My new fuel injection controller based on w65c265
swiety
Post by swiety »
http://www.fotosik.pl/pokaz_obrazek/pel ... d2291.html
Run at 6.5536 MHz. On board - 29EE010 flash rom, 82c54 - timer , ADC0809 - A/D converter, MAX 232 , 74hct4060.
ElEctric_EyE
Post by ElEctric_EyE »
That is in my area of interest also. Cars and fuel modifications! Welcome back, I was not here before when you posted your previous creations. I'm catching up on your last posts from back in 2007...
Controlling 4 injectors? I don't see the drivers...
Are you running your fuel mixture more rich or more lean? Fuel additives?
swiety
Post by swiety »
Yes, 4 injectors , at that moment i use mc33385 (at upper left side) to drive injectors independent.
Old board use 2 pieces VNP5n07 - smartfet , one transistor drive 2 injectors per bank.
Currently I am using this system in my amateur racing car , so the fuel mixture is more rich than lean. To tune the fuel maps i use wideband oxygen senor and AFR type device, by which I can see what is happening with the exhaust gases
My youtube channel :
http://www.youtube.com/user/swietyEFI?feature=mhum
Engine tuning - old ecu:
http://www.youtube.com/user/swietyEFI?f ... QSAk3csDwc
swiety
Post by swiety »
First test on megatune (a megasquirt tuning program):
6502.org wrote:
Image no longer available: http://img411.imageshack.us/img411/7314/dsc01287medium.jpg
swiety
Post by swiety »
Assembled unit:
6502.org wrote:
Image no longer available: http://www.kswiecicki.prospect.pl/ecu/DSC01328%20(Medium).JPG
