Recommended clock input
KhanTyranitar
Ok, I am using a 6526 chip in my project, and I want to use a 60Hz TTL level input that is quite accurate. What would you guys recommend?
I am working on building a 65816 based computer (for personal use)
Eventual goals include:
65816 CPU up to 14-16 MHz (In Turbo Mode)
up to 16MB RAM (512K on the main board)
Dual YM3438 audio
IEC serial device support
Dual YM3438 audio
- floobydust
Re: Recommended clock input
Other than this, getting a 60Hz accurate source was accomplished by some older style chips, such as the MM5369, which uses a standard color burst Xtal at 3.58MHz. Here a link:
http://www.eleccircuit.com/60hz-clock-pulse-generator/
KhanTyranitar
Yes, but that assumes using AC current as a source for the signal, but my project runs off 12v DC. I don't want to run AC just to time a chip.
I'll have a look at that pulse generator.
Dual YM3438 audio
Dual YM3438 audio
- floobydust
Re needing AC line access... true, but you never specified any details about your project. You just have to think about the options. You can also use a can oscillator and a series of dividers to get 60Hz. It all depends on your overall goals and what existing clock sources exist in your project.
White Flame
You could even use the 6526's own cycle timer to trigger TOD blips.
Would vertical sync from the video be accurate enough ? It'd required a 60Hz filter.
KhanTyranitar
The application will have a regulated power supply that supplies 12v and 5v DC. But no AC. The unit I'm building may also run off batteries. But I would like the TOD clock to work.
Dual YM3438 audio
Dual YM3438 audio
grey-lensman
Complete 32.768 kHz can oscillators are easy to come by. Divide the output with a pair of 8 bit counters (74HC590 or equivalent) and you'll get an accurate 60 Hz square wave. It's good enough for clocks...
- barrym95838
What would you use for your output divider value? 546.13333333333333333333333333333?
Mike B.
Mike B.
DerTrueForce
Barry is right there. The divisor would not be an integer if you wanted to use a 32.768 kHz signal.
You could use a 1.8432MHz crystal(an ACIA baud-rate crystal) and divide it by 30,720($7800). Or, if you're using one of the NXP UARTS, you could take the 3.6864MHz that they use and divide by 61439($EFFF). Both of those would produce 60Hz, if I've got my maths right.
A 32.768kHz oscillator was used in my first digital watch (LED), back in 1976. There was a tiny tuning thingie in there. Probably a capacitor. The clock was a bit too fast, so I connected a frequency counter and fine-tuned the 60Hz. After three months the watch was still within one second off. Presumably the oscillator had then been shifted to 32.760 kHz, which doesn't sound unreasonable.
