Orac Draughts.
orac81
Orac Draughts.
Post by orac81 »
ORAC DRAUGHTS
ORAC is a (fairly) strong 6502 checkers playing program. Its was originally written a long time ago for the PET, then later adapted for the Commodore 64 and C16. (VIC20 version to come, hopefully..)
Latest version:
orac523.zip
(88.23 KiB) Downloaded 62 times
(Added colour, sound, vic20 version, etc)
orac509b.zip
(Orac: programs and source.)
(58.04 KiB) Downloaded 61 times
Or see GITHUB: https://github.com/orac81/Orac-Draughts
(MODS: I have posted this here under programming, since the source is included. I dont know of any other strong(ish) checkers-playing game engines written for the 6502, so I thought it worth sharing here)
Files in this archive:
orac-c64.prg - Commodore 64 version.
orac-c16.prg - Commodore 16/Plus 4 version.
orac-pet.prg - Commodore PET version. (BASIC 2.0, PET 30xx/2001)
orac88pet.prg - Original PET version. Originally written and hand-patched on a PET.
orac.s - Source code for above, compiles with CA65 or ASM502. Released as free under GPL3 licence.
orac.txt - This document. Includes tutorial on checkers.
To get a quick idea of the game, try running ORAC using the auto-play feature (A command) from a new board with different IQ settings.
COMMAND SUMMARY
#-# - Enter your own move. (ie. 11-15 <RETURN>)
N - Put the square numbers up on the screen. Hit <RETURN> to clear numbers.
I# - Set an intelligence (IQ) level. (ie. I20<RETURN>, range 0 to 39)
R - Resign and Restart a new game.
A - Auto play, tells ORAC to play ORAC. To stop this feature, hit SPACE.
G - Makes ORAC take your move and swap sides.
P - Makes ORAC skip your go and play again with his colours.
X - Swap side to move.
S# - Save board into 1 of 7 memory slots, ie. S1<RETURN>, range 1 to 7.
L# - Loads 1 of 7 board positions from memory, ie. L1<RETURN>
C - Clear the board, ready to set up a position.
E# - Erase piece at a given square.
B# - Puts a black man on a given square. (ie: B5<RETURN>)
BK# - Puts a black king on a given square.
W# - Puts a white man on a given square.
WK# - Puts a white king on a given square.
F1 - Change the foreground colour. (F1 key) (C16 CTRL-D)
F3 - Change the background colour. (F3 key) (C16 CTRL-E)
PROGRAM NOTES
As things stand this program is another "work in progress" - you might say somewhat slow progress! The original PET user interface is somewhat old fashioned. You make moves by typing in the from-to square numbers, followed by RETURN. It was my intention to design a new interface that could work on different machines, use joystick/cursor (or even CBM mouse) to select moves, but this is incomplete. I also wanted to make a VIC20 version, with a smaller board display. Since I dont know when this will get completed, I thought it an idea to share things as it stands.
The C64 version, when thinking, shows on the right the best move so far, its eval in hex, and at the bottom a node count in hex.The eval is a two byte integer, about $8000 for an even game, higher for a black win, lower for a white win, etc. It uses the usual game searching methods - Alpha/Beta pruning, short-look ahead to sort move ordering, and so on. The IQ setting determines the search depth, about 4 IQ points for each ply, however jumps do not count, and are scanned deeper.
Compiling ORAC is simple: asm502 orac.s orac.prg >orac.lst # Also compiles with CA65
You can change features by changing these defines in the code:
.define USE_PETSCII 0 ; Zero for hires graphics pieces, 1 for PETSCII (smaller prg)
.define SMALLER_CODE 0 ; Set this to take out some routines (Title screen, Brd Save/load etc)
.define SHOW_MOVE_INFO 1 ; Set to add code to show best move, eval, node count etc..
.define USE_CLOCK 1 ; Display clock move timer.
; You can set Set just ONE of these..
.define IS_C64 1 ; CBM64
.define IS_PET 0 ; PET Basic 2 (2001/30xx)
.define IS_C16 0 ; CBM16/+4 (PETSCII only currently)
ORAC was fairly strong for its day, in testing it beat other 8 bit commercial offerings like the Fidelity Checker Challenger stand alone machine. But in reality there is plenty of room for improvement, particularly in the endgame, which is rather weak. Detection of position repetition, which requires storing all game moves, would greatly improve play. Also simple endgame databases could be implemented, for example 1 king vs 1 king lookup is about 200 bytes (32x32/5) plus access code. On larger 6502 platforms, small transposition tables would improve performance. Of course these days there are very strong checker programs for modern platforms in the public domain, ORAC is from a different time. (ORAC was first advertised PCW June 1981!)
The original PET version (ORAC88PET.PRG) runs on BASIC 2.0 (2001/30xx) type machines. It was written using an early home-made assembler, with patches hand assembled and applied later, so its a bit of a mess. I had to "resource" and untangle this for the C64 version, although more work is needed. I tried to keep the original 6502 engine functionally the same for now, which makes bug checking easier. I moved some critical engine variables to zero page (board etc), which improves speed by 10% or so. This code is also smaller, needing about 4-5K or so.
The PET version (ORAC88PET.PRG) randomises selection of moves if they are of equal value, which is best for actual play. For testing it is possible to disable randomisation by typing: POKE 6409,96 after loading but before RUN. The C64 version does not randomise moves, this is for development/error checking.
The PET version has vestiges of an interesting feature I tried in an early version (see memory location $192f). It would scan the board in 5 square "X" patterns (like a 5 on a dice) and, using 3 possible square values (white, black, empty) use a lookup table of 243 (3^5) bytes to get a "score" for that particular pattern. This little bit of 6502 asm is an early example of pattern recognition code. It didnt really seem to work well with ORAC, I didnt see a gain in performance, and it slowed down the search, so I patched it out. But I note that more advanced versions of this (with more sophisticated/bigger patterns, more memory, faster computers etc) seem to be used with success in more recent game playing programs.
Now follows a little tutorial on the game, since checkers is not so widely played these days. I hope you find ORAC fun, and maybe useful. Enjoy!
INTRODUCING THE GAME OF CHECKERS (ENGLISH DRAUGHTS)
Draughts (or Checkers) is a much under rated and neglected game, often derided as a 'kids' game, and looked down upon by exponents of games like chess. This view is unjustified, as the game offers characteristics and subtleties simply not found in any other board game. And despite of over 200 years of research and analysis of the game, there is still plenty of new play to be found by the adventurous player. In a way, the virtue of the game is actually in its limited piece movement and mobility, since this forces you think in terms of warding off threats at a much deeper level than you would do in a game like chess, that has a larger mobility. Back in the day, there were clubs, tournements, magazines and even newspaper columns dedicated to the game. Let us look at the rules...
 |::32::31::30::29|    White (moving down)
 |28::27::26::25::|
 |::24::23::22::21|
 |20::19::18::17::|
 |::16::15::14::13|
 |12::11::10:: 9::|
 |:: 8:: 7:: 6:: 5|
 | 4:: 3:: 2:: 1::|    Black (moving up)
BOARD NUMBERING
DRAUGHTS is traditionally played on the BLACK squares of an 8 by 8 chess board The squares are numbered from 1 (bott right) to 32 (top left), with black men on squares 1-12 and white on squares 21-32. Men move diagonally forward onto empty squares, or jump over and capture an opponent if there's a clear space behind it. One VERY important rule - IF YOU CAN JUMP, YOU MUST! If, after jumping, the same piece can jump again, IT MUST! One exception to this rule - when a man reaches the KING-ROW (the 8th), and is made into a KING, it may NOT make any further jumps - until the next move. When a man becomes a KING, it can move in all 4 diagonal directions. When one side has no legal moves left, that side loses the game. The most important rule is that if you can jump YOU MUST. This leads to fascinating combinations, often sparked by cunning material sacrifice.
Consider this problem:- Black Man on 4, Black king on 6, White men on 7 and 12. Black to play and win. To set this up in ORAC type: C <RETURN> B4 <RETURN> BK6 <RETURN> W7 <RETURN> W12 <RETURN> . (or B 4,K6 : W 7,12 in standard notation.)
The winning move is 4-8! White MUST jump 12x3, its man at 3 becoming a king. Now black moves his king 6-2!! White now only has 1 move, 3-8, since its man at 7 cannot move, and Black simply jumps the 2 pieces 2x11x4 and wins.
Here is another problem: B 1,2,6 : W 11,18,27 with Black to play & win. The key move for black is 2-7 !! White replies 11x2, and the new king HAS to stop at 2 to be crowned, it cannot go on and make further jumps. Black now plays 1-5, White must jump 2x9 and black wins with 5x14x23x32.
Now a harder problem: W 6,10,14,15,18,19,22,23,27 : B 1,3,7,12,K13,20,K25,26 White to play and win. (Composed by World champion Derek Oldbury)
ORAC can see the 17 move solution in a few minutes on IQ30: 27-24! 20x27, 14-9, 7x14, 15-11, 1x10, 11-7, 13x6, 18x9x2, 25x18, 23x14, 10x17, 19-16, 3-10, 2-6, 12x19, 6x15x24x31x22x13 and White wins.
OK, having done something to convince you of the beauty of the game, let us backtrack, and consider how you should approach actual play. In the broadest terms, getting a man up, without your opponent having any compensating advantage, will usually win you the game. In the opening, beginners often lose pieces by pushing them forward too far and too fast - this happens when you initiate an exchange. For example, if Black starts a game 11-15 and White replys 22-18, after the exchange 15x22, 25x18, you will see that the piece on 18 is thrown forward - in effect White has gained 2 extra 'steps' or tempi with his pieces. While forcing pieces forward like this is OK in the later stages of the game, when you able to break through your opponents defences, it can be dangerous early on. In fact, the opening just described is perfectly sound for White, but if White was to initiate further exchanges, he could rapidly run out of space, and find himself unable to protect his forward men.
Another common mistake is to break up your back rank WITHOUT FORCING YOUR OPPONENT TO DO THE SAME. Your back rank is protection against your opponent getting a king, and also provides some protection against piercing shots and combinations. So, for Black, it is a good idea to keep the pieces at 1,2,3,6,7 intact for as long as possible. Note that I have excluded squares 4 & 8 - these are the SINGLE CORNER squares, and it is usually safer to evacuate these squares at an early stage - it is hard to get through for a king here, and even when you do, the king can often be held by a defender at square 3. By contrast, you should take particular care to defend your DOUBLE CORNER squares at 1 & 5 - this is a good place to break through for a king. For this reason, black will often keep men at 1 & 3 right through until the late stages of a game - this is called the BRIDGE defence. White usually has to place a man on square 10 before he can march through for a king. The BRIDGE can also tie up white men at square 12 (3 holds it) and 5 (1 holds it) - these are called the DOG-HOLES, and white should avoid going into these squares if at all possible. A good way to for White to attack Black's double corner is by occupying or controlling squares 14, 18 and 23 - this line-up is called the DYKE formation. Of course all the above applies equally WHITE'S back defence squares as well - for instance the White BRIDGE is at squares 30 & 32. The great emphasis on defence underlines the power of the King - an unhindered King behind your opponents defences can wreak havoc. To get to grips with the game, let us examine openings - first let us look at Black's opening moves, strongest first.
11-15 - Considered to be Blacks strongest - dominating the center. 23-19, 8-11, 22-17 often follow.
11-16 - The BRISTOL also good for black, often followed by 24-20, 16-19 with black attacking 19.
9-14 - The DOUBLE-CORNER - often followed by 22-18,5-9,25-22 with many traps awaiting white.
10-15 - The KELSO - While superficially looking strong, it does tend to jam up Black's single corner 10-14 - The DENNY, an even opening, often followed with 22-18, 11-16.
12-16 - The DUNDEE - weak for black, since 24-20 cramps his Single Corner.
9-13 - The EDINBURGH - while traditionally considered weak for black since White's 22-18 grabs the center, modern analysis reveals later counterplay for Black if played correctly.
The 11-15 move deserves special consideration - it is draughts equivalent to E2-E4 in chess! White has 7 replies, all of them good! In descending order of strength they are 23-19, 22-18, 22-17, 23-18, 24-19, 24-20, 21-17. Here are some mini-games illustrating traps in the classic openings.
* 11-15,22-18, (Single corner opening) 15-22,25-18,8-11,29-25,4-8,25-22,12-16,24-20,10-15,27-24?? This is the Draughts equivalent of 'Scholar's Mate' - its called the Goose Walk. 15-19! 24-15,16-19,23-16,9-14, 18-9,11-25,28-24,5-14, and Black wins.
* 11-15,23-19,8-11,22-17,4-8, (Old fourteenth opening) 17-13,15-18,24-20,9-14,26-23,10-15,19-10,6-15,28-24, 12-16?? Black is too aggressive! 23-19! 16-23,20-16,11-20,25-22,18-25,27-4 and White wins.
* 11-15,23-19,9-14,27-23, (Defiance opening) 8-11,22-18,15-22,25-9,5-14,29-25,11-15,25-22,4-8,24-20,15-24, 28-19,8-11? Dangerous! 22-18,6-9,31-27,10-15?? Trying to be too clever 19-10,2-6,18-15! 11-18,30-25,6-15, 21-17,14-30,23-5,30-23,27-2 and White wins.
* 11-15,23-18 (Cross opening) 8-11,26-23,10-14,30-26,7-10,24-19,15-24,28-19,11-16,22-17,4-8,26-22,9-13? This strong looking move loses.. 18-9,5-14,19-15,10-26,17-10,6-15,22-17,13-22,25-4 and White king wins..
* 11-15,24-19,15-24,28-19 (Second Double Corner opening) 9-14,22-18,5-9,26-22,7-11,27-24,3-7,22-17,11-15, 18-11,8-15,25-22,9-13,23-18? White attempt for a king backfires 14-23,17-14,10-26,19-3,12-16,31-22,16-20, 24-19,2-7,3-10,6-24 and Black wins.
* 10-14, (Denny opening) 23-19,11-16,26-23,9-13,24-20? This loses to 14-17! 21-14, (20-11,17-26,31-22,8-31 loses) 6-10,20-11,10-26,31-22,8-31 and Black wins.
* 10-15, (Kelso opening) 23-19,6-10,22-17,11-16?? a loser! 17-13!, 16-23, 13-6, 2-9,27-18-11-2 and White wins.
ORAC DRAUGHTS is released as free software under the GNU GPL3 licence, see GNU website: http://www.gnu.org/licenses/gpl-3.0.html
drogon
Re: Orac Draughts.
Post by drogon »
Thanks for posting it. I never even knew draughts had "openings". (and 3 names in Scotland, one near where I live, another in England. Most odd!)
wonder how hard it might be to port to another system...
orac81
Re: Orac Draughts.
Post by orac81 »
I have intended to make a generic text version - just needing generic ascii input/output teletype routines, but its not done yet.
The original source for the engine is a bit of mess really, but it works.
There was a famous 19th century scottish champion of checkers called James Wyllie (the herd laddie), who named many openings, hence the strong scottish connection with the game.
http://wylliedraughts.com/HerdLad.htm
I had the pleasure of corrosponding and working with Derek Oldbury, english world champion, who was also a remarkable character in the game..
https://en.wikipedia.org/wiki/Derek_Oldbury
drogon
Re: Orac Draughts.
Post by drogon »
Amazing.
well, as a fellow Scott, I guess I have to make the effort and port it to my own 6502/65816 SBC. I have text output with reprogrammable characters (8x8) and colour graphics in a variety of resolutions, so ...
I also worked in Bristol and lived in Devon for some 19 years too... It's a weird old world.
Re: Orac Draughts.
It might be helpful to post the source code in a “neutral” format that can be opened by an ordinary text editor.  I had to jump through several hoops to read the source file.
orac81
Orac Draughts 5.23 (with source)
Post by orac81 »
ORAC is a (fairly) strong open-source 6502 checkers playing program. (Possibly the strongest for the 6502?) It was written a long time ago for the PET, then later adapted for the Commodore 64, C16/+4 and VIC20.
orac523.zip
(88.23 KiB) Downloaded 50 times
Main files in this archive:
  orac-vic8k.prg - Commodore VIC20 8k+ version.
  orac-vic5k.prg - Commodore VIC20 unexpanded version (PETSCII only) (just 3300 bytes!).
  orac88pet.prg  - Original PET version, written and hand-patched on a PET.
  orac.txt       - This document. Includes quick tutorial on checkers.
COMMAND SUMMARY
Cursor up/down/left/right & SPACE - Move cursor and select move. (first the piece to move, then destination)
#-# - Enter your move using square numbers. (ie. 11-15 <RETURN>)
H - Show HELP screen. (H <RETURN>)
A - Auto play, tells ORAC to play ORAC. To stop this feature, hit RETURN.
S# - Save board into one of 8 memory slots, ie. S1<RETURN>, range 0 to 7.
L# - Loads one of 8 board positions from memory, ie. L1<RETURN>
V - Toggle different graphic shapes for black pieces.
M# - Set a randomisation factor. Bigger for more random the play. M0=off, M1 default. (M0 .. M15 <RETURN>).
F1 - Change the foreground colour. (F1 key) (C16: CTRL-D)
F3 - Change the background colour. (F3 key) (C16: CTRL-E)
F5 - Change white piece colour. (F5 key) (C16: CTRL-F)
F7 - Change black piece colour. (F7 key) (C16: CTRL-G)
(PET screenshot)
PLAYING THE GAME
You can enter your move by using the Cursor keys to move up/down/left/right, then hit SPACE to select the piece you want to move. Repeat to select the destination square. You can also make moves by typing in the from-to square numbers, followed by RETURN. To show the square numbers, hit N <RETURN>. When playing the game, remember that IF YOU CAN JUMP, YOU MUST! This is a very important rule. For a short tutorial on playing the game, see the end of this document.
The C64 version, when thinking, shows on the right the best move so far, its eval in hex, and at the bottom a node count in hex.The eval is a two byte integer, about $8000 for an even game, higher for a black win, lower for a white win, etc. It uses the usual game searching methods - Alpha/Beta pruning, short-look ahead to sort move ordering, and so on. The IQ setting determines the search depth, about 4 IQ points for each ply, however jumps do not count as a ply, and are scanned deeper.
In end games (with Kings) Randomisation will improve ORAC's play, try setting M3 up to M15 <RETURN> if ORAC is repeating moves in a winning position. When you first run ORAC, there are 8 sample problems to try - L0 .. L7 <RET> loads them, white to play and win.
TECHNICAL DETAILS
Compiling ORAC is simple: using my own open source assembler ASM502:
Also compiles with the widely used assembler CA65 (part of the open source CC65 C compiler):
ca65 -D USE_CA65=1 orac.s
cl65 -t none -o orac.prg orac.o
(If you set the "-t" computer type, you don't need the "-D USE_CA65=1" fixup)
.define USE_HIRES    1		; Set to 1,2.. to use different Hi-res chrsets, =0 for PETSCII (Needed for PET). 1=C64/C16, 2=VIC20..
.define USE_CLOCK    1		; Set to add chess style clock display.
.define NEW_FRONTEND 0		; Use smaller frontend board (=2 small, info underneath) (NEEDED for VIC20).. (0 for PET/C16/C64)
.define USE_COLOR    1		; Set to use color graphics (0 for PET)
.define USE_SOUND    1		; Enable simple beep sound on move (=1 click, =2 long beep)
.define USE_CURSOR   1		; Allow use of cursor+space to select moves.
.define USE_RANDMODE 1		; Use randomisation to improve play variety (M0..M15 set random factor)
.define V20_RELOC    0		; Set to make 8k VIC ver relocate to $1C00.. (needed for V20 hires)
   ; You can set just ONE of these..
 .define IS_PET 0		; PET Basic 2 (2001/30xx) (NOTE Set: USE_COLOR 0, USE_HIRES 0)
 .define IS_V20 0		; VIC20 8k+.  (NOTE Set: USE_HIRES 2, NEW_FRONTEND 1, V20_RELOC 1)  (When loading use LOAD"ORAC-VIC8K",8)
As things stand this program is still a "work in progress" - you might say somewhat slow progress! ORAC was fairly strong for its day, in testing it beat other 8 bit commercial offerings like the Fidelity Checker Challenger stand alone machine. But in reality there is plenty of room for improvement, particularly in the endgame, which is rather weak. Detection of position repetition, which requires storing all game moves, would greatly improve play. Also simple endgame databases could be implemented, for example 1 king vs 1 king lookup is about 200 bytes (32x32/5) plus access code. On larger 6502 platforms, small transposition tables would improve performance. Of course these days there are very strong checker programs for modern platforms in the public domain, do bear in mind that a modern PC is over 1000 times faster than a 6502 PET/C64/VIC computer - ORAC is from a different time. (ORAC was first advertised in PCW, June 1981!)
The original PET version is included here (ORAC88PET.PRG), its runs on PET BASIC 2.0 (2001/30xx) type machines. It was written using an early home-made assembler, with patches hand assembled and applied later, so its a bit of a mess. I had to "resource" and untangle this for the C64/VIC/C16 version, although more work is needed. I tried to keep the original 6502 engine functionally the same for now, which makes bug checking easier. I moved some critical engine variables to zero page (board etc), which improves speed by 10% or so. This code is also smaller, needing about 3-5K or so. The PET version (ORAC88PET.PRG) randomises selection of moves if they are of equal value, which is best for actual play. For testing it is possible to disable randomisation by typing: POKE 6409,96 after loading but before RUN. If you turn off randomisation in the new version (M0) it should play the same!
The PET version has vestiges of an interesting feature I tried in an early version (see memory location $192f). It would scan the board in 5 square "X" patterns (like a 5 on a dice) and, using 3 possible square values (white, black, empty) use a lookup table of 243 (3^5) bytes to get a "score" for that particular pattern. This little bit of 6502 asm is an early example of pattern recognition code. It didn't really seem to work well with ORAC, I didn't see a gain in performance, and it slowed down the search, so I patched it out. But I note that more advanced versions of this (with more sophisticated/bigger patterns, more memory, faster computers etc) seem to be used with success in more recent game playing programs.
Now follows a short tutorial on the game, since checkers is not so widely played these days. I hope you find ORAC fun, and maybe useful. Enjoy!
INTRODUCING THE GAME OF DRAUGHTS
(Vic20 screenshot, white to play and win in 17 moves.)
(For the rest of the tutorial and rules, see first post in this thread, or orac.txt in orac523.zip download.)
The source code is released as free software under the GNU GPL3 licence, see GNU website: http://www.gnu.org/licenses/gpl-3.0.html
fachat
Re: Orac Draughts.
Post by fachat »
Cool!
If you already have colour support for the other platforms, maybe you could support the Colour-PET too?
André
orac81
Re: Orac Draughts.
Post by orac81 »
fachat wrote:
Cool!
André
Which colour PET? :-)
I remember some plug in boards to give colour on a pet 2001/30xx, but also the "educator" pet with a c64 inside. People called the c64 the colour PET!
In any case, if the colour ram is addressable directly/simply, if you set the "pcolor" variable to the address and compile the pet version with these changes:
.define USE_COLOUR 1
.define IS_PET 1
.define IS_C64 0
.define USE_HIRES 0
pcolor=$xxxx ; Colour ram address
It should work. Some code would need adding to "io_getkey" routine at line 3686 to implement keys to change colours, see the c64 version of the routine at line 3582.. (but I don't know what control keys to use for a pet, since the early ones didn't have CTRL or function keys.)
fachat
Re: Orac Draughts.
Post by fachat »
I'm talking about this project, modifying a PET universal board to 40 col with RGBI colour output: http://cbmsteve.ca/colourpet/index.html This is actually emulated in VICE already (although you have to use the editor ROM from Steve's page)
But anyway, I'll have a look
Thanks André
orac81
Re: Orac Draughts.
Post by orac81 »
Interesting, I hadn't seen that. The first thing I could simply do is a pet40xx/80xx version, I think that would be simple, the same as pet30xx but with different romirq vectors, and VDUX=80 for 80 col. For colour would need routines set_colour_bank and set_video_bank, preserving a,x,y..
There seem to be infinite commodore machines!
orac81
Dynamo Draughts (with source)
Post by orac81 »
Just to add - I have released another related program:
DYNAMO DRAUGHTS is a program that plays International (10x10), Canadian (12x12), Spanish, American Pool, Portugese and Russian (8x8) games. It is moderately strong for its time, has many features not found on modern programs, and it was widely featured on many magazine cover disks and shareware libraries back in the 1990s. The original DOS version is included, together with a text/console version for win32 and linux, which compiles with C99 compatible compilers.
Download dynamo v9.18 with source:
dyna918a.zip
(242.93 KiB) Downloaded 48 times
Screenshot:
Now the interesting(?) thing is - I cannot find any 6502 program that plays 10x10 International draughts! So I was trying to get the c99 text version of Dynamo to compile with cc65, but it keeps throwing out-of-memory, even targeting a plus4 or c64. Can anyone suggest a better 6502 (C89) C compiler?
I may have to go back to much earlier simpler version to make it work.
It was not written with the 6502 in mind. The stripped binary of the Linux txt version is 38k. If it does compile, it might be the only 6502 program for these variants.
The best thing of course would be 6502 ASM, but it's a tricky job. Oracs engine was less than 3k, so it would be possible.
barnacle
Re: Orac Draughts.
Post by barnacle »
There's SDCC 4.2 or later which builds for the 6502 and (I think) 65c02. When I last played with it I had issues with interrupts, but that was the first 6502 target so things may have improved.
pjdennis
Re: Dynamo Draughts (with source)
Post by pjdennis »
You could look at the llvm-mos project which is working on an advanced highly optimizing compiler for the 6502, but is very much at an alpha stage so ymmv.
orac81
Re: Orac Draughts.
Post by orac81 »
Ok thanks, I will go round again and look at SDCC, and the new LLVM. I think I might have to go back to an earlier simpler version of DYNAMO to make it work, maybe convert some arrays from int to byte, etc.
Talking more generally the problem I keep seeing is that modern compilers promote BYTE vars to INT, which maybe right for modern CPUs, but not the 6502. So u can make a backend for a modern c99 compiler that sort of emulates a 16 bit machine with zero page vars, but to get true efficient handling of bytes needs a deeper rewrite, or a new compiler..
Here's a clip of a post I put on the denial (vic20) forum..
"Back when writing ASM502 I was looking at Small-C, etc - in the end I started writing my own C compiler (x86, but intending to end up 6502). it is (of course) not complete. If I recall, when experimenting, the Small-C type compilers often seem to convert byte-arithmetic to 16 bits (via virtual ZP registers) for work, converting back to BYTE at the end - which is very inefficient.
Recognising the "static" keyword properly for both vars and subroutines can help - since we would not then need to push everything onto the emulated stack, which is slow on the 6502. I did also think of having one true BYTE register variable available - mapping to X reg. A lot more use of ZP for secondary register vars could help - cc65 didnt seem to use so many as are available if one just uses all of BASIC var space.
I did start thinking in terms of pattern recognition within the intemediate code, so for example
#define VDU 0x1e00 /* C64 0x0400 etc */
void showcharset ()
register BYTE x;
x=0;
do {
*(VDU+x) = x;
x++;
} while (x);
the compiler could pick out the larger pattern and generate..
VDU = $1e00
showcharset:
ldx # 0
loop01:
txa
sta VDU,x
inx
bne loop01
rts
Of course thinking it and actually doing it are very different things!"
drogon
Re: Orac Draughts.
Post by drogon »
For a very long time, "stdint" has been a thing in the C world. (and I think mandated by the c99 standard)
So:
#include <stdint.h>
  unit8_t x, y ;
And with that you should get a byte-wide storage unit (register or otherwise). It takes away all ambiguity of char, unsigned char, int, long, etc. Want a 16-bit signed value? It's int16_t and so on. You are still at the mercy of the compiler itself doing the right thing but my experience of this has been good in the microcontroller and 6502 world (cc65)
Guaranteeing that declaring register uint8_t x; will actually use X is somewhat questionable though. I checked with llvm but c11 doesn't allow 'register' anymore and the code it produced is somewhat verbose. Similar for cc65.
The link below will take you to the godbolt compiler explorer with that snippet of code included:
https://godbolt.org/z/sYKvTMEsf
However there is effort to write code using it in the first place and update older code if you're not used to coding in that style.
(And this is actually making me wonder if my BCPL system actually generated better/faster code than cc65 on the same platform - something I'm going to have to test at some point...)
