I want to be some 6502a microprocessor
Asiancrates
Post by Asiancrates »
6502a
any places where I can find them..are you guys going to order some with the bulk order?
thanks for your help
usotsuki
Re: I want to be some 6502a microprocessor
Post by usotsuki »
Asiancrates wrote:
6502a
Would a 65C02 not suffice? They have more functionality than 6502A processors and might be *much* easier to find. :wink: :roll:
Isolationist
Post by Isolationist »
I have found my 6502's inside a Commodore 1541 floppy drive and a Commodore VIC-20 (remember them?).
You shouldn't have any problems removing the 6502 from the VIC (finding one on the other hand...)
If you find a 1541 drive, make sure its the old grey ones with the built in power supply, not the 1541-II (external power supply, white) or a later revision of the 1541 (white, internal power supply, drive door much like on an IBM computer). Make sure its the type of drive that to close the drive door you must push the lever down and pull it out slightly. This type is the older type and has the 6502 mounted on a plug, unlike the others where they are directly soldered to the board.
Good luck!!!
You will porbably find the old Commodore hardware lurking around garage sales or swap-meets.
There is no expedient to which a man will not go to avoid the labour of thinking.
esarintulo
Post by esarintulo »
And the 1541 board can make a nice SBC too.It has everything on board to begin with : ram (well,2K but to start....),rom,decoding,cpu,6522's,even a serial interface (to connect to the C64),power supply.
You only need to "commit" some programming to come with a small monitor à la Apple or whatever you like, an eprom/eerom/flash burner to cast it in stone , hook it to your terminal of choice (Hyperterminal,VT100,even a TTY) et voilà.
Schematics are easy to find on the Web,the commented 1541 rom disassembly too.
Have fun!
René.
TMorita
Post by TMorita »
My brother wanted to be an oboe when he was a kid, but I have to admit, a 6502a would be a lot cooler.
Toshi
