128 bit Floating Point 65C816 implementation
Posted: Mon May 23, 2016 6:58 pm
Hello everyone.
i'm developing a floating point unit for 65C816 compliant with IEEE754 quadruple precision.
At this time these functions are full implemented:
- fpadd, fpsub, fpmult, fpdiv (basic operations)
- fprexp (extract exponent), fscale (scale by a power of two), scale10 (scale by a power of ten), fsquare
- fpack (store in memory in ieee format), funpack (get from memory)
- Roundup functions: ftrunc, fceil, floor, fround, fmod
- str2int, str2fp (convert string to binary)
- fp2str: convert a float to string (compliant with sprintf() function)
- int2dec, uint2dec: convert a 128 bit integer to string
- fsqrt, fcbrt: square root and cube root
- flog, flog10, flog2 (logarithm functions)
- flogp1, flog10p1, flog2p1: computes lognn(1+x) whenn x is very close to 1.0
- fexp, fexp2, fexp10: exponential functions
- fexpm1: computes exp(x)-1 with greater accuracy when x is close to 0.0
- fpown: computes x raised at n (n integer)
- frootn: computes the n-th root
- fpowxy: computes x raised to y (both float)
For future i plan to implement circular functions and hyperbolics functions.
Source code is available HERE: http://65xx.unet.bz/fpu.txt
- Marco
- Marco
