I have been busy up flying up North for work so I have mainly been working on the 6502 code for the sound channels and main OS. I built a tiny breadboard version with one channel that travels along with me so I can keep sane after the workday is done. Today I switched gears and took some time to start on the base frame so it would at least be done before the snow returns around here. Since I had not used my old welder for a few years, it needed work so by the time I had the sparks flying, the sun was already setting.
Did manage to get a lot of the base frame complete, which is the footprint for the entire unit.
Here are a few stills from the videos I took today, along with a few updated renders showing what the final Synth should look like.
I like to change things as I build, but I would think it will be pretty close to the final look.
Here is a model of the entire steel frame. Made from 1" x 1/8" angle and 1" x 1/8" flatbar....
Dimensions of the base frame that I am working on today...
Sparks are flying in my high tech shop (aka - old pallet out back)...
Slowly working up the angles based on my sketch...
Here is a basic 3D model showing what I am working towards.
The CRT is a 12" mono like the PET, but brand new and white.
The computer keyboard is from a VIC, multiplexed by the main OS 6502.
The disk drive is a 1541, using the original components.
The piano keyboard is an 88 key unit also multiplexed by the OS 6502.
There will be a lot of other analog controls for mixing and FX on the black metal front panel as well.
The Huge PCBs are behind glass plates and will have cool backlighting and active LEDs on each of the 12 channels.
There are 6 massive circuit boards, each one 10 x 20 inches.
Most likely, the final hand wired boards will have 1000 or more ICs, all 74 logic and multiple 6502s.
I actually have all of the components already, so there is no going back now!
In keeping with the spirit of this original post, I am only using parts available in 1980.
Everything is 74 logic, SRAM and 6502s. Yeah, there are now fifteen 6502s in the unit (12 for sound, 1 for OS, 1 for Video, and one in the 1541).
I literally have buckets of ICs on my bench since I have already purchased all of the parts and ICs I need for this project!
I also have the gutted Commodore 1541 jacked onto my protoboard and so far I seem to have control over it.
Even with only 4 working channels, it's fun to jam out on the prototype. It keeps my energy level high for getting this completed.
If I can get the frame completely welded before winter then I can work on the wood sides and PCB frames indoors.
Not sure where I am going to find all of the 1/2" solid mahogany or cherry wood required, but I will keep looking.
It would be great to have at least a few channels and the main OS running to the point where I can make some simple tracks.
Greets out to all 6502 freaks.... thanks for posting all of your amazing projects!
Radical Brad
