Attention code golfers...
BillG
Post by BillG »
This is the ready check for a serial printer in a driver for the 6800:
* Check printer ready, return with sign flag set if ready
PChk
    psha            ; Save A
    ldaa    ACIA    ; Get status register
    rora            ; Get TDRE bit into MSB
    rora
    rora
    pula            ; Recover A
    rts
How would you write this for the NMOS 6502?
I can see juggling bytes on the stack or using a temporary variable, but no direct translation.
gfoot
Re: Attention code golfers...
Post by gfoot »
Something like this - it puts the result in the carry flag rather than the negative flag:
    pha
    lda ACIA
    ror
    ror
    pla
    rts
A CMOS 6502 could do this all in one instruction but you asked for MMOS explicitly.
BillG
Post by BillG »
The interface was originally used for a parallel printer. Space was extremely limited, so they just read the port and the ready line was bit 7. I would rather not change the interface as that would make the parallel driver even bigger.
The best I could come up with is:
PChk
    pha             ; Save A
    lda     ACIA    ; Get status register
    ror     A       ; Get TDRE bit into MSB
    ror     A
    ror     A
    sta     Temp
    pla             ; Recover A
    bit     Temp    ; Set S flag accordingly
    rts
PChk
    pha             ; Save A
    ror     A
    ror     A
    sta     Temp
    pla             ; Recover A
    rts
If the ready line is bit 7 what's wrong with BIT ACIA followed by BPL or BMI?
BillG
Post by BillG »
The Ready line is bit 7 for the parallel port. It is bit 1 for the serial port.
    pha
    lda ACIA
    ror
    ror
    pla
    rts
George's code looks good to me. Yes, you'd have to make a minor change in every place from which this routine is called (to test Carry rather than the Sign). But that seems tolerable if you're replacing all the 6800 code with 6502 code anyway...
barrym95838
Post by barrym95838 »
It looks like the 6800 version is nine bytes. If you have space for ten bytes and you have a "junk" zp location, you can just add an ROR zp to George's code:
    pha
    lda ACIA
    ror
    ror
    pla
    ror temp
    rts
When I was translating code from 6800 to 6502 I would be often annoyed by the need to tsta after a pula, but this is a good counterexample.
teamtempest
Post by teamtempest »
Is there any reason you can't trash X or Y? If not, here's another 10-byte attempt:
    tax
    lda ACIA
    ror
    ror
    ror
    php
    txa
    rti
IamRob
Post by IamRob »
The ROR's can be replaced with LSR's if only the carry flag is pertinent.
barrym95838
teamtempest wrote:
    php
    txa
    rti
I don't recommend it, unless you only JSR $EAxx ... PC will be one byte off ...
barrym95838
... and it works around that pesky ROR bug!
BillG
Post by BillG »
One of the goals of the project is to make it as easy as possible to port 6800 code over. Changing this interface would be yet another thing to forget to check.
The serial driver is under no space pressure.
The parallel driver is. The 6800 version uses 55 of the 56 bytes allotted. I've allocated 64 bytes for the 6502 version and barely managed to code golf it to fit.
I posted that subroutine from the serial driver to see whether I overlooked any coding tricks.
BillG
Post by BillG »
I do not have a spare zp location, but there are bytes to spare within the driver, that temporary variable I used, for instance.
I should have known that you would come up with something.
gfoot
Post by gfoot »
BillG wrote:
You could even ROR a read-only location, like something in ROM. The write will fail but the negative flag should be set correctly.
BillG
Post by BillG »
gfoot wrote:
Interesting that you can do it with ROM. That will confuse someone trying to reserve engineer the code unless they happen to know that fact.
