BitWise wrote:
I stumbled across a new PIC chip (24FJ256DA210) that contains an embedded graphics generator, CLUT and 96K of RAM (enough for QVGA 320x240 @ 8 bpp) that looks interesting. Slightly higher resolutions and colour depths are possible if integrated with an external RAM. The graphics controller can do some simple blitter functions, character drawing and image decompression.
Its designed to drive a LCD screen directly but looks like it could be made to output VGA compatible signals. No sprites but you would have almost 100% of 16 MIPS to program anything like that with.
The chip runs at 3V3 but the pins for I2C and SPI are 5V tolerant. The 100pin chips have an EPSP interface that in slave mode would allow them to attached as a 4 addressable memory locations on an 8-bit data bus - all control signals would have to be 3V3 and you couldn't have external RAM.
Not bad for less that $8.
I know this is an old topic, but this intrigued me. I might be interested in investigating this but PIC programming isn’t my area exactly. I’m working on a project and here’s basically what I want.
A linear 256 color (even 64 color would be fine) bitmap mode
8px8p tile based display modes with multicolor support
Sprites (ideally 16x16 with 16 colors per sprite)
Both horizontal and vertical scroll support window based
I don’t need any vector or line draw features, though that would be nice.
I think something like this could be great for lots of 6502 based projects as well as other home brews.
Personally I would pack it all onto a little card that can be connected either card edge or with header pins. Make so that it has an 8 bit exposed data bus, a few address lines, an active low CS line, RW line, and an IRQ line. Probably RESET as well. If anyone finds this intriguing PM me.
