Hi,
What assembler should I use to build EhBasic if not using the simulator ?
Cheers.
Phill.
How to build.....
DaveK wrote:
You can assemble in the simulator and save an image of the memory, that's what I do.
However as a more perminent solution I converted the code (via a conversion program, written in delphi), to assemble with BeebAsm, as this is what I was using for other projects, that seems to work fine now.
Cheers.
Phill.
Rich Cini
http://cini.classiccmp.org
GitHub Repro: https://github.com/RichCini
