So, I'm trying to get up to speed on the xa assembler, and so far, things are going pretty well.
The weird problem I've run into though is that it is treating 'JSL $123456' as a syntax error. I am passing the '-w' option in the command line.
Any ideas what I'm missing here?
Question about xa and JSL
- barrym95838
Re: Question about xa and JSL
Is this the xa you are referencing? Did you try JSL @123456?
@ render as 24-bit quantity for 65816 (must specify -w
command-line option). This is required to specify any
24-bit quantity!Got a kilobyte lying fallow in your 65xx's memory map? Sprinkle some VTL02C on it and see how it grows on you!
RebeccaBlue
24-bit quantity!Thank you!
