I'm trying to find the X-RAY Resident Assembler/Editor for the Synertek Sym-1 program, and the manual has the program listing. However, I've tried several OCR programs, and none are able to actually get the listing bytes out in any meaningful way. I guess I could try to hand enter it into a blank rom file, but that would take forever!
Does anyone have a copy of the program, or a good way to OCR a pdf source listing? The PDF doesn't even look bad!
http://www.6502.org/trainers/synertek/s ... isting.pdf
X-RAY Line Editor/Assembler for SYM-1 source/paper tape?
GinDiamond
- barrym95838
Re: X-RAY Line Editor/Assembler for SYM-1 source/paper tape?
I'm not sure which OCR engine is being used by archive.org, but it seems to be quite good in the examples I've seen.
[Edit: I experimented, found out that it's tesseract 5.3.0-3-g9920, and concluded that it choked badly]
Here's a tesseract OCR version told to use full page rather than the default which selects the listing as columns. It's going to need some editing
but it's a good start. The edge of left hand page and the clip binding don't help things...
edit: this is easy... I have an ongoing project to convert my entire library - about two and a half thousand books - to epub via scanning and OCR. Whether I will finish before I die of old age is an interesting question, but Analog SF&F just decided they can deliver in epub, which helps a little. Though I still have about fifteen years' of those to do.
- Attachments
- xray.zip
- (7.65 MiB) Downloaded 93 times
- barrym95838
[Edit: Nine errors found so far ... see below for a better version.]
barrym95838 wrote:
- barrym95838
IamRob wrote:
A quick search found 1-Q and 2-S's that will have to be replaced.
P.S. Found six more:
034B:20
04DE:C9
0505:40
07BD:B3
0997:38
0B70:80Got a kilobyte lying fallow in your 65xx's memory map? Sprinkle some VTL02C on it and see how it grows on you!
GinDiamond
034B:20
04DE:C9
0505:40
07BD:B3
0997:38
0B70:80Now I'm trying to figure out why SYMDOS no longer wants to save files to my sd card, tsk tsk! I can load files and read the directory just fine, but sometimes running the delete command hangs the system and yeah, saving completely hangs the drive and doesn't work at ALL. It makes a blank file with the filename and doesn't save anything from the ram. I tried with even 0200 to 0300, nope, nothing!
