Looking for floating point libraries
As title.
I already know of:
- Wozniak & Rankin's one from Dr. Dobbs in 1976 (4-byte binary, difficult copyright licensing/issues)
- Microsoft's one in their BASIC (no license)
- Acorn's in their BASIC (no license)
- the Atari MATHPACK clone from Altirra (GPL; 6-byte BCD)
- the C64-compatible routines from the X16 kernal replacement (mostly copied from Microsoft, AFAICT)
- Louis Chorich's Atari floating point library (commercial, 6-byte, presumably BCD but the docs don't say)
- Apple's SANE (source lost)
- Some Random Internet Guy's library (no license, 5-byte BCD, no negative numbers)
Anyone know of more?
I already know of:
Re: Looking for floating point libraries
I wrote some floating point routines earlier this year, I'm not sure if they count as a library though. I think I posted it on Stardot as it was using the BBC BASIC assembler, and had routines to load values from BASIC variables. I only implemented the basics though (addition, subtraction, multiplication). I made a two byte version and a three byte version. The API was load-store register-based, a bit like ARM I guess.
- barrym95838
viewtopic.php?p=45404#p45404
... leading to
https://web.archive.org/web/20170923012 ... 80/fpu.txt
https://web.archive.org/web/20210418053 ... calc65.htm
... leading to
- BigDumbDinosaur
For the 65C816: http://forum.6502.org/viewtopic.php?f=2&t=4133
- BigDumbDinosaur
barrym95838 wrote:
http://65xx.unet.bz/fpu.txt opens for me.
Here's another one, written this decade: https://hackaday.io/project/181098-home ... r-for-6502 32-bit BCD, no license (but unusually, the author can be contacted without the use of a spirit medium!).
https://web.archive.org/web/20200128060 ... calc65.htm: 64-bit BCD, full set of trigonometric functions... no license and 'all rights reserved'.
Hi!
The Altirra ROM replacement is not under the GPL, but under the MIT license, much more permissive.
The VBCC 6502 compiler uses those, and includes a library with all the split objects.
The Mad Pascal compiler (at https://github.com/tebe6502/Mad-Pascal ) includes:
- 32-bit FLOAT: https://github.com/tebe6502/Mad-Pascal/ ... single.asm
- 16-bit FLOAT: https://github.com/tebe6502/Mad-Pascal/ ... dd_sub.asm and other files.
Have Fun!
hjalfi wrote:
As title.
I already know of:
I already know of:
Have Fun!
Here's a standards-compliant implementation. Only compiles on llvm-mos as far as I know.
https://github.com/rweather/berkeley-softfloat-3-6502
I know you want something with a permissive license.
I am not a patent lawyer and I do not play one on television; if you were to paraphrase code from one processor architecture to a different one, is the result considered to be infringing? If not, that may be a relatively easy way to get there. I have always presumed that to be safe; it is not unlike coding from an algorithm in a book or journal.
Floating point code has been published for the Motorola 8-bit processors. Same for 8080/Z80. Source code for 8087 emulation from the Borland compilers (80x86) is also out there.
Are you picky between BCD versus binary?
A long time ago, I set out to write IEEE 754 compliant floating point for the 6800. I have single precision generally working but have yet to work out how to implement the guard, round and sticky bits. Because the AVR instruction set looked so easy to program, I also built a version for that. Future steps:
* Figure out the guard, round and sticky bits
* Improve the speed
* Implement 6-byte, double and extended precision
* Port to other processors
* Improve the speed
The idea if implementing floating point in a language that doesn't intrinsically support it [1] isn't new either - in the early 80's BCPL didn't support floating point either, but there were libraries - one I used was the package for the BBC Micros implementation of BCPL which supported various formats and previsions. FP numbers were held in vectors (arrays) and you called functions to do the FP operations.
https://www.computinghistory.org.uk/det ... s-Package/
[1] Yes, C supports floating point but cc65 doesn't, so it would have to be implemented by external means.
I wrote some 32 bit single precision FP routines for VM02. Not much error handling. Search for FLOATING_POINT:
https://github.com/dschmenk/VM02/blob/master/src/ops.s
