Orac Draughts.
Posted: Fri Jun 07, 2024 3:39 pm
ORAC DRAUGHTS
ORAC is a (fairly) strong 6502 checkers playing program. Its was originally written a long time ago for the PET, then later adapted for the Commodore 64 and C16. (VIC20 version to come, hopefully..)
Latest version: (Added colour, sound, vic20 version, etc)
Or see GITHUB: https://github.com/orac81/Orac-Draughts
(MODS: I have posted this here under programming, since the source is included. I dont know of any other strong(ish) checkers-playing game engines written for the 6502, so I thought it worth sharing here)
Files in this archive:
orac-c64.prg - Commodore 64 version.
orac-c16.prg - Commodore 16/Plus 4 version.
orac-pet.prg - Commodore PET version. (BASIC 2.0, PET 30xx/2001)
orac88pet.prg - Original PET version. Originally written and hand-patched on a PET.
orac.s - Source code for above, compiles with CA65 or ASM502. Released as free under GPL3 licence.
orac.txt - This document. Includes tutorial on checkers.
To get a quick idea of the game, try running ORAC using the auto-play feature (A command) from a new board with different IQ settings.
COMMAND SUMMARY
#-# - Enter your own move. (ie. 11-15 <RETURN>)
N - Put the square numbers up on the screen. Hit <RETURN> to clear numbers.
I# - Set an intelligence (IQ) level. (ie. I20<RETURN>, range 0 to 39)
R - Resign and Restart a new game.
A - Auto play, tells ORAC to play ORAC. To stop this feature, hit SPACE.
G - Makes ORAC take your move and swap sides.
P - Makes ORAC skip your go and play again with his colours.
X - Swap side to move.
S# - Save board into 1 of 7 memory slots, ie. S1<RETURN>, range 1 to 7.
L# - Loads 1 of 7 board positions from memory, ie. L1<RETURN>
C - Clear the board, ready to set up a position.
E# - Erase piece at a given square.
B# - Puts a black man on a given square. (ie: B5<RETURN>)
BK# - Puts a black king on a given square.
W# - Puts a white man on a given square.
WK# - Puts a white king on a given square.
F1 - Change the foreground colour. (F1 key) (C16 CTRL-D)
F3 - Change the background colour. (F3 key) (C16 CTRL-E)
PROGRAM NOTES
As things stand this program is another "work in progress" - you might say somewhat slow progress! The original PET user interface is somewhat old fashioned. You make moves by typing in the from-to square numbers, followed by RETURN. It was my intention to design a new interface that could work on different machines, use joystick/cursor (or even CBM mouse) to select moves, but this is incomplete. I also wanted to make a VIC20 version, with a smaller board display. Since I dont know when this will get completed, I thought it an idea to share things as it stands.
The C64 version, when thinking, shows on the right the best move so far, its eval in hex, and at the bottom a node count in hex.The eval is a two byte integer, about $8000 for an even game, higher for a black win, lower for a white win, etc. It uses the usual game searching methods - Alpha/Beta pruning, short-look ahead to sort move ordering, and so on. The IQ setting determines the search depth, about 4 IQ points for each ply, however jumps do not count, and are scanned deeper.
Compiling ORAC is simple: asm502 orac.s orac.prg >orac.lst # Also compiles with CA65
You can change features by changing these defines in the code:
.define USE_PETSCII 0 ; Zero for hires graphics pieces, 1 for PETSCII (smaller prg)
.define SMALLER_CODE 0 ; Set this to take out some routines (Title screen, Brd Save/load etc)
.define SHOW_MOVE_INFO 1 ; Set to add code to show best move, eval, node count etc..
.define USE_CLOCK 1 ; Display clock move timer.
; You can set Set just ONE of these..
.define IS_C64 1 ; CBM64
.define IS_PET 0 ; PET Basic 2 (2001/30xx)
.define IS_C16 0 ; CBM16/+4 (PETSCII only currently)
ORAC was fairly strong for its day, in testing it beat other 8 bit commercial offerings like the Fidelity Checker Challenger stand alone machine. But in reality there is plenty of room for improvement, particularly in the endgame, which is rather weak. Detection of position repetition, which requires storing all game moves, would greatly improve play. Also simple endgame databases could be implemented, for example 1 king vs 1 king lookup is about 200 bytes (32x32/5) plus access code. On larger 6502 platforms, small transposition tables would improve performance. Of course these days there are very strong checker programs for modern platforms in the public domain, ORAC is from a different time. (ORAC was first advertised PCW June 1981!)
The original PET version (ORAC88PET.PRG) runs on BASIC 2.0 (2001/30xx) type machines. It was written using an early home-made assembler, with patches hand assembled and applied later, so its a bit of a mess. I had to "resource" and untangle this for the C64 version, although more work is needed. I tried to keep the original 6502 engine functionally the same for now, which makes bug checking easier. I moved some critical engine variables to zero page (board etc), which improves speed by 10% or so. This code is also smaller, needing about 4-5K or so.
The PET version (ORAC88PET.PRG) randomises selection of moves if they are of equal value, which is best for actual play. For testing it is possible to disable randomisation by typing: POKE 6409,96 after loading but before RUN. The C64 version does not randomise moves, this is for development/error checking.
The PET version has vestiges of an interesting feature I tried in an early version (see memory location $192f). It would scan the board in 5 square "X" patterns (like a 5 on a dice) and, using 3 possible square values (white, black, empty) use a lookup table of 243 (3^5) bytes to get a "score" for that particular pattern. This little bit of 6502 asm is an early example of pattern recognition code. It didnt really seem to work well with ORAC, I didnt see a gain in performance, and it slowed down the search, so I patched it out. But I note that more advanced versions of this (with more sophisticated/bigger patterns, more memory, faster computers etc) seem to be used with success in more recent game playing programs.
Now follows a little tutorial on the game, since checkers is not so widely played these days. I hope you find ORAC fun, and maybe useful. Enjoy!
INTRODUCING THE GAME OF CHECKERS (ENGLISH DRAUGHTS)
Draughts (or Checkers) is a much under rated and neglected game, often derided as a 'kids' game, and looked down upon by exponents of games like chess. This view is unjustified, as the game offers characteristics and subtleties simply not found in any other board game. And despite of over 200 years of research and analysis of the game, there is still plenty of new play to be found by the adventurous player. In a way, the virtue of the game is actually in its limited piece movement and mobility, since this forces you think in terms of warding off threats at a much deeper level than you would do in a game like chess, that has a larger mobility. Back in the day, there were clubs, tournements, magazines and even newspaper columns dedicated to the game. Let us look at the rules...
BOARD NUMBERING
DRAUGHTS is traditionally played on the BLACK squares of an 8 by 8 chess board The squares are numbered from 1 (bott right) to 32 (top left), with black men on squares 1-12 and white on squares 21-32. Men move diagonally forward onto empty squares, or jump over and capture an opponent if there's a clear space behind it. One VERY important rule - IF YOU CAN JUMP, YOU MUST! If, after jumping, the same piece can jump again, IT MUST! One exception to this rule - when a man reaches the KING-ROW (the 8th), and is made into a KING, it may NOT make any further jumps - until the next move. When a man becomes a KING, it can move in all 4 diagonal directions. When one side has no legal moves left, that side loses the game. The most important rule is that if you can jump YOU MUST. This leads to fascinating combinations, often sparked by cunning material sacrifice.
Consider this problem:- Black Man on 4, Black king on 6, White men on 7 and 12. Black to play and win. To set this up in ORAC type: C <RETURN> B4 <RETURN> BK6 <RETURN> W7 <RETURN> W12 <RETURN> . (or B 4,K6 : W 7,12 in standard notation.)
The winning move is 4-8! White MUST jump 12x3, its man at 3 becoming a king. Now black moves his king 6-2!! White now only has 1 move, 3-8, since its man at 7 cannot move, and Black simply jumps the 2 pieces 2x11x4 and wins.
Here is another problem: B 1,2,6 : W 11,18,27 with Black to play & win. The key move for black is 2-7 !! White replies 11x2, and the new king HAS to stop at 2 to be crowned, it cannot go on and make further jumps. Black now plays 1-5, White must jump 2x9 and black wins with 5x14x23x32.
Now a harder problem: W 6,10,14,15,18,19,22,23,27 : B 1,3,7,12,K13,20,K25,26 White to play and win. (Composed by World champion Derek Oldbury)
ORAC can see the 17 move solution in a few minutes on IQ30: 27-24! 20x27, 14-9, 7x14, 15-11, 1x10, 11-7, 13x6, 18x9x2, 25x18, 23x14, 10x17, 19-16, 3-10, 2-6, 12x19, 6x15x24x31x22x13 and White wins.
OK, having done something to convince you of the beauty of the game, let us backtrack, and consider how you should approach actual play. In the broadest terms, getting a man up, without your opponent having any compensating advantage, will usually win you the game. In the opening, beginners often lose pieces by pushing them forward too far and too fast - this happens when you initiate an exchange. For example, if Black starts a game 11-15 and White replys 22-18, after the exchange 15x22, 25x18, you will see that the piece on 18 is thrown forward - in effect White has gained 2 extra 'steps' or tempi with his pieces. While forcing pieces forward like this is OK in the later stages of the game, when you able to break through your opponents defences, it can be dangerous early on. In fact, the opening just described is perfectly sound for White, but if White was to initiate further exchanges, he could rapidly run out of space, and find himself unable to protect his forward men.
Another common mistake is to break up your back rank WITHOUT FORCING YOUR OPPONENT TO DO THE SAME. Your back rank is protection against your opponent getting a king, and also provides some protection against piercing shots and combinations. So, for Black, it is a good idea to keep the pieces at 1,2,3,6,7 intact for as long as possible. Note that I have excluded squares 4 & 8 - these are the SINGLE CORNER squares, and it is usually safer to evacuate these squares at an early stage - it is hard to get through for a king here, and even when you do, the king can often be held by a defender at square 3. By contrast, you should take particular care to defend your DOUBLE CORNER squares at 1 & 5 - this is a good place to break through for a king. For this reason, black will often keep men at 1 & 3 right through until the late stages of a game - this is called the BRIDGE defence. White usually has to place a man on square 10 before he can march through for a king. The BRIDGE can also tie up white men at square 12 (3 holds it) and 5 (1 holds it) - these are called the DOG-HOLES, and white should avoid going into these squares if at all possible. A good way to for White to attack Black's double corner is by occupying or controlling squares 14, 18 and 23 - this line-up is called the DYKE formation. Of course all the above applies equally WHITE'S back defence squares as well - for instance the White BRIDGE is at squares 30 & 32. The great emphasis on defence underlines the power of the King - an unhindered King behind your opponents defences can wreak havoc. To get to grips with the game, let us examine openings - first let us look at Black's opening moves, strongest first.
11-15 - Considered to be Blacks strongest - dominating the center. 23-19, 8-11, 22-17 often follow.
11-16 - The BRISTOL also good for black, often followed by 24-20, 16-19 with black attacking 19.
9-14 - The DOUBLE-CORNER - often followed by 22-18,5-9,25-22 with many traps awaiting white.
10-15 - The KELSO - While superficially looking strong, it does tend to jam up Black's single corner 10-14 - The DENNY, an even opening, often followed with 22-18, 11-16.
12-16 - The DUNDEE - weak for black, since 24-20 cramps his Single Corner.
9-13 - The EDINBURGH - while traditionally considered weak for black since White's 22-18 grabs the center, modern analysis reveals later counterplay for Black if played correctly.
The 11-15 move deserves special consideration - it is draughts equivalent to E2-E4 in chess! White has 7 replies, all of them good! In descending order of strength they are 23-19, 22-18, 22-17, 23-18, 24-19, 24-20, 21-17. Here are some mini-games illustrating traps in the classic openings.
* 11-15,22-18, (Single corner opening) 15-22,25-18,8-11,29-25,4-8,25-22,12-16,24-20,10-15,27-24?? This is the Draughts equivalent of 'Scholar's Mate' - its called the Goose Walk. 15-19! 24-15,16-19,23-16,9-14, 18-9,11-25,28-24,5-14, and Black wins.
* 11-15,23-19,8-11,22-17,4-8, (Old fourteenth opening) 17-13,15-18,24-20,9-14,26-23,10-15,19-10,6-15,28-24, 12-16?? Black is too aggressive! 23-19! 16-23,20-16,11-20,25-22,18-25,27-4 and White wins.
* 11-15,23-19,9-14,27-23, (Defiance opening) 8-11,22-18,15-22,25-9,5-14,29-25,11-15,25-22,4-8,24-20,15-24, 28-19,8-11? Dangerous! 22-18,6-9,31-27,10-15?? Trying to be too clever 19-10,2-6,18-15! 11-18,30-25,6-15, 21-17,14-30,23-5,30-23,27-2 and White wins.
* 11-15,23-18 (Cross opening) 8-11,26-23,10-14,30-26,7-10,24-19,15-24,28-19,11-16,22-17,4-8,26-22,9-13? This strong looking move loses.. 18-9,5-14,19-15,10-26,17-10,6-15,22-17,13-22,25-4 and White king wins..
* 11-15,24-19,15-24,28-19 (Second Double Corner opening) 9-14,22-18,5-9,26-22,7-11,27-24,3-7,22-17,11-15, 18-11,8-15,25-22,9-13,23-18? White attempt for a king backfires 14-23,17-14,10-26,19-3,12-16,31-22,16-20, 24-19,2-7,3-10,6-24 and Black wins.
* 10-14, (Denny opening) 23-19,11-16,26-23,9-13,24-20? This loses to 14-17! 21-14, (20-11,17-26,31-22,8-31 loses) 6-10,20-11,10-26,31-22,8-31 and Black wins.
* 10-15, (Kelso opening) 23-19,6-10,22-17,11-16?? a loser! 17-13!, 16-23, 13-6, 2-9,27-18-11-2 and White wins.
ORAC DRAUGHTS is released as free software under the GNU GPL3 licence, see GNU website: http://www.gnu.org/licenses/gpl-3.0.html
COMMAND SUMMARY
PROGRAM NOTES
|::32::31::30::29| White (moving down)
|28::27::26::25::|
|::24::23::22::21|
|20::19::18::17::|
|::16::15::14::13|
|12::11::10:: 9::|
|:: 8:: 7:: 6:: 5|
| 4:: 3:: 2:: 1::| Black (moving up)
