aim-65 floppy disk control
pjmag
Post by pjmag »
Hi
I was wondering if anyone had rigged up a floppy controller for an AIM-65? I have seen Dallas Shell's notes on KYM DOS variants, including one based on the 1541. I have some old 1541s sitting around and so that would look like a quick/cheap option (all I need to do is generate an EPROM with an appropriately modified DOS variant). Any other suggestions or information out there?
Pete
It would make sense to get a FDD going again for something like an Apple II which would have a lot of legacy code on floppies, but I don't remember ever hearing of an AIM-65 having that. How about implementing an SPI (four-wire synchronous serial) interface for a flash memory that could hold as much as a large case of floppies, all in a postage-stamp-size unit? You can get raw serial flash memories, or use something like an MMC module.
Mike Naberezny
Site Admin
Floppies
Post by Mike Naberezny »
Hi,
Dallas Shell's materials are the best source that I know for floppy drive information for the AIM-65.
Using the Commodore drive is a good solution for many homebuilt projects as it already has some intelligence built-in. Richard Cini and I have been working on this for some time and he has successfully extracted the serial communications routines from the VIC-20 KERNAL, cleaned them up, and successfully reimplemented them on Daryl Rictor's SBC-2 board.
We have artwork for version 2.6 of the SBC-2 board, which adds a new header. This header connects to a daughterboard with some simple electronics which in turn connectors to the CBM-IEC serial bus. We're working on pages for this project and it will be included in the mini-projects section shortly.
Regards,
Mike
Wally Daniels
Post by Wally Daniels »
The beauty of this idea is that Read / Write Sector is more or less done for
you already ( IIRC ). This would then let you concentrate on a MS-DOS
FAT system, clusters etc. which would eventually give you access to DOS
files. I have not done this personally with Flash / MMC style memory but
I have done low level primitives for 360kb / 720kb read/write sectors.
If you decide to roll your own FDC routines, look for any PC/XT ISA FDC
card that has an NEC765 / Intel 8272 / 82077aa or National 8477 chip
on board. Then start with the lowest transfer rate ( 250kbs ) this means
very roughly that you will need to be able to handle a byte about every
13uS. As far as the actual ISA interface goes, its pretty forgiving.
-Wally
HansO
Re: Floppies
Post by HansO »
Mike Naberezny wrote:
.... We're working on pages for this project and it will be included in the mini-projects section shortly.
Regards,
Mike
Nice! Looking forward to these articles. Commodore floppy drives are now very cheap and widely available and have a DOS builtin. Plenty of space for files for a 6502 system. Dallas already published the details for the SYM-1 product sold in the eighties and that works fine. A bit slow, but using a parallel port modification the speed can be improved.
Hans, http://www.hansotten.com
Paul
Post by Paul »
Hi,
You may want to check out http://www.6502pages.com/ that I have been working on for several months now with input from Dallas Shell. There you find software and schematics for a floppy controller that will work on a SYM, KIM, TIM, and AIM computers called FODS or File Oriented Disk System. The controller card is switch selectable for any address in memory. The software posted is for a SYM dual drive system but could be altered for any machine. The controller uses a FD1771 and 6522. The one I have still currently works with no problems at all.
For those of you with Synertek's KTM terminal there is also information and schematics for the KTM2/80 terminal which includes how to convert a 40 column to 80 with all the binaries posted.
Paul
HansO
Post by HansO »
Paul wrote:
Hi,
You may want to check out http://www.6502pages.com/ that I have been working on for several months now ...
Paul
Great page! Thank you!
Hans
RichCini
Re: Floppies
Post by RichCini »
This is very true. I wanted to use this setup for a data logging application, and printers and drives are cheap.
I'd like to add that not only are the raw routines implemented, but they are done in a Commodore-compatible way, meaning that the overall API is the same as is the command sequence to open/use/close a device. It supports IEC devices 4-31, and I've successfully used both printers and disk drives with the SBC-2.
Additionally, the code contains a DOS command interpreter module which sort of looks like and operates like the disk commands in PET BASIC 4.0. Not all commands are supported, but enough are that it's convenient to use.
IIRC, the entire Serial IEC support module is just over 3k in size.
Rich
blackadder
Post by blackadder »
dredging up a year old topic...
I worked with a guy named Don Lewis who was sort of a 1541 guru, one of his projects was called VDOS, as I recall it was a 1541 DOS that worked on various 6502 based computers.
I remember building an interface for one of our shop AIM 65's to try it out, wasn't much to it, just a connector wired to one of the 6522s on the AIM I think, might have used a TTL buffer, I don't recall for sure.
I might actually still have a copy of it in my old C64 stuff, and I'm pretty sure I have the users manual.
debounce
Post by debounce »
Among others, one enterprising chap has developed an MMC interface that connects to 4 pins on the B side of a 6522, and also a memory-mapped version. Then there is the GoMMC board which has been produced for a couple of years now and fits in a JEDEC ROM socket, and also supplies 2x8 KB of FRAM for firmware.
-Wally
At 300 rpm, the nominal transfer rate for SD FM data is 64us per byte, DD MFM 32us, and HD 16us; allow +/- 2%^2 (~4%) error for varying motor speeds. At 1 MHz with no DMA, double density is doable with sacrifices, and HD is out of the question. If you need DD I can try and draw up suitable code.
Greg
EmbeddedBob
Post by EmbeddedBob »
I've been playing with a mini DOS for my KIM for several months now using old Atari disk drives. Atari used a serial async protocol to talk to perihpherals at 19200 baud, making it very easy to hook up a simple 6850 ACIA and some software. Yes, the file management is done in the KIM as opposed to the disk drive itself, but you've got lots of flexibility, and a properly designed DOS will allow for adding higher capacity drives in the future.
Right now, the software is pretty crude. I load a 256 byte "miniboot" program into the KIM's memory, then it loads the boot sector from the drive and pulls in the rest of the system. There are subroutines to read, write sectors, format and install a bootable image on the disk. The next higher layer up is only partially written, but has routines for maintaining the used/free sector map on the disk.
A couple of other guys are getting interested in this project. If someone wants info, I'd be happy to share the simple schematic and source code. I'm open for suggestions.
Bob
orgwood
aim 65 1541 interface
Post by orgwood »
Hi guys, I just found my ah5050 board and schematic that interfaced to the AIM65 and used the 1541 disk drive ...and interest in communicating?
DaveC
fachat
Post by fachat »
There already is some code available - I have implemented DD/HD MFM disk access using the WD1772 controller. You can find it at
http://www.6502.org/users/andre/csa/shug/index.html
Andre
Greg
ptorric
Post by ptorric »
btw: where can i find the theory at the base of a mfm disk controller?
thanks!
orac
Post by orac »
Wikipedia of course!
