Newbie clock help
Posted: Fri Dec 09, 2011 4:15 pm
Adam (1) describes a clock circuit originating from Harry the Bastard, who can no longer be found.
Chris Ward shows an identical circuit (2).
Thomas Scherrer (3) shows a similar circuit with different values and a ground connection through a capacitor.
Q1. Adam refers to a '6502' and uses a 2MHz crystal. My CPU is marked R6502P, which is rated at 1 MHz. What should I change?
Q2. Should it work without the ground connection? What is the benefit?
Q3. Adam suggests a "... need to play around ...", particularly with crystal frequency and capacitor rating. How different a capacitance do I need to try? (I shall have to go online to find these, so your guidance will save me time).
Many thanks, Robin
(1) http://www.reocities.com/SiliconValley/ ... 02prj1.htm
(2) http://www.chrisward.org.uk/6502/schematics/6502-1.png
(3) http://www.gaby.de/z80/uexosc.htm
Many thanks, Robin
