https://youtu.be/MrbVL-Fe7Xw
And a credit in there for Mike, too.
Usagi Electric enjoying a 6500/1 in the wild!
Re: Usagi Electric enjoying a 6500/1 in the wild!
The 6500/1 is an interesting early device.
On a tangent, there is this piece on hacking the 6500/1 in the CBM VC1520 printer:
https://e4aws.silverdr.com/hacks/6500_1/
Extracting the code from the device, a complete IEC interface and print controller and chr set, implemented in 2048 bytes of Rom and 64 bytes of Ram.
Github: https://github.com/orac81
It's a cute printer and definitely useful for the retro-computing purist.
I was curious how the ROM on the 6500 was programmed and did a Google search looking for the 6500's original data sheet. Unfortunately, all the 6500 searches turned up the data sheets for the 6500 family which didn't include the 6500/1.
My guess is it could be a PROM with fuses that are burned, or a mask ROM physically "masked" onto the chip during its fabrication.
I'd agree with either suggestion; cheaper to mask program it once it works. I found a page describing how one might get the data out of the rom, though there's no suggestion that it's programmable: https://e4aws.silverdr.com/hacks/6500_1/
Edit: Doh. Just realised that was a link already posted.
It'll certainly be mask ROM, for cost reasons - simpler technology, smaller die, higher yield.
I'm not sure if the 6500/1 was a MOS design or a Rockwell design, but the Rockwell version has a lot more documentation. This includes emulator devices with a piggyback socket for an EPROM, for development, and I think there is one packaged with extra pins for an external bus for a ROM only. They are in the Rockwell databooks and I think the Rockwell 6500/1 data sheet is in the files section here.
I checked and there are a few useful data sheets on 6502.org, including two MOS ones:
http://www.6502.org/documents/datasheet ... r_1981.pdf
http://www.6502.org/documents/datasheet ... t_1986.pdf
MOS also had a version labeled 6570 which was used as the keyboard microcontroller on quite a few Amiga's, including the original Amiga 1000.
Only the Rockwell emulator data sheet:
http://www.6502.org/documents/datasheet ... n_1987.pdf
I don't know why Rockwell never produced FLASH microcontrollers, it would have made them a lot more popular. Even for their modem chipsets which sold in the millions (just a guess) they used an external EPROM or FLASH. Some of their microcontrollers had FLASH programming routines in the ROM even.
- Mike Naberezny
- Site Admin
Both printers really are implemented in only 2K ROM and 64 bytes RAM. The features are impressive given the constraints:
Alphacom VP42
- Commodore IEC serial interface
- Embedded character set with 159 glyphs
- Full PETSCII support (all characters, uppercase, lowercase, reverse, quote modes)
- Control codes (PETSCII modes) and IEC secondary addresses (e.g. set page size)
- Unidirectional printing
- Self-test mode
Alphacom Sprinter 40
- Selectable Centronics or bit-banged RS232 serial interface (110-9600 baud)
- Embedded character set with 95 glyphs
- Control codes (speed control, multi-line feed, form feed, right justify, pagination)
- Bitmap graphics mode
- Bidirectional printing with speed control
- Self-test mode
- Attachments
- alphacom_sprinter_40.asm
- Alphacom Sprinter 40 disassembly
- (105.63 KiB) Downloaded 17 times
- alphacom_vp42.asm
- Alphacom VP42 disassembly
- (100.32 KiB) Downloaded 10 times
I miss those old-fashioned printers of that era. Besides being well engineered (given the constraints) and built like tanks. They predated the modern razor and blade marketing strategy of modern ink jet printers.
