indirect addressing
DanielS
indirect addressing
Post by DanielS »
I'm coming along with my walk into C64 assembly. I've hit another block though.
Take this code...
position_1 .byte $51, $04 ;Points to an address in screen memory
The target address is $0451. I need to store the contents of the accum into that memory location.
I've tried different examples from online docs but none work.
lda #$20
sta ??position_1??,y ; should resolve to "sta $0451,y"
Y is the indexer in this case (ie. $0451 + Y).
I can't figure out how to get the correct address that's pointed to by the high/low byte pair.
C64 with 64tass assembler.
Thanks for helping an old guy realize a childhood dream. :)
DerTrueForce
Re: indirect addressing
Post by DerTrueForce »
What you're doing in that first snippet is putting a label at the assembler's current address, then laying down two bytes starting at that position.
The second snippet is correct, if you remove the question marks.
Your assembler should tell you how to assign a value to a label somewhere in its documentation.
barrym95838
Post by barrym95838 »
position_1 and position_1+1 must both be in zero page, then
    lda  #$20
    sta  (position_1),y
should store a $20 in address $0451+y (assuming 64tass uses classic 65xx assembly notation).
DanielS
Post by DanielS »
I can put them in zero page. Can I just pick an arbitrary location or... ?
[Edit] Found something that said I can safely use $02-$7f.
DerTrueForce
Oh. I had a braino moment... I'll see myself out...
barrym95838
Depends on your definition of "safe".
https://sta.c64.org/cbm64mem.html
$02-$06 and $fb-$fe seem quite safe, by my personal definition.
IamRob
Post by IamRob »
Sorry! Posted to the wrong forum.
Totally unrelated!
DanielS
Post by DanielS »
Using...
        lda #$51
        sta position_1
        lda #$04
        sta position_1 + 1
        lda     square_data,x
        sta     (position_1),y
        position_1 .byte $02 ;Location in zero page
I get the error
square.asm:26:20: error: not a direct page address address '($18be),y'
sta (position_1),y
That being said... the file that has this code assembles fine by itself. I get the error when I assemble the file that includes (.include "foo.asm") this file.
So I don't know if I'm declaring something wrong or if it's a 64tass thing.
You need position_1 to be the value $02 - but that's not what you have. You need a directive more like an EQU to set the value of position_1.
What you have is position_1 as a label, and then you've placed $02 at that location. That's the sort of thing you do when you want a constant, or some constants, embedded in your program.
DanielS
Post by DanielS »
Could I bother you for a small example?
If I read the manual right, you'd use
        position_1 = $02 ;Location in zero page
and it might need to be up at the left edge. And it should be before the first point you use it, I think.
Or, an example from the manual, ahead of all of your code:
*       = $02
position_1	.addr ?         ;a zero page pointer
(But that's very 64tass specific.)
DanielS
Post by DanielS »
Looks like that did it. Thanks!
BillG
Post by BillG »
Take this code...
lda #$20
Is $0451 a constant or will it be different as your program runs?
If constant, you can do
    sta     $0451
or better,
Screen = $0451
    sta     Screen
If you will be writing to other locations nearby, you can do
Screen = $0451
    ldy     #Offset
    sta     Screen,Y
which is saying store A at Screen+Offset provided you stay within the range $0451..$0550.
DanielS
Post by DanielS »
Screen = $0451
    ldy     #Offset
    sta     Screen,Y
BOOM! Why didn't I think of it this way? This is exactly what I needed. The high/low byte pairs was just complicating something that should be simple. Thanks!
