jds wrote:
It looks like the MOS 6500/1 is a second sourced Rockwell R6500/1.
An interesting possibility! Why would you think Rockwell are the original, and not themselves the second source?
I'm at home with RSV at present, so maybe not thinking straight. However I do have 3 ceramic R6500/1's in the workshop which I need to go out and check the date codes on.
I'm mainly going on the dates on the data sheets. Rockwell have 1979 dated data sheets as the earliest I could find (and 1987 as the latest). That's probably not conclusive as Commodore were particularly bad at updating datasheets, probably understandable as most of their production was for internal use.
The other clue is that one Commodore data sheet refers to the emulator as a R6500/1 emulator, this could mean that Commodore didn't produce any emulators (with their special packaging) and just used the Rockwell ones. In general the Rockwell data sheet is consistent with all their other data sheets, and the original Commodore one appears to be quite a close copy.
A counter argument could be that the die shot shows no Rockwell branding and a CSG logo?
NCR also produced them, looks like with Commodore ROM code in them, the one I found had an 83 date code.
But mainly I know about these as they are the start of a very long line of Rockwell 6502 microcontrollers, in the end only used in modems, which is unfortunate, the last standalone one, the L28 apparently runs at up to 35MHz. It has a 512k address range, with bank switching, and a multiply instruction.
