Attempting a 65c816 build (with learning opportunities.)
ssturgis
Re: Attempting a 65c816 build (with learning opportunities.)
Post by ssturgis »
Proxy wrote:
also instead of a slow external clock with an NE555 or similar, you can just use the arduino as the clock source so it's always fully in sync
A great idea! However, my knowledge of the arduino is even more limited than my knowledge of the 6502 family. I'll see if I can figure out how to do this once my '816 project is running. It would be great for anyone with the same sort of problem Im working through. The Ben Eater breadboard clock is great, but very sensitive to noise as I found earlier.
ssturgis
Post by ssturgis »
BDD has agreed to my republishing some of his schematics for his POC V1 and below are those (partial) schematics with my additions. My modifications to the original design were to the RAM (71256SA) and the serial I/O (65c51). I don't have a RT clock (yet), but I'll add one when I get the basic implementation working. I'll also swap out the 65c51 for an 88c92 for serial I/O.
This shows the various selects and the Read/Write qualification:
This shows the selects connecting to the memory and ACIA:
In the diagrams, I've omitted the data, address and serial I/O connections to the RAM and ACIA, but they are connected as well.
akohlbecker
Post by akohlbecker »
If you've enjoyed Ben's videos and are starting a 65C816 project you might want to give my own series about this processor a watch. https://www.youtube.com/watch?v=sdFXc0R ... jHKi3f1kqT
Notably, I talk about designing the glue logic in more detail than Ben did, I build a pretty nice clock circuit, and I also built a more advanced Arduino debugger. There are a ton of useful info in those videos. (of course I'm biased :-) )
Good luck with your build!
Yuri
Post by Yuri »
Still working my way through those videos, but I've enjoyed the detail you've gone into on the timings for those videos. Very informative!
ssturgis
Post by ssturgis »
I agree with Yuri, very interesting videos and great to share. I just subscribed to your channel!
