First thought on an interface (to use Paleolithic DROM)
Re: First thought on an interface (to use Paleolithic DROM)
Logisim's attempt at a gated solution requires:
- four inverters
- twenty-two two input AND
- twelve three-input AND
- one four-input OR
- five five-input OR
- one six-input OR
I don't think I'll bother...
- four inverters
- one four-input OR
- one six-input OR
You could consider charlieplexing... of course, just seven OR gates will do it, if they have up to sixteen inputs each
viewtopic.php?f=4&t=8388&p=112946#p112946
Gr
tings, Louis
May your wires be long and your nerves be strong !
Aha, a non-cheating version.
Critical design change:
The special key row does not go to d4, but rather to d6, for detection by BIT key
[Edit: except scroll down, I was totally wrong about this being needed for this approach to work.
It works just fine with "non-key" reading out as $00, "hex keys" reading out as $8x, and "special keys" reading out as $90-$93 -- albeit having "non-keys" read as $80, hex as their hex value, $0x, and "special keys" read out as $10-$13 would save two bytes.]
Non-critical design change:
"no-key" sets d7, "key" resets d7, so the d7 bit doesn't have to be cleaned up when a hex value as the new low nybble is being "or"ed with the new high nybble (not doing this leaves the requirement for an "AND #$7F" in place.
Design specification: this can work with various allocations of special keys, but I put the review key, "<-" in column 0, the go key, "->", in column 1, and the CR key in column 3.
Instead of trying to make it possible to set an address, this version accepts that there is a single starting address and GO will jump to that address ... and uses restarting the whole thing, including the original setting of the address, to go back for the review run.
The key to making the <- function fit in was the realization that it doesn't have to be prevented from auto-repeating ... because multiple repeated executions of setting W:W+1 to $00:$02 for a single press of the <- (or "review") key gives the same result as a single "<-" keypress. So just going to the start where the base address is originally set should work.
Putting the tac switch (or whatever button) for that on the 0 column is partly so that the review key, at least, shouldn't glitch the LED display ... if still pressed, it will run through one full column cycle of unpressed keys until hitting the 0 column and redo the restart at that point. But it is also an aesthetic choice, since if the ReView key is a silkscreened as a left "<-" arrow, then the GO switch next to it can be silkscreened as a right "->" arrow if desired.
Or a more mundane, though likely more mnemonic, "RV" (for review or reverse, take your pick), "GO" and "CR". (Also noting that "GB" for Go Back and "GA" for "Go Ahead" would be both mundane and also excessively obscure.)
Rather than comparing to each command key, this one distinguishes between hex keys and command keys (which involves a slight hardware change), and then a comparison with the index state for the middle (GO) key distinguishes between that key (BEQ), the one to it's left (BMI), and then by implication the one to its right.
VERSION = $00 ; alpha
REVISION = $01 ; first revision
; 125 total
; main: 80
; to_leds: 25
; vectors: 4
; table: 16
; Note:
; the special key row goes to d6
; d7 is !(row0 # row1 # row2 # row3 # row4)
; so no need to clean up hex key before "or" op.
; For branching to work, need to know where keys are:
; Column 0 = "<-", Reverse key (restart)
; Column 1 = "->", Go key (execute routine)
; Column 3 = "CR", CR key, next address
; Paleolithic
led_addr = ????
keys = ????
addr0 = $0200
; Neolithic
;led_addr = $0880
;keys = $0886
;addr0 = $1000
W = $00
leds = $02
KEY_RV = %11000000
RV_INDEX = 0
KEY_GO = %11000001
GO_INDEX = 1
KEY_CR = %11000011
CR_INDEX = 3
code
org $ff80
LED_PATTERNS db 0b00111111 ;0
db 0b00000110 ;1
db 0b01011011 ;2
db 0b01001111 ;3
db 0b01100110 ;4
db 0b01101101 ;5
db 0b01111101 ;6
db 0b00000111 ;7
db 0b01111111 ;8
db 0b01101111 ;9
db 0b01011111 ;a
db 0b00111100 ;b
db 0b00101000 ;c
db 0b01011110 ;d
db 0b01111101 ;e
db 0b01110001 ;f
exec: jmp addr0 ; +3
; +6
start: ; Set base address, this is also "review"
lda #>addr0
sta W+1
stz W ; start address addr0, page aligned
loop_main: ; +2
; Initialize the display count
; we have eight leds but we only drive six (5..0)
; to save code space (we don't need to clear them)
ldy #5
loop_digit: ; +17
; current state to leds
; put W and (W) into leds
; [x][x][x][x][x][x][ ][ ]
; (also provides a short delay for the LED multiplex)
ldx #0
lda W+1
jsr to_leds
lda W
jsr to_leds
lda (W)
jsr to_leds
; +10
; for each LED digit (right to left)...
lda leds,y
sta led_addr,y ; display bit pattern
bit keys
bmi loop_99 ; no key pressed
; +8
; do stuff to sort out which key
; a hex key if V clear (bit6=0)
bvc loop_hex ; enter hex value
; sort out the command key by index
cpy #GO_INDEX
beq exec ; execute on Go key
bmi start ; return addr0 to review
; +8
; remaining special key is return
inc W
bne loop_90
inc W+1
bra loop_90
loop_hex: ; +17
; else shuffle key value into (W)
lda keys
pha
lda (W)
asl a
asl a
asl a
asl a
sta (W)
pla
ora (W)
sta (W)
loop_90: ; +4
; wait for key to be released
; this will cause display glitch, but...
lda keys
bmi loop_90
loop_99: ; +5
dey
bpl loop_digit
bra loop_main
to_leds:
; unpack byte into two adjacent LED patterns
; x has character position
phy
pha
and #$0f ; low nibble
tay
lda LED_PATTERNS,y ; index into the patterns
sta leds+1,x ; and output into the LED array
pla
lsr a
lsr a
lsr a
lsr a ; high nibble
tay
lda LED_PATTERNS,y
sta leds,x ; this byte goes on the left
inx
inx
ply
rts
org $fffc
dw start
db VERSION,REVISION
BruceRMcF wrote:
... Non-critical design change:
1A <= row0
1B <= row1
1C <= row2
1Y => 2A
2A <= 1Y
2B <= row3
2C <= row4
2Y => driver_input7
... and unless there is a bug in the below (which is, of course, always possible) which requires too many bytes to fix, it would still work to take this:
bit keys
loop_hex: ; +17
lda keys
pha
lda (W)
asl a
asl a
asl a
asl a
sta (W)
pla
ora (W)
sta (W)
bit keys
bpl loop_99 ; no key pressed
loop_hex: ; +19
lda keys
and #$7F
pha
lda (W)
asl a
asl a
asl a
asl a
sta (W)
pla
ora (W)
sta (W)
Oh rats... I thought about that AND and forgot it...
But I can remove the original clearing of the Y register - eventually the count will get to 5 and it will then reset to zero - and use the space for the AND, I think. Hmm.
... and starting the count at 5 and counting down to 0 buys two more bytes, because you don't need to do a compare to know whether or not you have reached the end of the iterations ... when it underflows from positive to negative, you are at the end of one digit cycle and know that you can loop back to where the Y value was originally set to restart the digit cycle.
So you were never in a bind about the AND.
Where my code squeezes in the ability to test for three command keys instead of two is in having the "command key row" being connected to the input that drives D6 on the data bus, so that a BIT of KEYS tests for the key marker and whether it is a hex key in one check. Since there would be exactly three command keys, once it's divided between special keys and hex keys, the special keys only need one compare in the middle to infer work out which one of the command keys it is ... so long as you know their order on the keyboard.
[Edit: No, that wasn't it, it was just splitting between hex and command keys up front that did it, it can be done with a CMP to the smallest command key value, so it's not necessary to rewire that at all.]
I compare to the Y index value rather than to the Key value because my code doesn't do a LOAD KEY untll hitting the hex keys, but with the original marker, but the command key on Bit6 of the character, it would be equivalent to do :
LDA KEYS
BPL loop_99
BIT KEYS
BVC loop_hex
CMP #GO_KEY
BEQ exec
BMI start
; ... (CR code here)Huhn, I just now realized that there's no need to move the command key line around ... on loading KEYS, then instead of BIT, you can do a compare to the lowest command key:
LDA KEYS
BPL loop_99
CMP #RV_KEY
BMI loop_hex
BEQ start
CMP #GO_KEY
BEQ exec
SO I guess that makes Revision 2, but still, 16byte segment table, Go, Review and CR functions, and it all fits with a byte or two to spare.
I just realized that if you want to view the state of things within the $0200+ domain when code isn't working as intended (it won't work to look at the stack or the zero page), you can actually set the IRQ/BRK vector to "start" as well ... that won't work if the code that is punched in starts up interrupts, but it seems like that is a "don't do until the EEEPROM takes over from the DROM" thing in any event, but in the second stage of the bootstrap, it would support BRK points.
I'm going to do a recount of the size when it's not so early in the day, to verify whether there is space in my revision of your code for the "post-Paleolithic nicety" of Version/Revision bytes.
EDIT: I did that recount, and the two bytes could be used to implement the fourth Action key, "Page Forward" (increment the page byte of the address). With one compare to the lowest key detecting both the hex keys and also the "Review" key, leaving only three possible keys, one compare of the 3rd key, "PF" (">>") support BMI for the GO key and BEQ for the PF key, leaving CR as the remaining action by elimination.
VERSION = $00
REVISION = $03 ; 2025-06-09
; 128 total
; main: 83
; to_leds: 25
; vectors: 4
; table: 16
; Note:
; Paleolithic
led_addr = ????
keys = ????
addr0 = $0200
; Neolithic
;led_addr = $0880
;keys = $0886
;addr0 = $1000
W = $00
leds = $02
KEY_RV = $90 ; %10010000
KEY_GO = $91 ; %10010001
KEY_PF = $92 ; %10010010
KEY_CR = $93 ; %10010011
code
org $ff80
db 0b00000110 ;1
db 0b01011011 ;2
db 0b01001111 ;3
db 0b01100110 ;4
db 0b01101101 ;5
db 0b01111101 ;6
db 0b00000111 ;7
db 0b01111111 ;8
db 0b01101111 ;9
db 0b01011111 ;a
db 0b00111100 ;b
db 0b00101000 ;c
db 0b01011110 ;d
db 0b01111101 ;e
db 0b01110001 ;f
; +6
lda #>addr0
sta W+1
loop_main: ; +2
ldy #5
loop_digit: ; +17
ldx #0
lda W+1
jsr to_leds
lda W
jsr to_leds
lda (W)
jsr to_leds
; +10
lda leds,y
lda keys
; +12
; do stuff to sort out the key value
cmp #KEY_RV
bmi loop_hex ; enter hex value
beq start ; return addr0 to review
cmp #KEY_PF
bmi exec ; execute on Go key
beq loop_pf
; +8
inc W
bne loop_90
loop_pf
inc W+1
bra loop_90
loop_hex: ; +16
and #$7F
pha
lda (W)
asl a
asl a
asl a
asl a
sta (W)
pla
ora (W)
sta (W)
loop_90: ; +4
lda keys
bmi loop_90
loop_99: ; +5
dey
bpl loop_digit
bra loop_main
to_leds: ; +25
phy
pha
tay
pla
lsr a
lsr a
lsr a
lsr a ; high nibble
tay
lda LED_PATTERNS,y
inx
inx
ply
rts
org $fffc ; +4
dw start
dw start ; support BRK in code
SO, tl:dr:
Then after the BRK is triggered, the micromonitor comes up at the base address, edit the CLC to SEC and hit GO, and the first BRK that brings the micromonitor back up will be the end of the routine the put the desired debugging information where you can go look at it.
- Fits in 128byte DROM
- Includes hex to 7segment translation table
- Shift new hex digits into data byte from the lower digit toward the upper digit
- Accept value at current address and move to next by hitting CR (either one)
- Jump a binary page forward by hitting PF (or ">>")
- Execute code at built-in base address by hitting GO (or "->")
- Review the code that has been entered by hitting RV (or "<-")
- Use as a micro-monitor for entered code by inserting BRK points
So I think our versions are both very similar, but depend on the exact keyboard decoding code.
Therefore I will think about hardware again for a while.
... wish-listing alternative hardware that would make the programming easy was just wandering around false paths in the forest until an actual path appeared.
Squeezing a couple of bytes out through judicious use of loop targets and picking actions that can executed by jumping to code that already exists was enough to fit all four functions into 128 bytes.
It's (1) the order that the key parsing is executed, (2) pinning down exact values for which command key is where and (3) having the CR key in the fourth column (since it is RV, PF and GO that are best done with branches), which reduces the number of bytes needed to 4.
CMP #ThisThing
BNE check_that_action
; do ThisAction
check_that_action:
CMP #ThatThing
BNE do_that_other_thing
; do ThatAction
do_that_other_thing
; It must be TheOtherThing
; do it
... Code: Select all
CMP #TheMiddleThing
BMI TheLowerAction
BEQ TheMiddleAction
; It must be TheHigherAction
...- All hex values
- Review Key
- Go Key
- Page Forward Key
- Carriage Return
Since the two new actions (Review and Page Forward) could be implemented by just branching to the right location, only four bytes were needed to add the two branches for the two new actions.
Those four bytes were available after tightening up the looping code by reversing the digit scan to scanning from high to low, and making the initial setting of Y into the outer loop loop target, so it's not necessary to include the code to set the Y index twice in the same loop. That is:
LDY #0
loop:
INY
CPY #6
BMI loop
LDY #0
BRA loopCode: Select all
loop_main:
LDY #5
loop_digit:
DEY
BPL loop_digit
BRA loop_mainLike I said, I do think that setting the key pressed bit with two 3-input OR gates is nifty, I wouldn't want to have to add a gate to invert it if bytes can be found elsewhere.
The key hardware challenge is avoiding double-pressing CR or PF due to bounce. Without an ability to head back one line, having to go all the way through the code to get back where you were because of a key bounce would be maddening.
Especially if the code put into the base address gives feedback, a missed press is much less trouble than a bounced press ... because RV, PF, CR and a hex key all give very immediate feedback, missing a keystroke is not as much of an issue.
And giving feedback that the code that has been painstakingly assembled byte by byte has started to run is pretty easy, because the lack of use of the decimal point in the DROM code means that one decimal point in the first digit when the code starts going makes it clear that "we aren't in DROM anymore":
LDA #$80
STA ledaddr Re: First thought on an interface (to use Paleolithic DROM)
BTW, this guy likes to debounce with a 555 timer at the end of an RRC circuit ...
https://www.youtube.com/watch?v=Y-c7lf7mGok
... though I am unsure how this compares to a Schmitt-Trigger, since it seems like what he is doing is using the 555 as a Schmitt-Trigger inverter. Does it perhap give a laggier threshold crossing, where the lag itself helps improve the quality of the debounce?
I wonder if one is using switches that don't normally tend to bounce very long (to use precise statistical terminology), whether one could consider putting the full RC / series of Schmitt-Trigger inverters circuit on the command key line and just use a "pretty good" debounce for the hex key lines ... since with this micro-monitor, if the hex key input is only rarely flaky, it can be fixed up immediately.
I think possibly the simplest to fit into the circuit board for a reasonably fast closing/opening switch would be a LogiSwitch LS19-P, which gives 6 circuits with what seems like pretty good hardware debounce of a 20ms delay before a transition is triggered.
I'm still contemplating whether making the key array eight by three would help things. Certainly it needs fewer gates to encode the keys, and the command keys remain on a line of their own (and could live at any convenient position therein).
With my revision cut back to two command keys, there's six additional bytes (only one comparison and two branches needs to parse, rather than two comparisons and four branches), so there's room to add "LDA #0 : JSR to_leds" at the end of the current leds output.
(Of course, with my 4 command revision, a short routine could always be keyed in to zero out the high bytes of the led vector, terminated by a break. If "leds" is at $00F8, Key in:
6 4 F E 6 4 F F 0 0 GOBut with the four command key code, laying out the switches as:
8 9 A B C D E F : Row %xxx01xxx
0 1 2 3 4 5 6 7 : Row %xxx00xxx
RV GO PF CR : Row %xxx10xxx
Indeed, with that layout, you could have 8 command switches for potential use by the code being punched in, while still only parsing four switches for the DROM micromonitor, which under my four command parsing revision of your code would by interpreted as:
8 9 A B C D E F
0 1 2 3 4 5 6 7
RV GO GO GO GO PF CR CR
; keycode in A
CMP #KEY_CMD0
BPL hexkey
AND #$0F
ASL
TAX
JMP (command,X)
hexkey: JMP (do_hex) Re: First thought on an interface (to use Paleolithic DROM)
/me Starts thinking...
