Simple hex question
James_Parsons
Simple hex question
Post by James_Parsons »
I'm sorry, but what is four bytes in hex. for example I have memory
$0500
and I need to jump 4 bytes ahead. what would I add. I know this seems trivial but I am having a hard time understanding
JMP $FFD2
Re: Simple hex question
$0500
What is that? If it's ORA 00 (IOW, OR accumulator with the contents of address 00 in ZP), the next instruction might be a conditional branch around a four more bytes of instructions, for example a BNE which assembles to D0 04.
Many of the questions you're asking will be answered by reading any 6502 programming manual. There are many good ones available, and any of them will get you more satisfaction from the whole 6502 experience. If you don't read any of them, I expect you will probably continue asking super basic questions and not make much progress. I like to recommend WDC's "Programming the 65816 including the 6502, 65C02, and 65802," available free online. It's big, but relatively easy reading, and you don't have to read the whole thing, as you can quit when it gets into the 16-bit stuff and then much of the rest is reference, where you look stuff up after you've got the basics down.
$0500
Questions like these don't belong in this section of the forum. You're scattering questions all over the 6502.org landscape and I, for one, am getting a bit weary of it. How about if you try to consolidate them into relevant areas and before posting, see if you can find the answer by use of that wonderful thing called an Internet search engine?
An addendum to that is 6502.org is not a tutoring service. You need to spend time reading readily available materials, such as the programming manual at WDC's website that Garth mentions. The 6502 is probably the most documented microprocessor in history, and countless people (including me) have learned how to use it by reading, reading, and more reading. Bluntly stated, quit asking so many simple questions like the above, lest you start irritating people around here and cause them to ignore you.
barrym95838
Post by barrym95838 »
Yeah, for someone who has "written operating systems" for the x86, these scattered questions seem a little strange. Would it help to have a sticky "Newbie Corner" somewhere, to encourage discussion of basic theory without polluting all of the other threads?
Mike
