OT:Vacuum florescent display as a msi vacuum tube ic?
So, really impractical idea for a rube-goldberg cpu here...
Vfds are basically just an array of tiny vacuum tube "transistors", and have been used in ham radios already as amplifiers... don't believe me?
Since triodes seem to work like a pnp bjt when a + voltage is applied to the grid, and a npn bjt when a - voltage is applied, this would make the equivalent of ttl possible with triodes.
If you don't mind making a 10 khz cpu that uses a 90 volt power supply and melts itself after a couple hours, is it possible?
Re: Vacuum florescent display as a msi vacuum tube ic?
Yes, I think you can make a CPU from any kind of switching element. One which had visuals built in would be amusing.
I just found a youtube video demonstrating his radio. Apparently it required at least 120 volts to drive a pc speaker at high volume. Probably would explode like a firework after 10 minutes of that though XD
Since the VFD picture was on the homepage of H.P Friedrichs:
"Instruments of Amplification", ISBN 0-9671905-1-7, from H.P. Friedrichs
sure was nice reading material.
Especially that part about homebuilt foil-based cuprous oxide transistors.
Pictures are at the end of this gallery:
http://hpfriedrichs.com/mybooks/ioa/bks ... llery2.htm
If I remember correctly, transistors didn't survive much more than 5V,
and only one of 10 homebuilt transistors worked as intended.
If you have success in building a 7400 that way, please post a picture.
Very nice! He starts out with missing some information though. A grid need not be between the filament and plate. It may be on the opposite side of the plate from the filament and work the same. Not that it matters for his project.
It still surprises me that there don't seem to be many people experimenting with flame triodes.
It even seems to be a DIP! No idea about availability though.
That always seemed to me like calling horse-drawn carriages "motorless motorcars".
Who replaces 12AX7s regularly? I see a huge market for socket retrofits, with oxygen-free pins.
Oh I understand. I have a ton of tube gear (probably literally).
What I don't understand (beyond the obvious copper-free nonsense) is why they are always changing tubes. They're just not that frail. In my opinion, something in constant use for the past forty years is lucky to actually need one new 12AX7 by now. But then I don't normally modify things to work out of tolerance. Maybe others do.
I always expected miniaturised tubes to make a comeback. For some reason I never expected it to come about this way.
- BigDumbDinosaur
They probably had active getters. A lot of power tubes do, and they will get gassy if you never operate them in such a way to activate the getter.
Otherwise, it's not much of an issue, else there wouldn't be /any/ working 01As.
- BigDumbDinosaur
Tube technology has some fierce advocates among musicians...
In the realm of guitar amps, some of the appeal of tube technology relates to aspects which can arguably be considered imperfections...
- BigDumbDinosaur
In that case, it must just be bad seals. Otherwise, it would affect all tubes equally.
I've got hundreds of tubes, which I have tested most of in recent years. Very, very few have ever been gassy, less than 1%. But most of mine are receiving tubes, especially television, mostly excluding sweep tubes. That may indicate something, I don't know.
- BigDumbDinosaur
When I got the amp it was DOA, due to dried-out electrolytics and a failed B+ rectification diode. I installed new caps and a pair of diodes (1N4007), and after bringing the amp up to full power (I started it off on the Variac), noticed that the two 6L6GC's, both RCAs, appeared to be a bit gassy, but with no color in the plates. A check of the quiescent plate current confirmed my suspicions. I replaced them with two NOS GEs I had and ran into the same problem, though not as bad. I ended up installing some Electro-Harmonix (Russian re-issues) I had laying around and everything was fine.
