Hallo allemaal,
I'm not sure if this subject is 'programming' or 'hardware'. I equped my Commodore 1541-II drive with a AT29C256. What I'm looking for is some sources how to program it while still in the drive. Having the datasheets I do it myself but I'm quite sure somebody did this before and inventing the wheel twice is a bit of waist of time IMHO.
Any helpers with sources or an URL?
Thank you very much !!!
Programming Flash Memory
___
/ __|__
/ / |_/ Groetjes, Ruud
\ \__|_\
\___| URL: www.baltissen.org
Here's the code I wrote for use with AM29F040, let me know if it's any good for the chip you're using.
byte_program:
stx temp2
ldx #$AA
stx $8555
ldx #$55
stx $82AA
ldx #$A0
stx $8555
sta (ptr),y ;(ptr),y
sta temp_lo
@program_wait:
lda (ptr),y
sta count_lo
lda (ptr),y
sta count_hi
and #%01000000
sta temp3
lda count_lo
and #%01000000
cmp temp3
beq @program_done
lda count_hi
and #%00100000
and count_lo
beq @program_wait
lda (ptr),y
sta count_lo
lda (ptr),y
sta count_hi
and #%01000000
sta temp3
lda count_lo
and #%01000000
cmp temp3
beq @program_done
lda #$F0
sta (ptr),y
ldx temp2
rts
@program_done:
; beep
ldx temp2
rts
sector_erase:
lda #$AA
ldy #$55
ldx #$80
sta $8555
sty $82AA
stx $8555
sta $8555
sty $82AA
lda #$30
sta $8000
lda $8000
cmp #$FF
bne :-
rts
autoselect_mode:
lda #$F0
sta $8000 ; reset command
lda #$AA ; unlock command
sta $8555
lda #$55
sta $82AA
lda #$90 ; auto-select command
sta $8555
lda $8000 ; mfg. id
sta temp1
lda $8001 ; device id
sta temp2
lda #$F0
sta $8000 ; reset
lda temp1
cmp #1
bne @xx
pointer mfg_amd,addr_lo
jmp mfg_end
@xx:
cmp #$20
bne @zz
pointer mfg_st,addr_lo
jmp mfg_end
@zz:
pointer mfg_none,addr_lo
mfg_end:
lda temp2
cmp #$A4
bne @aa
pointer dev_040,addr_lo2
jmp dev_end
@aa:
cmp #$E2
bne @ba
pointer dev_040st,addr_lo2
jmp dev_end
@ba:
cmp #$20
bne @bb
pointer dev_010,addr_lo2
jmp dev_end
@bb:
pointer dev_unk,addr_lo2
dev_end:
rts
msg_maker: .byte LF,"Flash maker; ",0
mfg_none: .asciiz "your mom!!"
mfg_amd: .asciiz "AMD"
mfg_st: .asciiz "ST"
msg_dev: .byte LF,"Part #; ",0
dev_040: .asciiz "Am29F040"
dev_040st: .asciiz "M29F040B"
dev_010: .asciiz "29F010"
dev_unk: .asciiz "Unknown"
___
/ __|__
\ \__|_\
