Page 1 of 2
Mandelbrot Benchmarking
Posted: Thu Oct 05, 2023 4:02 pm
by drogon
I decided to update my old Mandelbrot benchmark to the one I used recently (originally in VTL) to check my TinyBasic, then on a whim, I decided to make it work on the other BASICs I had to-hand.
It should work on most retro/8-bit BASIC systems with minimal changes and work over 16-bit signed integer BASICs to 4 or 5 byte floating point ones.
I put it all here:
https://projects.drogon.net/retro-basic ... andelbrot/
Re: Mandelbrot Benchmarking
Posted: Thu Oct 05, 2023 5:45 pm
by gfoot
Nice thanks for sharing it - I'm thinking of following your lead and porting BBC BASIC to my system, then maybe I can give it a go!
Posted: Thu Oct 05, 2023 8:59 pm
Nice - thanks for writing up and sharing!
I wonder if there's something funny going on - I'm not 100% happy about the integer-mode output. Of course the problem might be my expectations!
Here's an owlet link for the Beeb running Basic 2
And here's the same thing but using integer arithmetic.
(In both cases, press the rocket button for a quick run.)
I'm suspicious of the shapes of the contours - posting this with a vague idea I might look into it tomorrow.
Posted: Thu Oct 05, 2023 9:44 pm
by drogon
Me too... I'll translate it to another integer only system tomorrow when I get some time and compare.
Thanks,
Posted: Thu Oct 05, 2023 10:35 pm
by gfoot
I had a play with this. Firstly I tried using "DIV" instead of "/" in the floating point version, and the output was not the same. Debugging this revealed that on line 220 the fraction from dividing by F% was affecting the result - i.e. in the integer version, this bit at least was benefiting from "/" being floating point division. So to get a truly integer execution in BBC BASIC, I think you do need to carefully change all the "/" to "DIV", or at least this one!
The real problem however is with the bounds check on lines 230-240:
230A%=T%: P%=A%/F%:Q%=B%/F%
240IF ((P%*P%)+(Q%*Q%))>=5 GOTO 280
P% and Q% suffer badly from rounding here, as you're dividing by the fixed point factor. You can use floating point for P and Q, or better, do the comparison in the fixed point space:
230A%=T%
240IF ((A%*A% DIV F%)+(B%*B% DIV F%))>=5*F% GOTO 280
This may suffer different problems if it ends up overflowing the maximum integer width - 16 bits is pretty narrow - I haven't thought much about what the worst-case inputs would be though!
It seems to work pretty well:
https://bbcmic.ro/#%7B%22v%22%3A1%2C%22 ... %5Cn%22%7D
Posted: Fri Oct 06, 2023 7:07 am
Oh, well done, that does look a lot better!
Posted: Fri Oct 06, 2023 7:36 am
by drogon
Also, as an aside, interesting to note than even when presented with all integer variables, BBC Basic still does floating point operations if you're not careful...
Posted: Fri Oct 06, 2023 7:53 am
Yes... it does seem to make it a bit more difficult to experiment with the implications of different word sizes.
Posted: Fri Oct 06, 2023 9:43 am
by barrym95838
230A%=T%
WOZ BASIC errored out almost immediately with your modification, but was able to render a less accurate version of Gordon's original in about 696 seconds @ 1 MHz:
  100 REM PR#3 FROM > PROMPT FIRST!
  105 PRINT "MANDELBROT - WOZ BASIC"
  110 PRINT "START"
  130 DIM Z$(17):Z$=".:,;-=+^/%&S$X#@ "
  140 F=50
  150 FOR Y=-12 TO 12
  160 FOR X=-49 TO 29
  170 C=X*229/100
  180 D=Y*416/100
  190 A=C:B=D:I=1
  200 Q=B/F:S=B-Q*F
  210 T=(A*A-B*B)/F+C
  220 B=2*(A*Q+A*S/F)+D
  230 A=T:P=A/F:Q=B/F
  240 IF P*P+Q*Q>4 THEN 280
  250 I=I+1: IF I<17 THEN 200
  280 PRINT Z$(I,I);: NEXT X
  300 PRINT : NEXT Y
  330 PRINT "FINISHED";
  350 END
Applesoft renders a much better image, but takes about 860 seconds @ 1 MHz:
100  REM PR#3 FROM ] PROMPT FIRST!
105  PRINT "MANDELBROT - APPLESOFT"
110  PRINT "START"
130 Z$ = ".:,;-=+^/%&S$X#@ "
140 F = 50
150  FOR Y =  - 12 TO 12
160  FOR X =  - 49 TO 29
170 C = X * 229 / 100
180 D = Y * 416 / 100
190 A = C:B = D:I = 1
200 Q = B / F:S = B - Q * F
210 T = (A * A - B * B) / F + C
220 B = 2 * (A * Q + A * S / F) + D
230 A = T:P = A / F:Q = B / F
240  IF P * P + Q * Q > 4 THEN 280
250 I = I + 1: IF I < 17 THEN 200
280  PRINT  MID$ (Z$,I,1);: NEXT X
300  PRINT : NEXT Y
350  END
Posted: Thu Sep 19, 2024 12:48 pm
by GlennSmith
Hi,
I was looking for something simple to try out with my rather cumbersome (*) but all the same operational PLASMA Virtual Machine running on the Pico6502. I chose to adapt the Apple][ version that appears above. So the code becomes
[edit] BTW "word" in PLASMA means a 16-bit object.
byte[] Z = ".:,;-=+^/%&S$X#@ "
word A, B, C, D, E, F, I, P, Q, S, T, X, Y
    F = 50
    for Y = -12 to 12
        for X = -49 to 29
            C = X * 229 / 100
            D = Y * 416 / 100
            A = C; B = D; I = 1
            repeat
                Q = B / F; S = B - Q * F
                A = T; P = A / F; Q = B / F
                if (P * P + Q * Q) > 4 break
                fin
                I++
            until I >= 17
            putc(Z[I])
            next
        putln
    next
    puts("FINISHED\n")
done
... which shows a part of the PLASMA vocabulary. If I run the code through the linux VM, it gives this picture
......::::::::::::::::::::::,,,,,,,,,;;;;;-=+/S$+^--;;,,,,,,:::::::::::........
.....::::::::::::,,,,,,,,;;;;;;;--=^ &S%              ^/^S=-;,::::::::::.......
.....::::::,,,,,,;;-=X++=^ +===+^%                        &&-;;,,,:::::::......
....::,,,,,,,,;;;;-=+%  /$  #/^/%                          S-;;,,::::::::......
::::::,,,,,,;;;;;-==^/X        #                            -;;,,,::::::::::::.
FINISHED
If I run it through the 6502 VM, I get this picture
Picot_6502 Mandelbrot
(*) I can't give any timing for the moment, because the "Pico6502" VM is, in fact, the linux version pushed through cc65 - with stdio and all the rest of it - and it spends 80% of it's time messing around with the C stack and only 20% doing any real work. More news soon on a more "native" 6502 version.
Posted: Sun Sep 29, 2024 8:16 am
by GlennSmith
Hi all,
I have now successfully ported the PLASMA VM to the RP6502 "Picocomputer" in native ASM + Plasma.
It's probably because you're all so far away that I couldn't hear all of the "HOURRAA"s
Anyway, the above code completes in the native VM (bytecode interpreter) in 21.73 seconds. The 65C02 is being clocked at 7.5MHz, 'cos I'm getting fileIO errors at 8MHz. *AND* I had to cheat with the timing, the API entry for reading clock ticks doesn't work currently...
Have a great Sunday y'all.
Posted: Sun Sep 29, 2024 8:55 am
Hurrah!
Posted: Mon Sep 30, 2024 6:24 am
by resman
Hurrah! Can't wait to see what the hybrid VM will do
Posted: Tue Oct 01, 2024 7:01 pm
by GlennSmith
Not sure what you mean... The last result is the "Native" (6502 assembler + Plasma code) VM. No C code at all.
Posted: Tue Oct 01, 2024 8:44 pm
by resman
When the C coded VM gets compiled for ARM and the byte codes get interpreted from the ARM core as an accelerator. Now you're cooking with gas.
