Page 1 of 1
Need help with Kowalski assembler syntax
Posted: Thu Dec 28, 2023 6:50 am
by glockr
I'm trying to have the assembler populate an 8-bit jump table and I can't figure out the correct syntax. I want it to put the low order address byte of a group of routines. This is what I'm trying:
< My routines >
routine_1 (first line of code) A0 00 ; assembles to $0420
(more lines of code) E6 00
D0 02
4C BF 0E ; last line at $0434
routine_2 (first line of code) A0 00 ; assembles to $0437
(more lines of code) 68
85 60
4C BF 0E ; last line at $0441
routine_2 (first line of code) A0 00 ; assembles to $0444
(more lines of code) B1 60
85 76
etc...
< My jump table >
.BYTE <routine_1 ; gets set to $5B
.BYTE <routine_2 ; gets set to $6F
.BYTE <routine_3 ; gets set to $70
etc...
The table "should" contain $20, $37, and $44 or maybe the contents of the address, but it contains neither. If I leave off the '<' I get
message saying something about not being able to fit a 16 bit value into an 8 bit BYTE. Also tried playing around with different combinations
of '#', '$', '>', and '<' but nothing I try gives the results I want. Is it even possible? If so, what is the correct syntax? Also, is there a good
user manual for the Kowalski assembler available online somewhere? I've been looking for the past 3 or 4 days and I can't find anything
that has a lot of detailed information. Thanks.
Re: Need help with Kowalski assembler syntax
Posted: Thu Dec 28, 2023 8:27 am
by barrym95838
I use the interactive help Kowalski provides in the right pane. For example, if I cursor near a .BYTE directive in my source:
Could you share a bit more context? It looks like you're on the right track, but something's not clicking into place yet.
You can also help us out by surrounding your code with
 and
to provide a fixed-width font and unmolested white-space.
Posted: Thu Dec 28, 2023 12:58 pm
by 8BIT
What version of the Kowalski assembler are you using?
Also, are you sure your ORG statement is $0400 vs 0400?
I created this source:
	*= $0400
routine_1
	LDA #0
	STA $1
	JMP $0ebf
routine_2
	LDA #0
	STA $2
	JMP $0ebf
routine_3
	LDA #0
	STA $3
	JMP $0ebf
table
 .BYTE	<routine_1
 .BYTE	<routine_2
 .BYTE	<routine_3
And the disassembly was correct.
This is on the latest version from my website -> https://sbc.rictor.org/kowalski.html
Cheers!
Posted: Thu Dec 28, 2023 5:19 pm
by glockr
Hi Daryl,
I'm using version 1.3.4.7 and... I found out the problem was my fault. Playing around with it some more after I posted, I found that
putting .BYTE <somefunction_ before the routines gave the expected result, but putting it after didn't. Then after sleeping on it, I "noticed"
that I had two jump tables set to the same address. Once I fixed that it started working. My fault. Sorry for posting before figuring out it
was my own bone-headed mistake.
