It is currently Mon Apr 29, 2024 6:14 am
Post new topic Reply to topic  [ 44 posts ]  Go to page 1, 2, 3  Next
PostPosted: Mon May 23, 2016 6:58 pm
Hello everyone.
i'm developing a floating point unit for 65C816 compliant with IEEE754 quadruple precision.
At this time these functions are full implemented:
- fpadd, fpsub, fpmult, fpdiv (basic operations)
- fprexp (extract exponent), fscale (scale by a power of two), scale10 (scale by a power of ten), fsquare
- fpack (store in memory in ieee format), funpack (get from memory)
- Roundup functions: ftrunc, fceil, floor, fround, fmod
- str2int, str2fp (convert string to binary)
- fp2str: convert a float to string (compliant with sprintf() function)
- int2dec, uint2dec: convert a 128 bit integer to string
- fsqrt, fcbrt: square root and cube root
- flog, flog10, flog2 (logarithm functions)
- flogp1, flog10p1, flog2p1: computes lognn(1+x) whenn x is very close to 1.0
- fexp, fexp2, fexp10: exponential functions
- fexpm1: computes exp(x)-1 with greater accuracy when x is close to 0.0
- fpown: computes x raised at n (n integer)
- frootn: computes the n-th root
- fpowxy: computes x raised to y (both float)
For future i plan to implement circular functions and hyperbolics functions.
Source code is available HERE: http://65xx.unet.bz/fpu.txt
- Marco
PostPosted: Sat Jun 04, 2016 4:03 pm
Oh, this is wonderful. I'm going to try it out RIGHT NOW. :D
...and thank you.
PostPosted: Wed Jun 08, 2016 5:27 pm
Hello everyone,
i updated the fpu implementation with a new version: http://65xx.unet.bz/fpu.txt
Some minor bugs was fixed (one in str2fp function, one in fexp function) and some improvements was done.
Added a function int2str compliant with format of sprintf() function (hex. formatting, a flag to Group thousand in decimal format).
The function that extract integral part and fractionary part was renamed from fmod to fpfrac.
Added two "remainders" functions: fpmod & fprem (work as the same functions in C).
Finally, added circular & hyperbolics functions:
fsin, fcos, ftan, fcotan (max. absolute value of argument: 2^56)
fasin, facos, fatan, fatanyx (this last function compute fatan(y/x) but return value in interval [0, 2pi] useful for computes phase angle)
fsinh, fcosh, ftanh
fasinh, facosh, fatanh
For implementation details and algorithms look at source code.
Greetings,
Marco
PostPosted: Wed Jun 08, 2016 9:48 pm
For those who haven't had a peek at Granati's source code, it runs to 9838 lines, which is a substantial piece of work (the entire firmware in my POC is about 11,300 lines). I hope to look more closely into it in the near future, after I recover from my next ( :cry: ) eye surgery.
PostPosted: Thu Jun 09, 2016 6:31 am
Whishes for a quick and good recovery.
Many lines on fpu.asm are just comments, assembled code is about 16k (many bytes used for store float constants).
The main goal is build a "virtual numeric co-processor" with some internal pseudo-registers stack-oriented, interfaced by 'cop' instruction.
PostPosted: Thu Jun 09, 2016 6:47 am
It's great to have this available online. Thanks Marco. I added it to the math and other software section of my links page.
PostPosted: Thu Jun 09, 2016 7:46 pm
Thank you.
I include comments in the line count because they have to be typed in, just like the actual instructions, and hence represent code editing time.
The constants tables should help a lot in what are computationally-intensive operations. This is a classic tradeoff between memory consumption and compute-bound performance. Given the much greater addressing capabilities of the 65C816 over the 65C02, memory consumption of this sort should not be a problem.
The BIOS in POC V2 (which is awaiting construction once I regain full use of both eyes) will be called via software interrupts using COP. It'll be an interesting exercise to integrate your floating point package into such an environment. :)
PostPosted: Mon May 01, 2017 7:16 am
Glanced over the code. Thank you for writing it. Looks good.
Is anyone aware whether 32 and 64 bit versions of this code exist?
PostPosted: Fri Oct 05, 2018 11:05 pm
32,64,128 bit
why not, ieee754-16 (half single)
https://en.wikipedia.org/wiki/Half-prec ... int_format
PostPosted: Sat Oct 06, 2018 6:50 am
(Welcome, tebe6502!)
PostPosted: Fri Oct 19, 2018 2:03 pm
The link seems to be dead now. Did anyone save a copy?
PostPosted: Fri Oct 19, 2018 2:19 pm
Can see it here:
https://web.archive.org/web/20170923012 ... 80/fpu.txt
PostPosted: Tue Oct 23, 2018 5:44 pm
Sorry for dead link, soon i put again online. Happened when i changed hosting (i restored an old version of the web site).
Marco
p.s.: the source code is available in the downloadable archive in my site
PostPosted: Tue Oct 23, 2018 6:00 pm
Great to know you're still active!
PostPosted: Tue Oct 23, 2018 7:45 pm
Is that http://65xx.unet.bz/ ? (It's not in your profile or signature line, but it's the base of your link above which gives a 404 error message.) I cannot find the source code in that domain. It is archived though at https://web.archive.org/web/20170923012 ... 80/fpu.txt .
