Hi all
Today I started assembly of my first 6502 machine today but having a bit of trouble getting it running.
So far it's simple: reset circuit working and generates a nice low pulse when the button is pressed. Phase 0, 1, 2 and SYNC signals all look right.
BUT! I've got the data bus fixed to $EA to force it into a NOP loop and nothing is happing. R/W is low, and so are all address lines.
I'm trying to see what could be causing this but all my connections appear right. Does the above point to anything obvious?
Need a bit of help getting running
Re: Need a bit of help getting running
Is it a WDC cpu? They feature a BE (bus enable) pin which needs to be high. Sounds like maybe it's not.
Check the other "mystery pins" too, here on Garth's site.
That's exactly what it was, thank you!
I'm using a WDC chip, and my circuit was based on someone using an older MOS one.
Yep, it's only taken me about 4 years to get to this point!
- BigDumbDinosaur
You didn't ground pin 1 of the MPU, I hope. Pin 1 on non-WDC 65C02s is a ground, but is the VPB (vector pull) output on the WDC version.
Working on adding the RAM and decode logic, then will be ready for an actual program.
