6502 instruction control lines breakdown needed
JustClaire
Post by JustClaire »
Hello
I am currently looking for some resource that would show how the internal control logic works on 6502 on the hardware level.
I am interested in by-cycle breakdown, (ex. what control lines are actuated on each stage of the instruction, what happens on clock transition high and low <- this is very important part, etc.)
Would appreciate any helpful resource on the topic.
Re: 6502 instruction control lines breakdown needed
I'd always go first to visual6502, for example
http://visual6502.org/JSSim/expert.html ... ,DPControl
I'm not sure if you'll be most interested in plaOutputs or DPControl.
If you prefer a C program, try Perfect6502 which is the same data and the same algorithm
https://github.com/mist64/perfect6502#readme
