Page 1 of 2
Fast Mem accessed slowly
Posted: Fri Oct 31, 2025 3:50 pm
by richardc64
Has anyone experienced or heard of problems when accessing fast memory slowly? Such as 20-55nS sram being accessed with 500nS /CE?
Google and Bing Searches have only given me page after page of Stack -vs- Heap, registers -vs- files -vs- arrays - vs- database queries -vs- etc. Maybe I haven't asked correctly.
Thanks
Re: Fast Mem accessed slowly
Posted: Fri Oct 31, 2025 4:23 pm
One thing to watch: fast memories have complex internal sequences which trigger off changes to incoming signals. So you may want to be sure your address lines are stable before the chip begins an access. Look carefully at the timing diagrams.
Posted: Fri Oct 31, 2025 5:42 pm
by Yuri
Thanks
Are you wanting to know if you can use a 20-55ns SRAM while holding the /CE line low for 500+ns? If so, as far as I know there shouldn't be a problem with that so long as all the other lines also stable for that long as well.
(For that mater I have often just tied the /CE directly to ground for some circuits where I don't really need it.)
Posted: Fri Oct 31, 2025 6:39 pm
SRAM means “static random-access memory.” The key word here is “static,” which means the RAM merely responds to input signal states (low or high), without regard to the passage of time. Ergo there should never be a problem with slow access, as long as you operate within the recommended DC specs, e.g., VIL, VIH, etc., observe the input setup and hold times, and input signal transition rates are within spec.
Posted: Fri Oct 31, 2025 8:22 pm
by gfoot
These aren't really good places to look for this sort of information - the first and pretty much only place to look is the datasheet for whichever RAM module you're using - it should state any restrictions on access times, and if it doesn't say that there's a maximum duration for one of the signals to be in a certain state, and doesn't state anything like an overall maximum cycle time, then it should be fine to access it as slowly as you like. For typical static RAM, as stated above, it shouldn't be a problem.
Posted: Fri Oct 31, 2025 10:10 pm
The 4Mx8 SRAM modules I sell on the front page of my site (linked below) use 10ns SRAMs. I don't have any way to test for nanosecond-range timings, but I think the manufacturers' production testing is a good-enough guarantee for that. My own tester for completed modules is very slow, with shift registers that have to shift a lot of bytes in and out of my workbench computer for each byte tested on the SRAM module. It takes a lot of operations to test each byte, and I haven't timed it exactly, but it's probably leaving the SRAM enabled at least a hundred times as long as you're talking about. It is also where, as I was developing the test program, I found out, by accident, that with only CMOS loads on a line, its parasitic capacitance could hold the data for milliseconds (not just microseconds or nanoseconds) when nothing was driving it—which is partly why testing must consist of more than just writing to an address and then reading it back, because you might only be reading what the bus capacitance is storing, possibly from a previously written location, rather than making sure the data really got stored in the SRAM, in the proper place and nowhere else. FWIW, I did not try to see how much longer the capacitance could hold the data.
Posted: Fri Oct 31, 2025 10:53 pm
by BillO
I have a small SBC I created about a decade ago. It uses a W65C02 CPU, which is a static part and I use 10ns static ram and 45ns EEROM. The SRAM is the skinny dip SRAM they used to use for cache in 100MHz 486 mother boards. The slowest I've run that board at is down to 100Hz to troubleshoot some I/O board I was working on, and it ran just fine. We're talking a 10ms cycle time here. The moral of the story is, if the relative timing of the signals is correct, it will likely not be a problem. If you are having trouble, then check to make sure the relative timings of the address bus, data buss, R/W and /CE signals are correct.
Posted: Fri Oct 31, 2025 11:28 pm
by J64C
Same here. I run 12 ns RAM on one of my boards and it's happy to run anywhere between 40 MHz or indefinite single stepping (i.e. hours between clock cycles if need be).
Posted: Sat Nov 01, 2025 3:45 am
by richardc64
Reassuring responses, some verifying things I suspected, but wasn't sure of. Thanks.
I've wondered about that, and how it relates to most devices' datasheets stating Write can be /WE controlled or /CE controlled.
Posted: Sat Nov 01, 2025 5:18 am
My opinion is that is bad design practice. Yes, it will work, but there are potential timing problems with it and most SRAMs (and (E)EPROMs) will draw more current when /CS (/CE) is continuously asserted.
Best performance is usually achieved when writing is /WE controlled and /CS is asserted as soon as a valid address is generated by the MPU, which happens during Ø2 low. The data sheet’s timing specs will indicate if this is the case.
Similarly, best performance is usually achieved when reading is /OE controlled, again with /CS being asserted as soon as a valid address is generated. Qualifying /OE with Ø2 is optional with the 65C02 but mandatory with the 65C816 unless a bus transceiver is used and is put into the high-Z state during Ø2 low.
Posted: Sun Nov 02, 2025 4:24 am
by BillO
+1
Posted: Sun Nov 02, 2025 5:33 am
by Yuri
In this context I'm talking about my VGA circuit where there address bus is only hooked up to the RAM and nothing else, there is no other device selection occurring, and every address change is completely intended for it and it alone, and it will never not be accessed in favor of something else.
No doubt there is some timing considerations there though; but in this instance I think what I'm doing is "okay"
For a more complex circuit like putting RAM on the 6502 bus with so many other devices I absolutely agree, use the /CE line, it just gives much finer control.
But to the OP's question, if you want to hold /CE low for many more nanoseconds longer than the spec of the SRAM (e.g. single stepping a 65C02, or using it at a clock frequency much lower than it's rating), then I think my point still stands. It should be fine; it shouldn't lose its contents like DRAM does, and will not cause any ill effects like releasing the magic smoke.
Of course, as most have already pointed out, read the data sheet (thoroughly) to be absolutely sure for the make/model of RAM your using.
Posted: Sun Nov 02, 2025 8:33 pm
by fachat
I'm not sure if that is true today, but I remember some pseudo static RAM being declared as SRAM that may invalidate that assumption.
It's best to look at the datasheet and see if there is an upper limit noted.
André
Posted: Sun Nov 02, 2025 9:54 pm
The definition of static RAM is RAM that maintains individual cell state with fixed input levels applied, i.e., without clocking. If a RAM can’t meet that definition, it’s not static—it’s that simple.
I did say that in my post.
I have used several brands of SRAM in my contraptions and have, at times, used the clock stepper gadget to single-step a program. In one case, I was working on that when I got called away and was not able to return to what I was working on for several days. When I did get back on it, things continued without an issue. In other words, the SRAM (and the 65C816) was truly static.
- Clock Stepper Gadget
Posted: Mon Nov 03, 2025 8:31 am
by fachat
Yes of course SRAM means static.
Just I remembered that there was PSRAM at some time. E.g.
https://www.alldatasheet.net/datasheet- ... 8512A.html
It's got a max CE pulse time of 10u.
But those are obsolet today I'd think
André
