So what is the correct way to design your system to be able to program to an eeprom in circuit? All the ones I see have really slow access times ie 28c16's with 90ms access times.
In Circuit EEPROM Programming at speed.
clockpulse
Re: In Circuit EEPROM Programming at speed.
You might want to look at the Atmel AT28C64B, it's 8k with 150ns max access time. (usually faster than max at room temp, I have used them at 10mhz) There are faster units as well. As far as programming cycles, you can use a time delay, data polling or toggle bit.
I meant Nano Seconds, Certainly not Mano seconds
Fat fingers on the keyboard.
So the typical method your saying is to make a routine that basically counts a few clock cycles between each write of data or verifies each bit of data going into the eeprom.
Makes sense, I was just thinking of using it as slow ram. I guess I could make a "firmware" update function that copies from Ram to eeprom.
Thanks
Thanks
The technology of the 28C16 is quite old. I had expected that the devices were fully obsolete, but apparently ON Semiconductor and Atmel still make these types of devices (and Digi-Key apparently has some stock).
If you are making something new, I would recommend using a 5V Flash part instead. The write sequence may not be as clean as that of the 28C16 EEPROM, but it would certainly program 3 orders of magnitude faster: 10 microseconds per byte for Flash versus 10 milliseconds per byte for 28C16 EEPROM.
Michael A.
- GARTHWILSON
- Forum Moderator
8BIT wrote:
I can post some code snipets if you are interested.
My SBC2 uses essentially the same code. This has been simplified for the sake of clarity as my code first copies itself from the System Monitor in EEPROM to RAM before executing. This routine will copy 16k from RAM located from $1000-$4FFF to EEPROM located at $8000-$BFFF.
This routine has to be located in RAM also, at say address $0800 for example.
Here's the code:
The polling mode of my EEPROM states that bit 7 will be read as opposite of the data written while the write sequence is in progress and will return a matching value when the write is complete. I simply use the EOR instruction to test the source and destination bits. It works quite well.
Here's the code:
AddPtr = $e0 ; zp pointer
DestPtr = $e2 ; zp pointer
LDA #$00
STA AddPtr
LDA #$10
STA AddPtr+1 ; start of RAM source
LDA #$00
STA DestPtr
LDA #$80 ; start of EEPROM
STA DestPtr+1
Loop LDA (AddrPtr) ; Moves one byte
STA (DestPtr) ;
EEPROM_TEST LDA (AddrPtr) ; Read Source
EOR (DestPtr) ; EOR with EEPROM Data
bmi EEPROM_TEST ; Bit 7=0 if write is done
INC AddPtr ; pointers are in sync
INC DestPtr ; so we can inc together
BNE Loop
INC AddPtr+1
INC DestPtr+1 ; inc upper byte
LDA #$C0 ; 16k copied when
CMP DestPtr ; DespPtr+1 = $C0
BNE Loop
RTSDaryl
Thanks Daryl that is perfect. I dont really care how long it takes for the data to get in there. It would be nice to not have to pull the chip out to update the firmware. especially when your tweaking things a lot.
You're welcome. I bought 1 of these and used it on SBC-2 (and later on SBC-3) to make cycling the EEPROMs faster with less worry about bending pins. I just mounted a machined-pin socket on the board and plugged this in on top. Once development was done, I removed the ZIF socket and put the EEPROM in the machined-pin socket.
http://www.digikey.com/product-detail/e ... 7-ND/41613
- GARTHWILSON
- Forum Moderator
Daryl, on second thought, I think I'll just post the link your post above. It's simpler, and if you decide to edit it the post for whatever reason, you can.
