Converting traditional assembly code to Forth assembly code
Posted: Wed Jan 06, 2021 9:25 pm
Hi All,
(My first post, I think!)
I have a question that I thought might be best considered here, even though it's not strictly 6502 related *ahem*, but bear with me.
I'm using Brad R's excellent CamelForth/6809 that I have running on the Vectrex video game console, from 1982. My current project consists of salvaging a 6809 binary from a late 1970's FLEX disk and porting it onto the Vectrex. CamelForth/6809 comes with the 'Chromium' cross-compiler/assembler and I've started converting the FLEX binary, which I've disassembled, into CamelForth assembly.
First tests are good, the assembly works as expected, but then I hit a number of flag tests/branches and associated forward jumps, which the cross-assembler can't handle. Luckily, CamelForth assembler has IF, ELSE, THEN, etc. that in most cases I can substitute in.
But now I'm a bit further into the code, I'm hitting routines where the code flow jumps all over the place, e.g. out of BEGIN, UNTIL, loops, including using out of sequence IF, THEN,. Clearly, if the code was built using IF, THEN, etc. in the first place, I wouldn't be seeing this issue, but it wasn't and it looks like a laborious major restructuring to make it assemble with CamelForth.
My current thought is to abandon the attempt to convert to CamelForth assembly and use a regular assembler with the code as-is and attach the assembled binary to my Forth cross compiled binary and jump to the routines instead.
But before I do that, I thought I'd just ask around if anyone else had done something similar or had any further words of wisdom that might switch a light on.
Thanks for reading.
(And sorry it's not pure 6502. Actually, I have the idea to create a new cartridge for the Vectrex that would halt the 6809 and instead contain an '816 and a program ROM, which could then take over the system. People have already done it with an ARM, why not a '816?)
Thanks for reading.
