The PLASMA evaluation got put to the side for the moment - I have another (what was supposed to be little) project on the go at the moment...
I need to use the cc65 suite to compile & run a short program that was provided by one of my sons. The program works a treat compiled on linux (with gcc) and I wanted to show him what it looked like in 6502 lingo... His coding is OK, and the cc65 compiler doesn't complain about anything.
So far, so good...
I thought that this would be a good time to put my new 65C02 Picocomputer through some hoops. So my cc65 now has the rp6502 target in place, I have the .cfg file, etc.
When I try linking the whole thing together, the linker complains about tons of unresolved externals, like "tosaddax", "tosgeax"... These are helper shims that are in the runtime library. Normally the <target>.lib library file is actually a merge of the runtime library AND the <target>'s specific routines. And, if I look at the rp6502.lib file with a hex editor, I can see the different exports of all of the "missing" externals.
So, what am I missing, or doing wrong ?
Please help, my "Dad always wins" score is dwindling fast.
P.S. This is the sequence of compiling
cc65 -t none --cpu 65c02 greg.c
ca65 --cpu 65c02 greg.s
ca65 --cpu 65c02 crt0.s
ca65 --cpu 65c02 ria.s
ca65 --cpu 65c02 oserror.s
ld65 -v --allow-multiple-definition --target rp6502 --lib rp6502.lib -m greg.map crt0.o ria.o oserror.o greg.o
