7C JMP (llhh,X) ------
:noname @ABSX %ADC ; op, \ 7D ADC llhh,X NZC--V
:noname @ABSX %ROR ; op, \ 7E ROR llhh,X NZC---
:noname @ZPREL ^7 %BBR ; op, \ 7F BBR7 zp,rr ------
:noname @REL %JMP ; op, \ 80 BRA rr ------
:noname @ZPXI #A %STQ ; op, \ 81 STA (zp,X) ------
:noname @ZPI %NOP ; op, \ 82 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ 83 NOP ------
:noname @ZP #Y %STQ ; op, \ 84 STY zp ------
:noname @ZP #A %STQ ; op, \ 85 STA zp ------
:noname @ZP #X %STQ ; op, \ 86 STX zp ------
:noname @ZP ^0 %SMB ; op, \ 87 SMB0 zp ------
:noname @IMPLY %DEC ; op, \ 88 DEY NZ----
:noname @IMM %BIT' ; op, \ 89 BIT #dd -Z---- (special case)
:noname @IMPLX #A %LDQ ; op, \ 8A TXA NZ----
:noname @IMPLA %NOP ; op, \ 8B NOP ------
:noname @ABS #Y %STQ ; op, \ 8C STY llhh ------
:noname @ABS #A %STQ ; op, \ 8D STA llhh ------
:noname @ABS #X %STQ ; op, \ 8E STX llhh ------
:noname @ZPREL ^0 %BBS ; op, \ 8F BBS0 zp,rr ------
:noname @REL ^C %BFC ; op, \ 90 BCC rr ------
:noname @ZPIY #A %STQ ; op, \ 91 STA (zp),Y ------
:noname @ZPI #A %STQ ; op, \ 92 STA (zp) ------
:noname @IMPLA %NOP ; op, \ 93 NOP ------
:noname @ZPX #Y %STQ ; op, \ 94 STY zp,X ------
:noname @ZPX #A %STQ ; op, \ 95 STA zp,X ------
:noname @ZPY #X %STQ ; op, \ 96 STX zp,Y ------
:noname @ZP ^1 %SMB ; op, \ 97 SMB1 zp ------
:noname @IMPLY #A %LDQ ; op, \ 98 TYA NZ----
:noname @ABSY #A %STQ ; op, \ 99 STA llhh,Y ------
:noname %TXS ; op, \ 9A TXS ------
:noname @IMPLA %NOP ; op, \ 9B NOP ------
:noname @ABS %STZ ; op, \ 9C STZ llhh ------
:noname @ABSX #A %STQ ; op, \ 9D STA llhh,X ------
:noname @ABSX %STZ ; op, \ 9E STZ llhh,X ------
:noname @ZPREL ^1 %BBS ; op, \ 9F BBS1 zp,rr ------
:noname @IMM #Y %LDQ ; op, \ A0 LDY #dd NZ----
:noname @ZPXI #A %LDQ ; op, \ A1 LDA (zp,X) NZ----
:noname @IMM #X %LDQ ; op, \ A2 LDX #dd NZ----
:noname @IMPLA %NOP ; op, \ A3 NOP ------
:noname @ZP #Y %LDQ ; op, \ A4 LDY zp NZ----
:noname @ZP #A %LDQ ; op, \ A5 LDA zp NZ----
:noname @ZP #X %LDQ ; op, \ A6 LDX zp NZ----
:noname @ZP ^2 %SMB ; op, \ A7 SMB2 zp ------
:noname @IMPLA #Y %LDQ ; op, \ A8 TAY NZ----
:noname @IMM #A %LDQ ; op, \ A9 LDA #dd NZ----
:noname @IMPLA #X %LDQ ; op, \ AA TAX NZ----
:noname @IMPLA %NOP ; op, \ AB NOP ------
:noname @ABS #Y %LDQ ; op, \ AC LDY llhh NZ----
:noname @ABS #A %LDQ ; op, \ AD LDA llhh NZ----
:noname @ABS #X %LDQ ; op, \ AE LDX llhh NZ----
:noname @ZPREL ^2 %BBS ; op, \ AF BBS2 zp,rr ------
:noname @REL ^C %BFS ; op, \ B0 BCS rr ------
:noname @ZPIY #A %LDQ ; op, \ B1 LDA (zp),Y NZ----
:noname @ZPI #A %LDQ ; op, \ B2 LDA (zp) NZ----
:noname @IMPLA %NOP ; op, \ B3 NOP ------
:noname @ZPX #Y %LDQ ; op, \ B4 LDY zp,X NZ----
:noname @ZPX #A %LDQ ; op, \ B5 LDA zp,X NZ----
:noname @ZPY #X %LDQ ; op, \ B6 LDX zp,Y NZ----
:noname @ZP ^3 %SMB ; op, \ B7 SMB3 zp ------
:noname ^V %CLF ; op, \ B8 CLV -----V
:noname @ABSY #A %LDQ ; op, \ B9 LDA llhh,Y NZ----
:noname %TSX ; op, \ BA TSX NZ----
:noname @IMPLA %NOP ; op, \ BB NOP ------
:noname @ABSX #Y %LDQ ; op, \ BC LDY llhh,X NZ----
:noname @ABSX #A %LDQ ; op, \ BD LDA llhh,X NZ----
:noname @ABSY #X %LDQ ; op, \ BE LDX llhh,Y NZ----
:noname @ZPREL ^3 %BBS ; op, \ BF BBS3 zp,rr ------
:noname @IMM #Y %CPQ ; op, \ C0 CPY #dd NZC---
:noname @ZPXI #A %CPQ ; op, \ C1 CMP (zp,X) NZC---
:noname @ZPI %NOP ; op, \ C2 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ C3 NOP ------
:noname @ZP #Y %CPQ ; op, \ C4 CPY zp NZC---
:noname @ZP #A %CPQ ; op, \ C5 CMP zp NZC---
:noname @ZP %DEC ; op, \ C6 DEC zp NZ----
:noname @ZP ^4 %SMB ; op, \ C7 SMB4 zp ------
:noname @IMPLY %INC ; op, \ C8 INY NZ----
:noname @IMM #A %CPQ ; op, \ C9 CMP #dd NZC---
:noname @IMPLX %DEC ; op, \ CA DEX NZ----
:noname @IMPLA %NOP ; op, \ CB WAI ------ (not implemented)
:noname @ABS #Y %CPQ ; op, \ CC CPY llhh NZC---
:noname @ABS #A %CPQ ; op, \ CD CMP llhh NZC---
:noname @ABS %DEC ; op, \ CE DEC llhh NZ----
:noname @ZPREL ^4 %BBS ; op, \ CF BBS4 zp,rr ------
:noname @REL ^Z %BFC ; op, \ D0 BNE rr ------
:noname @ZPIY #A %CPQ ; op, \ D1 CMP (zp),Y NZC---
:noname @ZPI #A %CPQ ; op, \ D2 CMP (zp) NZC---
:noname @IMPLA %NOP ; op, \ D3 NOP ------
:noname @ZPX %NOP ; op, \ D4 NOP zp,X ------
:noname @ZPX #A %CPQ ; op, \ D5 CMP zp,X NZC---
:noname @ZPX %DEC ; op, \ D6 DEC zp,X NZ----
:noname @ZP ^5 %SMB ; op, \ D7 SMB5 zp ------
:noname ^D %CLF ; op, \ D8 CLD ----D-
:noname @ABSY #A %CPQ ; op, \ D9 CMP llhh,Y NZC---
:noname @IMPLX %PHT ; op, \ DA PHX ------
:noname @IMPLA %NOP ; op, \ DB STP ------ (not implemented)
:noname @ABS %NOP ; op, \ DC NOP llhh ------
:noname @ABSX #A %CPQ ; op, \ DD CMP llhh,X NZC---
:noname @ABSX %DEC ; op, \ DE DEC llhh,X NZ----
:noname @ZPREL ^5 %BBS ; op, \ DF BBS5 zp,rr ------
:noname @IMM #X %CPQ ; op, \ E0 CPX #dd NZC---
:noname @ZPXI %SBC ; op, \ E1 SBC (zp,X) NZC--V
:noname @ZPI %NOP ; op, \ E2 NOP (zp) ------
:noname @IMPLA %NOP ; op, \ E3 NOP ------
:noname @ZP #X %CPQ ; op, \ E4 CPX zp NZC---
:noname @ZP %SBC ; op, \ E5 SBC zp NZC--V
:noname @ZP %INC ; op, \ E6 INC zp NZ----
:noname @ZP ^6 %SMB ; op, \ E7 SMB6 zp ------
:noname @IMPLX %INC ; op, \ E8 INX NZ----
:noname @IMM %SBC ; op, \ E9 SBC #dd NZC--V
:noname @IMPLA %NOP ; op, \ EA NOP ------
:noname @IMPLA %NOP ; op, \ EB NOP ------
:noname @ABS #X %CPQ ; op, \ EC CPX llhh NZC---
:noname @ABS %SBC ; op, \ ED SBC llhh NZC--V
:noname @ABS %INC ; op, \ EE INC llhh NZ----
:noname @ZPREL ^6 %BBS ; op, \ EF BBS6 zp,rr ------
:noname @REL ^Z %BFS ; op, \ F0 BEQ rr ------
:noname @ZPIY %SBC ; op, \ F1 SBC (zp),Y NZC--V
:noname @ZPI %SBC ; op, \ F2 SBC (zp) NZC--V
:noname @IMPLA %NOP ; op, \ F3 NOP ------
:noname @ZPX %NOP ; op, \ F4 NOP zp,X ------
:noname @ZPX %SBC ; op, \ F5 SBC zp,X NZC--V
:noname @ZPX %INC ; op, \ F6 INC zp,X NZ----
:noname @ZP ^7 %SMB ; op, \ F7 SMB7 zp ------
:noname ^D %SEF ; op, \ F8 SED ----D-
:noname @ABSY %SBC ; op, \ F9 SBC llhh,Y NZC--V
:noname @IMPLX %PLT ; op, \ FA PLX NZ----
:noname @IMPLA %NOP ; op, \ FB NOP ------
:noname @ABS %NOP ; op, \ FC NOP llhh ------
:noname @ABSX %SBC ; op, \ FD SBC llhh,X NZC--V
:noname @ABSX %INC ; op, \ FE INC llhh,X NZ----
:noname @ZPREL ^7 %BBS ; op, \ FF BBS7 zp,rr ------
drop \ done with the OPS table pointer we've been incrementing
\ As a demo, let's emulate Tali's UM* which is position-independent
: demo ( -- )
\ Copy the code (including the RTS) to emulator address $400
\ The code is position-independent (no jumps) but there's
\ an initial bounds check JSR that we'll avoid below
['] um* DUP INT>NAME WORDSIZE 1+ ( xt u )
$400 &M SWAP MOVE
\ Initalize the emulator PC (skip stack check) and stack pointers
$403 >PC $fc >X $ff >S
\ Set up the multiplication by placing args on the emulator's data stack
2017 $fc &M ! 2027 $fe &M !
\ Emulate op codes until we see RTS
." emulating UM* code ... "
BEGIN op PC M $60 = UNTIL
\ Share the good news
." 2017 * 2027 = " X &M 2@ ud.
demo
