In my efforts to increase the speed of my bootloading processes (from here viewtopic.php?f=4&t=7939), I'm thinking of doing unconventional things to the '816.
What if I hold BE low during all read cycles? Will whatever is on the databus still reach the internals of the 65816?
Here is a step by step:
*** Setup ***
Ground PHI2, BE, and /RES // initial conditions
Toggle PHI2 high then low, about 20 times, doesn't matter // just making sure everything is cleared out
Drive external databus // coming from outside source
Put $EA on databus (reset vector will end up being $EAEA, doesn't matter) // this will eventually be NOP instructions
Release /RES to pull high // bring out of reset
Toggle PHI2 high then low, about 20 times // I think that you cannot know exactly how many cycles it will take until /VP goes low?
Check VDA and VPA, if both low then toggle PHI2 high then low one time // if in the middle of a NOP instruction, cycle once more
*** Bootload Read *** // the idea here is to use LDA# and STAal instructions to reach specific RAM addresses
Put $A9 on databus (LDA# instruction)
Put desired data value on databus
Put $8F on databus (STAal instruction)
Put desired low addr on databus
Put desired high addr on databus
Put desired bank addr on databus
*** Bootload Write *** // at this point R/W would be low
Tristate external databus
Release BE to pull high
Toggle PHI2 high then low // this is where the '816 writes to RAM
Ground BE
Loop back to "Bootload Read"
Thank you for any insight!
EDIT:
Looking at the Rockwell datasheet (here https://web.archive.org/web/20221112220 ... essors.pdf) there is the timing diagram for BE on page 1-15 (see attached picture), which has A0-A15 and R/W going into tri-state, but the databus is oddly absent. Hm.
