Page 1 of 1
Need a bit of help getting running
Posted: Sun Feb 07, 2016 7:36 pm
by Simon27
Hi all
Today I started assembly of my first 6502 machine today but having a bit of trouble getting it running.
So far it's simple: reset circuit working and generates a nice low pulse when the button is pressed. Phase 0, 1, 2 and SYNC signals all look right.
BUT! I've got the data bus fixed to $EA to force it into a NOP loop and nothing is happing. R/W is low, and so are all address lines.
I'm trying to see what could be causing this but all my connections appear right. Does the above point to anything obvious?
Re: Need a bit of help getting running
Posted: Sun Feb 07, 2016 8:26 pm
by Dr Jefyll
Is it a WDC cpu? They feature a BE (bus enable) pin which needs to be high. Sounds like maybe it's not.
Check the other "mystery pins" too, here on Garth's site.
Posted: Sun Feb 07, 2016 8:48 pm
by Simon27
That's exactly what it was, thank you!
I'm using a WDC chip, and my circuit was based on someone using an older MOS one.
Posted: Sun Feb 07, 2016 8:52 pm
by Dr Jefyll
A big thrill, I expect. Congratulations!! :D
Posted: Sun Feb 07, 2016 10:16 pm
by Simon27
Yep, it's only taken me about 4 years to get to this point!
Posted: Sun Feb 07, 2016 10:33 pm
You didn't ground pin 1 of the MPU, I hope. Pin 1 on non-WDC 65C02s is a ground, but is the VPB (vector pull) output on the WDC version.
The first step is always the hardest. Now that you have a working unit you'll find future builds easier to bring to life.
Posted: Mon Feb 08, 2016 9:55 pm
by Simon27
Good catch - I had this grounded! Bent the pin out from the socket as I was already using that handy pin to connect the decoupling cap.
Working on adding the RAM and decode logic, then will be ready for an actual program.
