Driving a 3-bit DAC from a VIA
cbmeeks
Post by cbmeeks »
Hello.
I found this schematic on how to drive a simple 3-bit DAC with a VIA (CB2).
http://wilsonminesco.com/6502interrupts/index.html#3.3
However, I was wondering if I could do the same thing with CA2. I'm reading over the data sheet but I'm just not getting how all of the timers work or I'm not finding how a timer can output data out to CA2 or CB2.
If that circuit only works with CB2, I will just have to swap my ports around. But I'd rather not if I don't have to. :-)
Re: Driving a 3-bit DAC from a VIA
The VIA's SR (shift-register serial port) is confined to using CB2 for data and CB1 for clock.  If the clock is controlled by a VIA timer, it will be T2.  There are quite a few modes of operation for each; but as is the case also with microcontrollers, the various timers and pins have limitations in the mix-and-match options.
cbmeeks
Post by cbmeeks »
Dang it! I was afraid of that. LOL.
Well, I will just have to swap the two ports so no big deal.
BTW, one of the biggest reasons I am building this one is so that I can tinker with these chips and not have to ask so many questions.
