Hello
I want to use lib65816 in my project, and i am a bit confused on how to use it correctly. Is there any guide or documentation written for it?
How to use lib65816
Re: How to use lib65816
Is that Sam Falvo's? He only rarely drops by these days.
https://github.com/sam-falvo/lib65816
I did something minimal with that, once - doesn't make me an expert! Looks like Daryl (8bit) tried it too:
viewtopic.php?f=8&t=4275&p=47961&hilit=run65816#p47961
Or maybe you've found this one
https://github.com/FrancescoRigoni/Lib65816
which is new to me... it's more recent but I'm not sure if it's still active.
JustClaire
Did you find this post and the one after? Might be helpful. There's going to be some puzzling-out needed, I suspect. It's late for me, now, but I could look tomorrow, see if I can help at all.
viewtopic.php?p=23982#p23982
Just had a quick look. It looks like Sam anticipated some sort of system-on-chip setup where there are up to a word's worth of IRQ sources. Looks like just using a mask of 1 would be the normal expected story.
JustClaire
