"A crash course on electronics"
This chapter of a larger work might be of interest:
Chapter 6 Logic Gates
This chapter provides an overview of the hardware components that are used to build a computer. We will limit the discussion to electronic computers, which use transistors to switch between two different voltages. One voltage represents 0, the other 1. The hardware devices that implement the logical operations are called Logic Gates.
(The larger work is Introduction to Computer Organization - ARM Assembly Language Using the Raspberry Pi by Robert G. Plantz)
