A 65C02 emulator in TaliForth
pdragon
Post by pdragon »
Emulate the 65C02 in a 65C02 forth, itself running on a 65C02 emulator of course... To illustrate it emulates the assembled version of its own UM* word, as well as passing a large suite of tests.
For some reverse-engineering I wanted some simple logic equations describing each opcode to reason about which registers or data locations were affected by a given instruction stream.
I realized Forth was a nice clean way to express (and test) that. I got slightly carried away and ended up writing this a full(*) emulator in TaliForth. (*) No decimal adc/sbc atm. I'm sure this kind of thing has been done before, so would appreciate any feedback on the approach. I'm more interested in simplicity than performance.
(edit: bugfix, bcd mode, P.)
\ 65c02 inception: emulate the 65c02 CPU with TaliForth running on a 65c02...
\ This is illustrated by emulating TaliForth's own assembly code for UM*
\ Also tested via https://github.com/SingleStepTests/ProcessorTests/tree/main/wdc65c02
\ Note:  STP and WAI are treated as NOP
\ Since TaliForth is running in a 64K memory space we restrict the emulator
\ memory to a smaller memory footprint by ignoring high address bits.
\ For example setting MBITS to 12 gives 2^12 = 4K bytes of emulator memory, with
\ four ignored address bits.  This means that there are 16 ways to address each
\ actual byte.  For testing we avoid tests that address the same actual location
\ with distinct 16 bit synonyms.  Also note that the BRK/IRQ vector at $fffe-f
\ will always map to the last two bytes of emulator memory.
12      constant MBITS      \ simulator memory is 1 << MBITS bytes, with upper address bits ignored
$FFFE   constant IRQBRK     \ maps to the last two emulator bytes since high bits are ignored
\ create emulator address mask and reserve its memory
1 MBITS lshift 1-       constant MMASK
here MMASK 1+ allot     constant MBASE
\ helper functions for reading and writing emulator memory
: &M    ( adr -- adr' ) MMASK AND MBASE + ;     \ emulator address to host address
: M     ( adr -- v )    &M C@ ;
: >M    ( adr v -- )    SWAP &M C! ;
\ We need to be careful with double byte access, since they need to wrap at
\ 8 or 16 bits.  So we can't just use @ to fetch two bytes since they aren't
\ always contiguous in memory.
: LSB   ( v -- byte )   $FF AND ;
: W>B   ( w -- lo hi )  DUP LSB SWAP 8 RSHIFT ;
: B>W   ( lo hi -- w )  8 LSHIFT OR ;
: MM    ( adr -- adr )  DUP M SWAP 1+ M B>W ;       \ read word from two bytes
: MMZ   ( zp -- adr )   DUP M SWAP 1+ LSB M B>W ;   \ read word from two bytes in ZP
\ Define the 16 bit program counter and some helpers
0 value PC
: >PC   ( adr -- )      TO PC ;
: PC+   ( -- adr )      PC PC 1+ >PC ;
: PC++  ( -- adr )      PC PC 1+ 1+ >PC ;
\ Reserve table of opcode XTs, with helpers to populate and emulate them
here $100 CELLS ALLOT constant OPS
: op,   ( p xt -- p' )  OVER ! 1+ 1+ ;      \ helper to write XT and inc slot
: op    ( -- )          PC+ M CELLS OPS + @  EXECUTE ;  \ emulate current opcode
\ Reserve register memory and set up access helpers
here 5 allot constant REGISTERS
0 constant #A
1 constant #X
2 constant #Y
3 constant #S               \ stack pointer (8 bit)
4 constant #P               \ flag register
\ use Q for generic register to avoid confusion with return stack words
: &Q    ( # -- adr )    REGISTERS + ;
: Q     ( # -- v )      &Q C@ ;
: Q!    ( v # -- )      &Q C! ;
: >Q    ( # v -- )      SWAP Q! ;
: A     ( -- v )    #A Q ;      : >A    ( v -- )    #A Q! ;
: X     ( -- v )    #X Q ;      : >X    ( v -- )    #X Q! ;
: Y     ( -- v )    #Y Q ;      : >Y    ( v -- )    #Y Q! ;
: S     ( -- v )    #S Q ;      : >S    ( v -- )    #S Q! ;
: P     ( -- v )    #P Q ;      : >P    ( v -- )    #P Q! ;
\ Stack management
: PUSH  ( v -- )        S $100 + SWAP >M  S 1- >S ;
: POP   ( -- v )        S 1+ >S  S $100 + M ;
\ push/pull address bytes individually since stack can wrap
: PUSH2 ( vv -- )       W>B PUSH PUSH ;
: POP2  ( -- vv )       POP POP B>W ;
\ Flag bits
%00000001 dup   constant ^0 constant ^C     \ Carry
%00000010 dup   constant ^1 constant ^Z     \ Zero
%00000100 dup   constant ^2 constant ^I     \ Interrupt
%00001000 dup   constant ^3 constant ^D     \ Decimal
%00010000 dup   constant ^4 constant ^B     \ Break
%00100000 dup   constant ^5 constant ^G     \ Ignored (always set)
%01000000 dup   constant ^6 constant ^V     \ Overflow
%10000000 dup   constant ^7 constant ^N     \ Negative
s" NV1BDIZC" drop constant FLAGS
: BIT?  ( v mask -- f )  AND 0<> ;          \ test if bit number is set
\ helpers to set or query flags
: F>P   ( f mask -- )   DUP INVERT P AND -ROT AND OR >P ;   \ set or clear bit number based on flag
: >Z    ( v -- )        0=      ^Z F>P ;        \ set Z by testing value for zero
: >N    ( v -- )        ^7 BIT? ^N F>P ;        \ set N by testing sign of value
: >Z>N> ( v -- v )      DUP >Z DUP >N ;         \ shortcut for both, keeping value
: >C    ( f -- )        ^C F>P ;                \ set other flags with true/false
: >V    ( f -- )        ^V F>P ;
: C?    ( -- f )        P ^C BIT? ;             \ carry flag as true/false
: D?    ( -- f )        P ^D BIT? ;
: P.    ( -- )          8 0 DO ( adr ) P ^N I RSHIFT BIT? IF FLAGS I + C@ ELSE [CHAR] - THEN EMIT LOOP ;
\ define T and >T so generic instructions can operate on either register or memory
DEFER &T    ( adr -- adr' )
: T     ( adr -- v )    &T C@ ;
: >T    ( adr v -- )    SWAP &T C! ;
: T:M   ( -- )          ['] &M IS &T ;  \ target memory
: T:Q   ( -- )          ['] &Q IS &T ;  \ target register
: SEXT  ( rel -- v )    DUP ^7 BIT? $ff00 AND OR ;  \ sign extend an 8-bit value
\ addressing modes that target a memory location or register index
: @IMPLA ( -- r )   #A                                  T:Q ;   \ implied A
: @IMPLX ( -- r )   #X                                  T:Q ;   \ implied X
: @IMPLY ( -- r )   #Y                                  T:Q ;   \ implied Y
: @IMM   ( -- adr ) PC+                                 T:M ;   \ #dd
: @ZP    ( -- adr ) PC+     M                           T:M ;   \ zp
: @ZPX   ( -- adr ) PC+     M       X + LSB             T:M ;   \ zp,X
: @ZPY   ( -- adr ) PC+     M       Y + LSB             T:M ;   \ zp,Y
: @ZPI   ( -- adr ) PC+     M                 MMZ       T:M ;   \ (zp)
: @ZPXI  ( -- adr ) PC+     M       X + LSB   MMZ       T:M ;   \ (zp,X)
: @ZPIY  ( -- adr ) PC+     M                 MMZ   Y + T:M ;   \ (zp),Y
: @ABS   ( -- adr ) PC++    MM                          T:M ;   \ llhh
: @ABSX  ( -- adr ) PC++    MM                      X + T:M ;   \ llhh,X
: @ABSY  ( -- adr ) PC++    MM                      Y + T:M ;   \ llhh,Y
: @ABSI  ( -- adr ) PC++    MM                MM        T:M ;   \ (llhh)
: @ABSXI ( -- adr ) PC++    MM      X +       MM        T:M ;   \ (llhh,X)
: @REL   ( -- adr ) PC+     M  SEXT PC +                T:M ;   \ rr
: @ZPREL ( -- a a ) PC+     M  @REL                     T:M ;   \ zp,rr
\ opcode implementations that act on a register or memory location
: %STQ  ( adr r# -- )   Q >T ;
: %STZ  ( adr -- )      0 >T ;
: %LDQ  ( adr #r -- )   SWAP T >Z>N> >Q ;
\ most transfers are expressed as load from implied register with special case for S
: %TSX  ( -- )          S  >Z>N>  >X ;
: %TXS  ( -- )          X  >S ; \ NB no flags are affected
: %INC  ( adr -- )      DUP T 1+ LSB  >Z>N>  >T ;
: %DEC  ( adr -- )      DUP T 1- LSB  >Z>N>  >T ;
: %ORA  ( adr -- )      T A OR   >Z>N>  >A ;
: %AND  ( adr -- )      T A AND  >Z>N>  >A ;
: %EOR  ( adr -- )      T A XOR  >Z>N>  >A ;
: %SMB  ( adr bit -- )  OVER T OR >T ;
: %RMB  ( adr bit -- )  INVERT OVER T AND >T ;
: %BIT  ( adr -- )      T DUP A AND >Z DUP >N ^6 BIT? >V   ;
\ BIT #dd is a special case where only Z is updated
: %BIT' ( adr -- )      T A AND >Z ;
: %TRB  ( adr -- )      DUP T A 2DUP AND >Z INVERT AND >T ;
: %TSB  ( adr -- )      DUP T A 2DUP AND >Z OR >T ;
: %LSR  ( adr -- )      DUP T DUP ^0 BIT? >C 2/      >Z>N>  >T ;
: %ASL  ( adr -- )      DUP T DUP ^7 BIT? >C 2* LSB  >Z>N>  >T ;
: %ROR  ( adr -- )      C? ^7 AND OVER T DUP ^0 BIT? >C 2/ OR      >Z>N>  >T ;
: %ROL  ( adr -- )      C? ^0 AND OVER T DUP ^7 BIT? >C 2* OR LSB  >Z>N>  >T ;
: %CPQ  ( adr #r -- )   Q SWAP T - >Z>N> 0< INVERT >C ;
\ Use XOR trick for add/subtract to infer the carry bits from the sum S
\ Start with S = A^M^CS so CS = S^A^M and we can calculate the 6502 flags
\ via C = C8 (the addition has a carry if carry out of bit 7 is set)
\ and V = C8^C7 (overflow if the carries in and out of bit 7 differ)
: A+    ( v -- v )
    A 2DUP XOR -ROT
    ( A^B  B  A )
    + C? -              \ calculate S=A+B+C, noting C? is true == -1 when set
    TUCK XOR            \ calculate A^B^S to get C and V flags
    ( S  A^B^S )
    DUP $100 BIT? DUP >C SWAP ^7 BIT? XOR >V
    ( S )
    LSB  >Z>N>          \ set Z and N leaving byte result
: B>HL   ( v -- hi lo )  DUP $F0 AND SWAP $F AND ;
\ BCD flags for addition and subtraction are a mess
\ this implements 65c02 behavior per http://www.6502.org/tutorials/decimal_mode.html#B
\ for V flag we use twos complement addition in seg 2C but note that
\ sign extending a byte with bit 7 set effectively subtracts $100.
\ so we can correct the signed result back to unsigned by tracking which bytes with negative
: ABCD+  ( b -- s )
    B>HL A B>HL ( bh bl ah al ) ROT + C? -              \ seq 2A
    DUP 9 > IF $6 + $F AND $10 OR THEN ( bh ah sl )     \ seq 2B
    \ sign extend bh, ah as bh', ah' tracking unsigned correction cb, ca each 0 or $100
    -ROT SEXT DUP $100 AND ROT SEXT DUP $100 AND ( sl ah' ca bh' cb )
    ROT + -ROT + ROT + ( cc s' )                        \ seq 2C (signed result with correction)
    DUP $80 + $FF00 BIT? >V                             \ seq 2F
    + DUP $9F > $60 AND + ( s )                         \ seq 1E (correct back to unsigned)
    DUP $FF00 BIT? >C                                   \ seq 1G
    LSB  >Z>N>
\ For subtraction, use binary difference to set C and V, then find the actual BCD difference
: ABCD- ( b -- s )
    C? INVERT >R DUP INVERT A+ DROP  ( b R: 1-c )       \ set C and V, saving original carry
    A $F AND OVER $F AND - R@ + ( b sl R: 1-c )         \ seq 4A
    A ROT - R> +  ( sl s )                              \ seq 4B
    DUP 0< $60 AND -                                    \ seq 4C
    SWAP 0< 6 AND -                                     \ seq 4D
    LSB  >Z>N>
: %ADC  ( adr -- )      T D? IF ABCD+ ELSE A+ THEN >A ;
\ Reframe subtraction as an addition using twos complement:
\   -M = 256 - M = 1 + 255 - M = 1 + ~M  where ~M is the inverse of M
\ Since borrow = 1 - carry we get:
\   A - M - borrow = A + ~M + 1 - borrow = A + ~M + C
: %SBC  ( adr -- )      T D? IF ABCD- ELSE INVERT A+ THEN >A ;
: %PHT  ( r -- )        T PUSH ;
: %PLT  ( r -- )        POP >Z>N> >T ;
\ the status register has special behavior
: %PHP  ( -- )          P ^B OR PUSH ;                  \ set BRK
: %PLP  ( -- )          POP ^G OR ^B INVERT AND >P ;    \ set IGN clr BRK
: %CLF  ( mask -- )     FALSE SWAP F>P ;
: %SEF  ( mask -- )     TRUE  SWAP F>P ;
: %JMP  ( adr -- )      >PC ;
: %JSR  ( adr -- )      PC 1- PUSH2 >PC ;
: %RTS  ( -- )          POP2 1+ >PC ;
: %RTI  ( -- )          %PLP POP2 >PC ;
: %BRK  ( adr -- )      DROP PC PUSH2 %PHP ^I %SEF ^D %CLF IRQBRK MM >PC ;
: ?JMP  ( adr f -- )    IF >PC ELSE DROP THEN ;
: %BFS  ( adr mask -- ) P AND    ?JMP ;
: %BFC  ( adr mask -- ) P AND 0= ?JMP ;
: %BBR  ( adr dst bit -- )  ROT T AND 0= ?JMP ;
: %BBS  ( adr dst bit -- )  ROT T AND    ?JMP ;
: %NOP  ( adr -- )      DROP ;          \ Support variable length NOPs
\ Build the opcode table, usually pairing a memory mode with an operator
OPS
:noname     @IMM        %BRK    ; op,   \ 00 BRK            ---I--
:noname     @ZPXI       %ORA    ; op,   \ 01 ORA (zp,X)     NZ----
:noname     @ZPI        %NOP    ; op,   \ 02 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 03 NOP            ------
:noname     @ZP         %TSB    ; op,   \ 04 TSB zp         -Z----
:noname     @ZP         %ORA    ; op,   \ 05 ORA zp         NZ----
:noname     @ZP         %ASL    ; op,   \ 06 ASL zp         NZC---
:noname     @ZP     ^0  %RMB    ; op,   \ 07 RMB0 zp        ------
:noname                 %PHP    ; op,   \ 08 PHP            ------
:noname     @IMM        %ORA    ; op,   \ 09 ORA #dd        NZ----
:noname     @IMPLA      %ASL    ; op,   \ 0A ASL A          NZC---
:noname     @IMPLA      %NOP    ; op,   \ 0B NOP            ------
:noname     @ABS        %TSB    ; op,   \ 0C TSB llhh       -Z----
:noname     @ABS        %ORA    ; op,   \ 0D ORA llhh       NZ----
:noname     @ABS        %ASL    ; op,   \ 0E ASL llhh       NZC---
:noname     @ZPREL  ^0  %BBR    ; op,   \ 0F BBR0 zp,rr     ------
:noname     @REL    ^N  %BFC    ; op,   \ 10 BPL rr         ------
:noname     @ZPIY       %ORA    ; op,   \ 11 ORA (zp),Y     NZ----
:noname     @ZPI        %ORA    ; op,   \ 12 ORA (zp)       NZ----
:noname     @IMPLA      %NOP    ; op,   \ 13 NOP            ------
:noname     @ZP         %TRB    ; op,   \ 14 TRB zp         -Z----
:noname     @ZPX        %ORA    ; op,   \ 15 ORA zp,X       NZ----
:noname     @ZPX        %ASL    ; op,   \ 16 ASL zp,X       NZC---
:noname     @ZP     ^1  %RMB    ; op,   \ 17 RMB1 zp        ------
:noname             ^C  %CLF    ; op,   \ 18 CLC            --C---
:noname     @ABSY       %ORA    ; op,   \ 19 ORA llhh,Y     NZ----
:noname     @IMPLA      %INC    ; op,   \ 1A INC A          NZ----
:noname     @IMPLA      %NOP    ; op,   \ 1B NOP            ------
:noname     @ABS        %TRB    ; op,   \ 1C TRB llhh       -Z----
:noname     @ABSX       %ORA    ; op,   \ 1D ORA llhh,X     NZ----
:noname     @ABSX       %ASL    ; op,   \ 1E ASL llhh,X     NZC---
:noname     @ZPREL  ^1  %BBR    ; op,   \ 1F BBR1 zp,rr     ------
:noname     @ABS        %JSR    ; op,   \ 20 JSR x16        ------
:noname     @ZPXI       %AND    ; op,   \ 21 AND (zp,X)     NZ----
:noname     @ZPI        %NOP    ; op,   \ 22 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 23 NOP            ------
:noname     @ZP         %BIT    ; op,   \ 24 BIT zp         NZ---V
:noname     @ZP         %AND    ; op,   \ 25 AND zp         NZ----
:noname     @ZP         %ROL    ; op,   \ 26 ROL zp         NZC---
:noname     @ZP     ^2  %RMB    ; op,   \ 27 RMB2 zp        ------
:noname                 %PLP    ; op,   \ 28 PLP            NZCIDV
:noname     @IMM        %AND    ; op,   \ 29 AND #dd        NZ----
:noname     @IMPLA      %ROL    ; op,   \ 2A ROL A          NZC---
:noname     @IMPLA      %NOP    ; op,   \ 2B NOP            ------
:noname     @ABS        %BIT    ; op,   \ 2C BIT llhh       NZ---V
:noname     @ABS        %AND    ; op,   \ 2D AND llhh       NZ----
:noname     @ABS        %ROL    ; op,   \ 2E ROL llhh       NZC---
:noname     @ZPREL  ^2  %BBR    ; op,   \ 2F BBR2 zp,rr     ------
:noname     @REL    ^N  %BFS    ; op,   \ 30 BMI rr         ------
:noname     @ZPIY       %AND    ; op,   \ 31 AND (zp),Y     NZ----
:noname     @ZPI        %AND    ; op,   \ 32 AND (zp)       NZ----
:noname     @IMPLA      %NOP    ; op,   \ 33 NOP            ------
:noname     @ZPX        %BIT    ; op,   \ 34 BIT zp,X       NZ---V
:noname     @ZPX        %AND    ; op,   \ 35 AND zp,X       NZ----
:noname     @ZPX        %ROL    ; op,   \ 36 ROL zp,X       NZC---
:noname     @ZP     ^3  %RMB    ; op,   \ 37 RMB3 zp        ------
:noname             ^C  %SEF    ; op,   \ 38 SEC            --C---
:noname     @ABSY       %AND    ; op,   \ 39 AND llhh,Y     NZ----
:noname     @IMPLA      %DEC    ; op,   \ 3A DEC A          NZ----
:noname     @IMPLA      %NOP    ; op,   \ 3B NOP            ------
:noname     @ABSX       %BIT    ; op,   \ 3C BIT llhh,X     NZ---V
:noname     @ABSX       %AND    ; op,   \ 3D AND llhh,X     NZ----
:noname     @ABSX       %ROL    ; op,   \ 3E ROL llhh,X     NZC---
:noname     @ZPREL  ^3  %BBR    ; op,   \ 3F BBR3 zp,rr     ------
:noname                 %RTI    ; op,   \ 40 RTI            NZCIDV
:noname     @ZPXI       %EOR    ; op,   \ 41 EOR (zp,X)     NZ----
:noname     @ZPI        %NOP    ; op,   \ 42 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 43 NOP            ------
:noname     @ZP         %NOP    ; op,   \ 44 NOP zp         ------
:noname     @ZP         %EOR    ; op,   \ 45 EOR zp         NZ----
:noname     @ZP         %LSR    ; op,   \ 46 LSR zp         NZC---
:noname     @ZP     ^4  %RMB    ; op,   \ 47 RMB4 zp        ------
:noname     @IMPLA      %PHT    ; op,   \ 48 PHA            ------
:noname     @IMM        %EOR    ; op,   \ 49 EOR #dd        NZ----
:noname     @IMPLA      %LSR    ; op,   \ 4A LSR A          NZC---
:noname     @IMPLA      %NOP    ; op,   \ 4B NOP            ------
:noname     @ABS        %JMP    ; op,   \ 4C JMP x16        ------
:noname     @ABS        %EOR    ; op,   \ 4D EOR llhh       NZ----
:noname     @ABS        %LSR    ; op,   \ 4E LSR llhh       NZC---
:noname     @ZPREL  ^4  %BBR    ; op,   \ 4F BBR4 zp,rr     ------
:noname     @REL    ^V  %BFC    ; op,   \ 50 BVC rr         ------
:noname     @ZPIY       %EOR    ; op,   \ 51 EOR (zp),Y     NZ----
:noname     @ZPI        %EOR    ; op,   \ 52 EOR (zp)       NZ----
:noname     @IMPLA      %NOP    ; op,   \ 53 NOP            ------
:noname     @ZPX        %NOP    ; op,   \ 54 NOP zp,X       ------
:noname     @ZPX        %EOR    ; op,   \ 55 EOR zp,X       NZ----
:noname     @ZPX        %LSR    ; op,   \ 56 LSR zp,X       NZC---
:noname     @ZP     ^5  %RMB    ; op,   \ 57 RMB5 zp        ------
:noname             ^I  %CLF    ; op,   \ 58 CLI            ---I--
:noname     @ABSY       %EOR    ; op,   \ 59 EOR llhh,Y     NZ----
:noname     @IMPLY      %PHT    ; op,   \ 5A PHY            ------
:noname     @IMPLA      %NOP    ; op,   \ 5B NOP            ------
:noname     @ABSX       %NOP    ; op,   \ 5C NOP llhh,X     ------
:noname     @ABSX       %EOR    ; op,   \ 5D EOR llhh,X     NZ----
:noname     @ABSX       %LSR    ; op,   \ 5E LSR llhh,X     NZC---
:noname     @ZPREL  ^5  %BBR    ; op,   \ 5F BBR5 zp,rr     ------
:noname                 %RTS    ; op,   \ 60 RTS            ------
:noname     @ZPXI       %ADC    ; op,   \ 61 ADC (zp,X)     NZC--V
:noname     @ZPI        %NOP    ; op,   \ 62 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 63 NOP            ------
:noname     @ZP         %STZ    ; op,   \ 64 STZ zp         ------
:noname     @ZP         %ADC    ; op,   \ 65 ADC zp         NZC--V
:noname     @ZP         %ROR    ; op,   \ 66 ROR zp         NZC---
:noname     @ZP     ^6  %RMB    ; op,   \ 67 RMB6 zp        ------
:noname     @IMPLA      %PLT    ; op,   \ 68 PLA            NZ----
:noname     @IMM        %ADC    ; op,   \ 69 ADC #dd        NZC--V
:noname     @IMPLA      %ROR    ; op,   \ 6A ROR A          NZC---
:noname     @IMPLA      %NOP    ; op,   \ 6B NOP            ------
:noname     @ABSI       %JMP    ; op,   \ 6C JMP (llhh)     ------
:noname     @ABS        %ADC    ; op,   \ 6D ADC llhh       NZC--V
:noname     @ABS        %ROR    ; op,   \ 6E ROR llhh       NZC---
:noname     @ZPREL  ^6  %BBR    ; op,   \ 6F BBR6 zp,rr     ------
:noname     @REL    ^V  %BFS    ; op,   \ 70 BVS rr         ------
:noname     @ZPIY       %ADC    ; op,   \ 71 ADC (zp),Y     NZC--V
:noname     @ZPI        %ADC    ; op,   \ 72 ADC (zp)       NZC--V
:noname     @IMPLA      %NOP    ; op,   \ 73 NOP            ------
:noname     @ZPX        %STZ    ; op,   \ 74 STZ zp,X       ------
:noname     @ZPX        %ADC    ; op,   \ 75 ADC zp,X       NZC--V
:noname     @ZPX        %ROR    ; op,   \ 76 ROR zp,X       NZC---
:noname     @ZP     ^7  %RMB    ; op,   \ 77 RMB7 zp        ------
:noname             ^I  %SEF    ; op,   \ 78 SEI            ---I--
:noname     @ABSY       %ADC    ; op,   \ 79 ADC llhh,Y     NZC--V
:noname     @IMPLY      %PLT    ; op,   \ 7A PLY            NZ----
:noname     @IMPLA      %NOP    ; op,   \ 7B NOP            ------
:noname     @ABSXI      %JMP    ; op,   \ 7C JMP (llhh,X)   ------
:noname     @ABSX       %ADC    ; op,   \ 7D ADC llhh,X     NZC--V
:noname     @ABSX       %ROR    ; op,   \ 7E ROR llhh,X     NZC---
:noname     @ZPREL  ^7  %BBR    ; op,   \ 7F BBR7 zp,rr     ------
:noname     @REL        %JMP    ; op,   \ 80 BRA rr         ------
:noname     @ZPXI   #A  %STQ    ; op,   \ 81 STA (zp,X)     ------
:noname     @ZPI        %NOP    ; op,   \ 82 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 83 NOP            ------
:noname     @ZP     #Y  %STQ    ; op,   \ 84 STY zp         ------
:noname     @ZP     #A  %STQ    ; op,   \ 85 STA zp         ------
:noname     @ZP     #X  %STQ    ; op,   \ 86 STX zp         ------
:noname     @ZP     ^0  %SMB    ; op,   \ 87 SMB0 zp        ------
:noname     @IMPLY      %DEC    ; op,   \ 88 DEY            NZ----
:noname     @IMM        %BIT'   ; op,   \ 89 BIT #dd        -Z----  (special case)
:noname     @IMPLX  #A  %LDQ    ; op,   \ 8A TXA            NZ----
:noname     @IMPLA      %NOP    ; op,   \ 8B NOP            ------
:noname     @ABS    #Y  %STQ    ; op,   \ 8C STY llhh       ------
:noname     @ABS    #A  %STQ    ; op,   \ 8D STA llhh       ------
:noname     @ABS    #X  %STQ    ; op,   \ 8E STX llhh       ------
:noname     @ZPREL  ^0  %BBS    ; op,   \ 8F BBS0 zp,rr     ------
:noname     @REL    ^C  %BFC    ; op,   \ 90 BCC rr         ------
:noname     @ZPIY   #A  %STQ    ; op,   \ 91 STA (zp),Y     ------
:noname     @ZPI    #A  %STQ    ; op,   \ 92 STA (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ 93 NOP            ------
:noname     @ZPX    #Y  %STQ    ; op,   \ 94 STY zp,X       ------
:noname     @ZPX    #A  %STQ    ; op,   \ 95 STA zp,X       ------
:noname     @ZPY    #X  %STQ    ; op,   \ 96 STX zp,Y       ------
:noname     @ZP     ^1  %SMB    ; op,   \ 97 SMB1 zp        ------
:noname     @IMPLY  #A  %LDQ    ; op,   \ 98 TYA            NZ----
:noname     @ABSY   #A  %STQ    ; op,   \ 99 STA llhh,Y     ------
:noname                 %TXS    ; op,   \ 9A TXS            ------
:noname     @IMPLA      %NOP    ; op,   \ 9B NOP            ------
:noname     @ABS        %STZ    ; op,   \ 9C STZ llhh       ------
:noname     @ABSX   #A  %STQ    ; op,   \ 9D STA llhh,X     ------
:noname     @ABSX       %STZ    ; op,   \ 9E STZ llhh,X     ------
:noname     @ZPREL  ^1  %BBS    ; op,   \ 9F BBS1 zp,rr     ------
:noname     @IMM    #Y  %LDQ    ; op,   \ A0 LDY #dd        NZ----
:noname     @ZPXI   #A  %LDQ    ; op,   \ A1 LDA (zp,X)     NZ----
:noname     @IMM    #X  %LDQ    ; op,   \ A2 LDX #dd        NZ----
:noname     @IMPLA      %NOP    ; op,   \ A3 NOP            ------
:noname     @ZP     #Y  %LDQ    ; op,   \ A4 LDY zp         NZ----
:noname     @ZP     #A  %LDQ    ; op,   \ A5 LDA zp         NZ----
:noname     @ZP     #X  %LDQ    ; op,   \ A6 LDX zp         NZ----
:noname     @ZP     ^2  %SMB    ; op,   \ A7 SMB2 zp        ------
:noname     @IMPLA  #Y  %LDQ    ; op,   \ A8 TAY            NZ----
:noname     @IMM    #A  %LDQ    ; op,   \ A9 LDA #dd        NZ----
:noname     @IMPLA  #X  %LDQ    ; op,   \ AA TAX            NZ----
:noname     @IMPLA      %NOP    ; op,   \ AB NOP            ------
:noname     @ABS    #Y  %LDQ    ; op,   \ AC LDY llhh       NZ----
:noname     @ABS    #A  %LDQ    ; op,   \ AD LDA llhh       NZ----
:noname     @ABS    #X  %LDQ    ; op,   \ AE LDX llhh       NZ----
:noname     @ZPREL  ^2  %BBS    ; op,   \ AF BBS2 zp,rr     ------
:noname     @REL    ^C  %BFS    ; op,   \ B0 BCS rr         ------
:noname     @ZPIY   #A  %LDQ    ; op,   \ B1 LDA (zp),Y     NZ----
:noname     @ZPI    #A  %LDQ    ; op,   \ B2 LDA (zp)       NZ----
:noname     @IMPLA      %NOP    ; op,   \ B3 NOP            ------
:noname     @ZPX    #Y  %LDQ    ; op,   \ B4 LDY zp,X       NZ----
:noname     @ZPX    #A  %LDQ    ; op,   \ B5 LDA zp,X       NZ----
:noname     @ZPY    #X  %LDQ    ; op,   \ B6 LDX zp,Y       NZ----
:noname     @ZP     ^3  %SMB    ; op,   \ B7 SMB3 zp        ------
:noname             ^V  %CLF    ; op,   \ B8 CLV            -----V
:noname     @ABSY   #A  %LDQ    ; op,   \ B9 LDA llhh,Y     NZ----
:noname                 %TSX    ; op,   \ BA TSX            NZ----
:noname     @IMPLA      %NOP    ; op,   \ BB NOP            ------
:noname     @ABSX   #Y  %LDQ    ; op,   \ BC LDY llhh,X     NZ----
:noname     @ABSX   #A  %LDQ    ; op,   \ BD LDA llhh,X     NZ----
:noname     @ABSY   #X  %LDQ    ; op,   \ BE LDX llhh,Y     NZ----
:noname     @ZPREL  ^3  %BBS    ; op,   \ BF BBS3 zp,rr     ------
:noname     @IMM    #Y  %CPQ    ; op,   \ C0 CPY #dd        NZC---
:noname     @ZPXI   #A  %CPQ    ; op,   \ C1 CMP (zp,X)     NZC---
:noname     @ZPI        %NOP    ; op,   \ C2 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ C3 NOP            ------
:noname     @ZP     #Y  %CPQ    ; op,   \ C4 CPY zp         NZC---
:noname     @ZP     #A  %CPQ    ; op,   \ C5 CMP zp         NZC---
:noname     @ZP         %DEC    ; op,   \ C6 DEC zp         NZ----
:noname     @ZP     ^4  %SMB    ; op,   \ C7 SMB4 zp        ------
:noname     @IMPLY      %INC    ; op,   \ C8 INY            NZ----
:noname     @IMM    #A  %CPQ    ; op,   \ C9 CMP #dd        NZC---
:noname     @IMPLX      %DEC    ; op,   \ CA DEX            NZ----
:noname     @IMPLA      %NOP    ; op,   \ CB WAI            ------  (not implemented)
:noname     @ABS    #Y  %CPQ    ; op,   \ CC CPY llhh       NZC---
:noname     @ABS    #A  %CPQ    ; op,   \ CD CMP llhh       NZC---
:noname     @ABS        %DEC    ; op,   \ CE DEC llhh       NZ----
:noname     @ZPREL  ^4  %BBS    ; op,   \ CF BBS4 zp,rr     ------
:noname     @REL    ^Z  %BFC    ; op,   \ D0 BNE rr         ------
:noname     @ZPIY   #A  %CPQ    ; op,   \ D1 CMP (zp),Y     NZC---
:noname     @ZPI    #A  %CPQ    ; op,   \ D2 CMP (zp)       NZC---
:noname     @IMPLA      %NOP    ; op,   \ D3 NOP            ------
:noname     @ZPX        %NOP    ; op,   \ D4 NOP zp,X       ------
:noname     @ZPX    #A  %CPQ    ; op,   \ D5 CMP zp,X       NZC---
:noname     @ZPX        %DEC    ; op,   \ D6 DEC zp,X       NZ----
:noname     @ZP     ^5  %SMB    ; op,   \ D7 SMB5 zp        ------
:noname             ^D  %CLF    ; op,   \ D8 CLD            ----D-
:noname     @ABSY   #A  %CPQ    ; op,   \ D9 CMP llhh,Y     NZC---
:noname     @IMPLX      %PHT    ; op,   \ DA PHX            ------
:noname     @IMPLA      %NOP    ; op,   \ DB STP            ------  (not implemented)
:noname     @ABS        %NOP    ; op,   \ DC NOP llhh       ------
:noname     @ABSX   #A  %CPQ    ; op,   \ DD CMP llhh,X     NZC---
:noname     @ABSX       %DEC    ; op,   \ DE DEC llhh,X     NZ----
:noname     @ZPREL  ^5  %BBS    ; op,   \ DF BBS5 zp,rr     ------
:noname     @IMM    #X  %CPQ    ; op,   \ E0 CPX #dd        NZC---
:noname     @ZPXI       %SBC    ; op,   \ E1 SBC (zp,X)     NZC--V
:noname     @ZPI        %NOP    ; op,   \ E2 NOP (zp)       ------
:noname     @IMPLA      %NOP    ; op,   \ E3 NOP            ------
:noname     @ZP     #X  %CPQ    ; op,   \ E4 CPX zp         NZC---
:noname     @ZP         %SBC    ; op,   \ E5 SBC zp         NZC--V
:noname     @ZP         %INC    ; op,   \ E6 INC zp         NZ----
:noname     @ZP     ^6  %SMB    ; op,   \ E7 SMB6 zp        ------
:noname     @IMPLX      %INC    ; op,   \ E8 INX            NZ----
:noname     @IMM        %SBC    ; op,   \ E9 SBC #dd        NZC--V
:noname     @IMPLA      %NOP    ; op,   \ EA NOP            ------
:noname     @IMPLA      %NOP    ; op,   \ EB NOP            ------
:noname     @ABS    #X  %CPQ    ; op,   \ EC CPX llhh       NZC---
:noname     @ABS        %SBC    ; op,   \ ED SBC llhh       NZC--V
:noname     @ABS        %INC    ; op,   \ EE INC llhh       NZ----
:noname     @ZPREL  ^6  %BBS    ; op,   \ EF BBS6 zp,rr     ------
:noname     @REL    ^Z  %BFS    ; op,   \ F0 BEQ rr         ------
:noname     @ZPIY       %SBC    ; op,   \ F1 SBC (zp),Y     NZC--V
:noname     @ZPI        %SBC    ; op,   \ F2 SBC (zp)       NZC--V
:noname     @IMPLA      %NOP    ; op,   \ F3 NOP            ------
:noname     @ZPX        %NOP    ; op,   \ F4 NOP zp,X       ------
:noname     @ZPX        %SBC    ; op,   \ F5 SBC zp,X       NZC--V
:noname     @ZPX        %INC    ; op,   \ F6 INC zp,X       NZ----
:noname     @ZP     ^7  %SMB    ; op,   \ F7 SMB7 zp        ------
:noname             ^D  %SEF    ; op,   \ F8 SED            ----D-
:noname     @ABSY       %SBC    ; op,   \ F9 SBC llhh,Y     NZC--V
:noname     @IMPLX      %PLT    ; op,   \ FA PLX            NZ----
:noname     @IMPLA      %NOP    ; op,   \ FB NOP            ------
:noname     @ABS        %NOP    ; op,   \ FC NOP llhh       ------
:noname     @ABSX       %SBC    ; op,   \ FD SBC llhh,X     NZC--V
:noname     @ABSX       %INC    ; op,   \ FE INC llhh,X     NZ----
:noname     @ZPREL  ^7  %BBS    ; op,   \ FF BBS7 zp,rr     ------
drop    \ done with the OPS table pointer we've been incrementing
\ As a demo, let's emulate Tali's UM* which is position-independent
: demo ( -- )
    \ Copy the code (including the RTS) to emulator address $400
    \ The code is position-independent (no jumps) but there's
    \ an initial bounds check JSR that we'll avoid below
    ['] um* DUP INT>NAME WORDSIZE 1+ ( xt u )
    $400 &M SWAP MOVE
    \ Initalize the emulator PC (skip stack check) and stack pointers
    $403 >PC  $fc >X  $ff >S
    \ Set up the multiplication by placing args on the emulator's data stack
    2017 $fc &M !  2027 $fe &M !
    \ Emulate op codes until we see RTS
    ." emulating UM* code ... "
    BEGIN op PC M $60 = UNTIL
    \ Share the good news
    ." 2017 * 2027 = " X &M 2@ ud.
demo
Re: A 65C02 emulator in TaliForth
Marvellous! Have you tried running Klaus Dormann's test suite?
pdragon
Post by pdragon »
Not yet, just the randomized tests for all wdc opcodes I linked above. That's a good thought tho, might need to implement decimal mode and take a stab at it.
Ah yes, decimal mode - something of an optional mode, for me, although of course one includes it for completeness.
SamCoVT
Post by SamCoVT »
That's pretty slick. I like the way you just run op to single step. I was able to modify the loop to print out the current PC with PC . and it looks pretty easy to print out the other items.
Out of curiosity, I wondered if you can use Tali's disassembler to print out the opcodes, and you can with the following change to the loop:
    BEGIN op   PC &M 1 DISASM   PC M $60 = UNTIL
The 1 before DISASM tells it to disassemble one byte.
The result looks like this:
3120        clc
3121      0 sbc.#
3123     37 sta.z
3125      1 lda.zx
3127      0 sbc.#
3129     63 bcc     3194 v
3131     38 sta.z
3133      0 lda.#
3171        inx
3172     39 cpx.z
3174    221 bne     3141 ^
3176      1 sta.zx
3178     35 lda.z
3180      0 sta.zx
3182     14 bra     3198 v
3198        rts
2017 * 2027 = 4088459  ok
The only oddity is that DISASM will show the actual memory location of the opcodes instead of the simulated memory address. I could imagine that DISASM could be made simulator-aware pretty easily, as it's just an offset between real and simulated memory addresses.
pdragon
Post by pdragon »
That's a good idea to use DISASM! I updated the listing above to fix BCD mode and also added a P. word to show status flags which was invaluable while fighting with BCD - what a mess that is. The randomized tests all pass now, still working thru checking Klaus suite tho it is super slow :)
pdragon
Post by pdragon »
Confirmed that Klaus Dormann's test suite passes with the code as shown above:
- the 6502 functional tests take about 45m to complete at 100MHz. These tests run natively in about 97M cycles. The emulated version takes 264B(!) cycles, an average of 2700 native cycles per emulated cycle, although obviously this emulator is not cycle-accurate.
- the 65c02 tests take about 33M at 100MHz. They're about 67M cycles natively and 200B cycles when emulated (so about 3000 native cycles per emulated one).
To run the tests, I created a 16Kb version of Klaus' binary images (all code and data lives below 16Kb) with the last six bytes set to the reset/nmi/irq vectors from his image. I concatenated that to the 32Kb Taliform image (leaving 16Kb of low memory for the emulator etc). I configured the emulator to use the 16Kb address space (14 constant MBITS) at a fixed location ($4000 constant MBASE) rather than allocating it. Then running the tests is just:
hex
: test ( -- )
    \ Initalize the emulator PC to start of test code
    $400 >PC
    ." Emulating test code ... "
    BEGIN PC op PC = UNTIL
    ." Trapped at " PC u.
test
bye
\ 6502 functional test results
test Emulating test code ... Trapped at 3469  ok
bye c65: PC=f016 A=29 X=78 Y=98 S=f8 FLAGS=<N0 V0 B1 D0 I1 Z0 C1> ticks=263,686,628,952
Excellent!
