thanks for the defines . it seems to enter callbacks without updating the registers
could you help me or do you have anyhingbetter
lib6502 trouble M602_RUN NEED STEP PROBLEM
Re: lib6502 trouble M602_RUN NEED STEP PROBLEM
It might be that you need the
externalise()
call, or possibly the
internalise()
call... have a look in the code to see how they are used.
externalise()
internalise()
errr.
exact;y this doesn't work and is impossible to debug in vs6 and they hang around here with that in java for example.
cpu class from dead6502 is seems not bad for rip anybody ?
[ cedar program they mention on this list = worth look at,went much better with lib86
listen / lib6502 question.
the more readable this lib is better the chips sell or worse ?
- GARTHWILSON
- Forum Moderator
the more readable this lib [lib6502] is better the chips sell or worse ?
Hi codecow
I have time now for a fuller response. First, welcome!
Second, I'm interested in your reference to "cedar" but I don't understand what that is.
Third, I see now that you already saw Symon, a 6502 emulator in Java, but you want a C version. There are several C emulators of 6502, perhaps you should look at all of them to see if the code is in a style which suits your development and debug environment. See here:
http://6502.org/tools/emu/#emulation
Finally, it might be worth me saying a little about the 6502 and this forum and the emulators - you might have misunderstood how many things are independent of each other:
- The 6502 was originally a chip by a company called MOS and has been made by several different manufacturers in the years after.
- The modern 65C02 is a chip made by a company called WDC, who also license their design to other companies including Sunplus/Generalplus.
- This site is independent of all companies, and almost everyone here is a hobbyist or engineer representing themselves, and not representing any company.
- The various emulators you can find, including lib6502, are each independent developments by various developers, some of which might be here on the forum but many of which are not here.
Now, lib6502 is something of a favourite of mine, but it's not my code, and it isn't suitable for all purposes. It's high performance and the code is built by a collection of defines - it's not the easiest code to debug. As you've found!
Hope this helps
Hope this helps
