Page 1 of 2
indirect addressing
Posted: Thu Aug 20, 2020 4:57 am
by DanielS
I'm coming along with my walk into C64 assembly. I've hit another block though.
Take this code...
position_1 .byte $51, $04 ;Points to an address in screen memory
The target address is $0451. I need to store the contents of the accum into that memory location.
I've tried different examples from online docs but none work.
lda #$20
sta ??position_1??,y ; should resolve to "sta $0451,y"
Y is the indexer in this case (ie. $0451 + Y).
I can't figure out how to get the correct address that's pointed to by the high/low byte pair.
C64 with 64tass assembler.
Thanks for helping an old guy realize a childhood dream.
Re: indirect addressing
Posted: Thu Aug 20, 2020 5:21 am
by DerTrueForce
What you're doing in that first snippet is putting a label at the assembler's current address, then laying down two bytes starting at that position.
The second snippet is correct, if you remove the question marks.
Your assembler should tell you how to assign a value to a label somewhere in its documentation.
Posted: Thu Aug 20, 2020 5:23 am
by barrym95838
position_1 and position_1+1 must both be in zero page, then
should store a $20 in address $0451+y (assuming 64tass uses classic 65xx assembly notation).
Posted: Thu Aug 20, 2020 5:29 am
by DanielS
I can put them in zero page. Can I just pick an arbitrary location or... ?
[Edit] Found something that said I can safely use $02-$7f.
Posted: Thu Aug 20, 2020 6:00 am
by DerTrueForce
Oh. I had a braino moment... I'll see myself out...
Posted: Thu Aug 20, 2020 6:03 am
by barrym95838
Depends on your definition of "safe".
https://sta.c64.org/cbm64mem.html
$02-$06 and $fb-$fe seem quite safe, by my personal definition.
Posted: Thu Aug 20, 2020 12:19 pm
by IamRob
Sorry! Posted to the wrong forum.
Totally unrelated!
Posted: Thu Aug 20, 2020 12:47 pm
by DanielS
Using...
lda #$51
sta position_1
lda #$04
sta position_1 + 1
lda square_data,x
sta (position_1),y
position_1 .byte $02 ;Location in zero page
I get the error
square.asm:26:20: error: not a direct page address address '($18be),y'
sta (position_1),y
That being said... the file that has this code assembles fine by itself. I get the error when I assemble the file that includes (.include "foo.asm") this file.
So I don't know if I'm declaring something wrong or if it's a 64tass thing.
Posted: Thu Aug 20, 2020 1:54 pm
You need position_1 to be the value $02 - but that's not what you have. You need a directive more like an EQU to set the value of position_1.
What you have is position_1 as a label, and then you've placed $02 at that location. That's the sort of thing you do when you want a constant, or some constants, embedded in your program.
Posted: Thu Aug 20, 2020 2:12 pm
by DanielS
Could I bother you for a small example?
Posted: Thu Aug 20, 2020 2:28 pm
If I read
the manual right, you'd use
position_1 = $02 ;Location in zero page
and it might need to be up at the left edge. And it should be before the first point you use it, I think.
Posted: Thu Aug 20, 2020 2:30 pm
Or, an example from the manual, ahead of all of your code:
* = $02
position_1 .addr ? ;a zero page pointer
(But that's very 64tass specific.)
Posted: Thu Aug 20, 2020 2:32 pm
by DanielS
If I read the manual right, you'd use
Looks like that did it. Thanks!
Posted: Thu Aug 20, 2020 2:39 pm
by BillG
Take this code...
lda #$20
Is $0451 a constant or will it be different as your program runs?
If constant, you can do
or better,
If you will be writing to other locations nearby, you can do
Screen = $0451
ldy #Offset
sta Screen,Y
which is saying store A at Screen+Offset provided you stay within the range $0451..$0550.
Posted: Thu Aug 20, 2020 2:52 pm
by DanielS
Screen = $0451
ldy #Offset
sta Screen,Y
BOOM! Why didn't I think of it this way? This is exactly what I needed. The high/low byte pairs was just complicating something that should be simple. Thanks!
