FigForth in 6502 IDE
Maybe someone is interested. I ported FigForth to Michal Kowalski's 6502 IDE and emulator (http://www.exifpro.com/utils.html).
Have fun!
--Dietmar
Have fun!
--Dietmar
- Attachments
- FIG6502.65s.txt
- (98 KiB) Downloaded 241 times
- BigDumbDinosaur
Re: FigForth in 6502 IDE
Also, the latest version is available here on 6502.org. Thanks to Daryl Rictor, it has a number of bug fixes.
Ah, FIG Forth. A classic!
Welcome, Dietmar. Hope to hear more from you in future.
Indeed, welcome Dietmar!
Just bumping this because I thought it might get more interest. (It's possible that most of the Forth users here already have setups, perhaps running native on their 6502 machines. I'm not really a Forth user, only knowing enough to try
when I find myself at the command line.)
Hi All,
I am a big fan of and have Tali running on my sbc fine.
However, FIGFORTH has always interested me. I've brought a couple different venison's up on my SBC, worked through tutorials with it and so on, but could never get screen listings to work. I had always assumed it had something to do with my setup, but I see the same issue exist in the simulator, thus I must be missing something.
As in the screenshot, I would expect a 0 list to list 16 lines but it crashes at line 2. I know this crash is happening when in routine L3030 / DDISC and that I have no disc attached, but I have thought I could use a RAM disk as described in the 1979 installation manual.
The section of the installation manual "fig-FORTH_Manuals_May79" I refer to, page 4 reads as:
RAM DISC SIMULATION
If disc is not available, a simulation of
BLOCK and BUFFER may be made in RAM. The
following definitions setup high memory as
mass storage. Referenced 'screens' are then
brought to the 'disc buffer' area. This is
a good method to test the start-up program
even if disc may be available.
HEX
4000 CONSTANT LO ( START OF BUFFER AREA )
6800 CONSTANT HI ( 10 SCREEN EQUIVALENT )
: R/W >R ( save boolean )
B/BUF * LO + DUP
HI > 6 ?ERROR ( range check )
R> IF ( read ) SWAP ENDIF
B/BUF CMOVE ;
Insert the code field address of R/W into
BLOCK and BUFFER and proceed as if testing
disc. R/W simulates screens 0 thru 9 when
B/BUF is 128, n the memory area $4000 thru
$6BFF.
An online version of the manual is at https://github.com/BillRagsdale/fig-FOR ... 20good.pdf
I have tried this several ways, but basically, I enter the above R/W definition and get an OK, then I do the following "which is probably wrong":
' BLOCK R/W !
' BUFFER R/W !
I will then try list and it will show a line or two and crash. I have also tried not doing anything but starting figforth and 0 list, as well as only defining hi and lo.
If anyone can give me a new idea I would appreciate it. I do know if I connected up my SD card routines it would likely work much better, but I wanted to get thru playing with a ram disk first to make sure I understood what to do with read sd card access.
I do have Tali working well with my sd card solution, but FIGFORTH seems a little less straight forward to setup for me.
Thanks,
Don
RAM DISC SIMULATION
HEX
B/BUF * LO + DUP
B/BUF CMOVE ;
$6BFF.
' BLOCK R/W !
' BUFFER R/W !
Thanks,
Don
- Attachments
- Screenshot 2023-06-05 224309.png (6.83 KiB) Viewed 6696 times
Don, this is maybe a long shot, but does LIST rely on U* ? I haven't the time to check right now. But perhaps you'll be glad to learn of the UM* (multiplication) bug in common 6502 Forths anyway.
The R/W routine is in page 69 of Ragsdales manual. You have to replace it with the RAM disc code above and then it will work fine.
Be aware, that in FIG FORTH screens 1 & 2 are reserved for the error messages.
Dietrich
Dietrich
My system: Elektor Junior Computer, GitHub https://github.com/Dietrich-L
' BLOCK R/W !
' BUFFER R/W !
' BLOCK R/W !
' BUFFER R/W !
Yes, it is. My FIG-Forth is a little rusty. I think ' (tick) returns the address of a word's PFA .
You are getting the PFA of BLOCK then calling the new R/W then getting the PFA of BUFFER and calling the new R/W .
Remembering ' (tick) before R/W and swapping the order of BLOCK and R/W will not work because R/W is not the first word in the definition of BLOCK or BUFFER .
If you don't want to rebuild the FIG-Forth system, you could try locating where R/W is used in BLOCK and BUFFER then replace them with the new definition.
' R/W CFA ADDR1 !
' R/W CFA ADDR2 !
ADDR1 is the location of R/W within BLOCK and ADDR2 is the location of R/W within BUFFER .
If that seems daunting, this might work:
First, save the PFA of the original definition of R/W.
' R/W
Enter the new definition of R/W.
If memory serves, the name in FIG-Forth for EXIT is ;S
With the PFA of the original R/W still on the data stack, do the following.
' R/W CFA OVER ! \ CFA of the new R/W is stored in the first cell of the original R/W
' ;S CFA SWAP ! \ CFA of the word to exit high level Forth words is stored in the second cell of the original R/W
The original version of R/W should now be patched to run the new R/W then exit.
I can not test this. The only version of FIG-Forth I have is for the Commodore 64 and it is on a cartridge.
Don't FORGET the new definition of R/W .
Personally, I'd rebuild the system. FIG-Forth doesn't have deferred words, if memory serves, so here is a technique from Scott Ballantyne's Blazin' Forth.
: (R/W)
<define R/W here>
: R/W
(R/W) ;
This exact exercise - trying to get FIG Forth to use a ram disk - is exactly what made me give up on FIG and find Scot Stevenson's Tali Forth 2 (even though I ended up being the one to write all of the block words for it later). I never returned to FIG, but it's interesting to see someone else trying to make it work and running into the same problems. I will say, first of all, "it's not just you" and this is actually a difficult problem that is not well documented.
It's a little more complicated than the notes you quoted would have you believe. BLOCK and BUFFER both take a single argument (the block# from the disk that you want in RAM) and returns the address of a buffer, while R/W takes multiple arguments and returns nothing, so it doesn't make sense to replace the entire actions of BLOCK and BUFFER with R/W. Instead, you are supposed to patch the calls to R/W that are already inside of those words with your new word.
BLOCK actually reads from the disk into a buffer, you need R/W to do that. BUFFER, although it doesn't actually read in from the disk, may need to flush an existing buffer to disk to have a buffer to give you, so it needs R/W for doing that. When the instructions say to insert the address of R/W into BLOCK and BUFFER, I believe they mean to go into the middle of those words and replace it there (each word calls R/W once) - difficult to do without a listing and tricky even with a listing.
I think the easiest path forward is to replace the R/W in the assembly with the ramdisk version and reassemble - that will automatically "patch" both BLOCK and BUFFER in exactly the right places. You can use FORTH words in the assembly, but may have to look up their assembly labels. See the current version of R/W (search for "RSLW:") in the assembly to see how it's done.
I do think it would be a good idea to rename R/W to (R/W) and define R/W as:
: R/W (R/W) ;
This will help "future proof" the build by making R/W easy to patch.
It might be necessary to make the label PARENRSLW for (R/W) .
Here is my solution to patch the existing BLOCK and BUFFER (only lightly tested):The 48 and 44 are the offsets into those words where the old R/W CFA lives. Note that RAM will likely be set to zeroes in a simulator and might be garbage on a real system. You'll want to fill them with blanks (spaces) first if you want to put code in them. Do note, if you are used to Tali which has block size = screen size = 1K, that FIG uses blocks of 128 bytes by default (B/BUF . to see on your system) so each block is only two lines of a screen and it takes 8 blocks to make a full screen.
HEX
B/BUF * LO + DUP
B/BUF CMOVE ;
( Patch BLOCK and BUFFER )
DECIMAL
' R/W CFA ' BLOCK 48 + !
' R/W CFA ' BUFFER 44 + !Re: FigForth in 6502 IDE
Wow fellows I can't thank you all enough, this gives me allot of new insight and motivation to keep digging!
All of you in this thread, I have previously learned something from, either thru this forum, your GitHubs, or at least one of you I think I have come across on YouTube. You are all legends in my book
Thanks, and I am off to play with this some more!
PS: SamCoTV : I run TallyForth2 on my SBC as the main rom app, I have a way to go, but wanted to share I very much enjoy working with it and its the main interface, making calls to other programs and so on. I follow your GitHub, read your "patch" emails, and hope the day will come I can contribute.
I keep going back to FigForth for the learning experience and, well because I can't stand knowing I don't yet understand!
About 5 years ago I was playing with FIG and ran into the exact same frustration, so I'm happy that I now know enough about Forths in general to go back and actually solve this issue. If you keep playing around, you too will learn enough to be able to do the same. The best way to learn is to work on things (regardless of whether you get them working or not - I have about a 30% success rate of idea->working prototype).
I think that's one of the reasons I like Forth so much. It lets me very quickly poke around at a low level (to see if the hardware is working) and also very quickly get to a high level so that it doesn't take as much time to determine if something is even going to work or not. Also, when things do go wrong, I can use those same words I just developed to recreate the issue and see if I can solve it. It's nice to be able to bring the system right before/after a failure and then be able to poke and prod the system and try changes live to see if they solve the problem.
If you are going to be playing with FIG for a bit, I'll give a pointer to a version of .S that I used here (I don't remember where I got it and I can't find it again). Between that and DUMP, you can do a lot of poking around to see how things work.
Thanks to you all, I have been able to get the ram disk working, as long as I start forth and then enter the colon definition mentioned above and patch, however I can't seem to get it to work by direct patching.
I have tried the following with this figforth 1.0:
With Taliforth2, thru the use of:
' myblockreader BLOCK-READ-VECTOR !
and
' myblockwriter BLOCK-WRITE-VECTOR !
I am able to create execute custom assembly which for example, assume I enter 1 list:
1) Store the screen number 1 which I want to work with by gathering the topmost item on the data stack
2) Convert this number to a decimal value
3) Instruct my sd card to open and read the related file, in this example 1.fth
4) Populate the buffer 4FF location with this data
With a flush, I do something very similar, creating separate files for each block named by their block number.
For FigForth I was hoping to achieve something similar, and thought a good start would be to get the ram disk working and from there figure out what I needed to do.
In the simulator, I can enter the colon definition in this thread and patch block and buffer with the new R/W as given, and this works. I have further tested it by creating words to clear the appropriate memory and also to write some characters to specific places to see that they show at on the respected screens at the right places. This work great.
However, once I alter the figforth 1.0 source as mentioned above, the simulator will crash on a 1 list command for example. I cannot determine where it crashes either. I have tried breakpoints, however, even before I make modifications, it appears R/W and/or RSLW are never executed. This is hard for me to follow, because if I enter a 0 load, although it passes thru allot of garbage, that does not crash and is reading memory from "somewhere" thru some routine.
Thanks !
L3060 .BYTE $83,"R/",$D7
.WORD L3050 ; link to -BCD
RSLW .WORD DOCOL
.WORD >R ; Save boolean
.WORD BBUF ; B/BUF
.WORD STAR ; *
.WORD $4000 ; LO
.WORD PLUS ; +
.WORD DUP ; dup
.WORD $6800
.WORD GREAT ; >
.BYTE $06 ; #$06
.WORD QERR ; ?ERROR
.WORD IF ; R> IF
.WORD SWAP ; SWAP
.WORD ENDIF ; ENDIF
.WORD BBUF ; BBUF
.WORD CMOVE ; CMOVE
.WORD SEMIS ; ;' myblockreader BLOCK-READ-VECTOR !
and
Thanks !
